huawei jsn-l22 frp solution needed Checking fastboot device.....OK Reading info.....OK Device Model: JSN-L22 Device Firmware: :JSN-L22 10.0.0.217(C185E2R1P1) Base Firmware: :JSN-LGRP2-OVS 10.0.0.217 Custom Firmware: :JSN-L22-CUST 10.0.0.2(C185) Preload Firmware: :JSN-L22-PRELOAD 10.0.0.1(C185R1) Device FB Lock: LOCKED Device USER Lock: LOCKED Device Lock: locked Waiting for server.....OK Reading data.....Security is not supported Operation {Reset FRP using server} ID: 56FCDCA98CDBE9D7 Elapsed time 00:08 -- Version 3.4.5 |
after flash this file phone stuck on error mode now in upgrademode showing this erro here is file name which i was trying to flash but flashing stuck JSN-L22 10.0.0(C185) Downgrade For FRP Bypass By EFT Pro (AOD) Searching for upgrade port.....Detected {COM45} Target model [JSN-L22 10.0.0(C185)] Reading data from server.....OK Bypassing downgrade protection.....Failed: writing failed, Please contact support team Operation {Downgrade to reset FRP} ID: 766C628766DA4E4E Elapsed time 00:04 -- Version 3.4.5 |
solved by flashing this file throgh otg Johnson-L22C 9.1.0.217(C185E3R2P1T8)_Firmware_9.0.0_r3_EMUI9.1. 0_05015KFK File By (www.needromarab.com) after that hard reset phone and use safe mode to bypass frp |
file and feature is already tested thousands of times ! https://easy-firmware.com/solution/e...-with-eft-pro/ |
