HUAWEI Id on p30 ELE-AL00 9.1.0(C00) Downgrade Firmware For Bypass Huawei Id After flashing, Use safe mode method to Huawei Id. Important: Use this firmware at your own Risk! Phone does not enter safe mode (not in the menu at least) No codes work from emergency What is the safe mode sollution? Talkback is 7.2 version.... so no bypass either ELLE-AL00B 9.1.0.162(C00E160R2P1)_Firmware_9.1.0_r1_EMUI9.1.0 |
You must format device in recovery mode and then the safemode will show up , did u do that ? |
Yes, I followed all the videos on youtube. I wrote the downgrade firmware : first I tried only the .app from the base folder, then I wrote the cust .app also but no difference. I hard reset it, then I choose Safe mode. It goes to safe mode (coz it`s written down left) but It aks for wifi and Huawei ID. https://i.postimg.cc/cJbqf8Bm/MVIMG-20200212-124507.jpg after hardreset, when I choose safe mode: https://i.postimg.cc/TPwMycg1/IMG-20200212-125707.jpg |
I am in the same looking for solution for this model with huawei id. |
Well, do the "safe mode" bypass work with your phone ? |
It does not work, does not enter the phone menu. |
maybe you can try lower version by sd card you won't lose any thing but be careful about model and such info |
I can`t find any older than 162 version for ELE-AL00 My question is still : how come the safe mode bypass works for some ppl and for me it does not work? I`m guessing it works considering it`s on the FTP server named downgrade for Huawei ID |
Safe mode trick only works when mobile have Frp, this method dont work on huawei id locked. |
if fail buy code bro..prices down,,check ourself on unlock sites |
Anyways, my issue was about ELE-AL00 9.1.0(C00) Downgrade Firmware For Bypass Huawei Id ... Did anyone used this and it worked? https://easy-firmware.com/index.php?...file&id=178601 |
Can anybody tell me how to bypass ? Video is not conclusive for this version. It`s badly named (file 2 is actually the last step) https://mega.nz/#F!zfwzDAyR!j33Ye_Up...zzjFA!7fgHxSKK |
File 1 how many gb size ??and file 2 how many ?? No instructions inside? |
