Old 04-17-2018, 21:24   #1 (permalink)
Thanks Meter: 21,699
How To Use FRP EMMC (UART) by EFT Dongle
By using this method we can convert FRP On to Off without Data loss!
We need UART cable to do this !
First we have to check
whither the device is Android 6.0 or above
If it is 6.0 then it is ready to go but if it is 7.0 then we have to flash Sboot from Android 6.0 (same binary as in device)
We already uploaded tested Sboot files on Dongle Support
You can check your device is 7.0 or 6.0 from Recovery Mode!
Our example will be Galaxy G610F
It is on Android 7.0
So we have to flash sboot from android 6.0 and it must be same binary as in device
2-Now Navigate to FRP Section and choose the right model (G610F)
Connect your Uart cable (Standalone or with any box com)
1- Press Rescan and choose the right COM
2- Press Reset FRP EMMC
Now
a- Press Volume Down and Power while connecting to UART cable
b- On Dongle request disconnect from UART and connect to normal USB cable
C- On Dongle request disconnect from USB and connect to UART cable while pressing Volume Down and power button and wait till finish
Now FRP Must be turned to OFF
The Following 11 Users Say Thank You to easy-team For This Useful Post:
Old 04-19-2018, 07:51   #2 (permalink)
Member: 2828514
Thanks Meter: 99
Thanx for sharing
Old 04-29-2018, 17:45   #3 (permalink)
Member: 2350853
Thanks Meter: 36
thank you
but i try g610f u1 6.0.1 and
resetting frp.....done
but frp is ON ??
Old 05-14-2018, 17:08   #4 (permalink)
Originally Posted by ahdkfiry View Post
thank you
but frp is ON ??
Use another Sboot bro
like this one you can try it
The Following 3 Users Say Thank You to easy-team For This Useful Post:
Old 05-15-2018, 00:42   #5 (permalink)
Member: 2828884
Thanks Meter: 3
where to buy uart cable?
The Following User Says Thank You to will91491 For This Useful Post:
Old 08-09-2018, 08:46   #6 (permalink)
Member: 1431853
Thanks Meter: 15
This is EFT UART Cable or Other Cable???
Old 08-09-2018, 23:06   #7 (permalink)
it doesn't matter , any cable works for you .
Old 08-27-2018, 14:16   #8 (permalink)
rifaaq's Avatar
Member: 567810
Sonork: Xiaomi direct
Thanks Meter: 30
bin format
I download from support J710KKKU1AQB3_6.0.1.rar.
inside sboot.bin
How can flash bin format?
Old 08-28-2018, 07:28   #9 (permalink)
Member: 2536582
Thanks Meter: 34
download 7zip.and instal .then sboot,bin file right click the 7 zip option click add to archieve window will open in first box select tar formate and save done ,file change in tar farmate and do flash.
Old 08-28-2018, 07:53   #10 (permalink)
Member: 798811
Sonork: astrong
Thanks Meter: 16
nice one Brother for d' reference............
Br.
Old 08-28-2018, 08:50   #11 (permalink)
rifaaq's Avatar
Member: 567810
Thanks Meter: 30
Give "Invalid tar magic" error
Page generated in 0.21341 seconds with 8 queries
