Old 09-14-2020, 10:03   #1 (permalink)
Arslanmayo's Avatar
Member: 2478233
Thanks Meter: 374
huawei jsn-l22 frp solution needed
Checking fastboot device.....OK
Reading info.....OK
Device Model: JSN-L22
Device Firmware: :JSN-L22 10.0.0.217(C185E2R1P1)
Base Firmware: :JSN-LGRP2-OVS 10.0.0.217
Custom Firmware: :JSN-L22-CUST 10.0.0.2(C185)
Preload Firmware: :JSN-L22-PRELOAD 10.0.0.1(C185R1)
Device FB Lock: LOCKED
Device USER Lock: LOCKED
Device Lock: locked
Waiting for server.....OK
Reading data.....Security is not supported
Operation {Reset FRP using server} ID: 56FCDCA98CDBE9D7
Elapsed time 00:08 -- Version 3.4.5
Old 09-14-2020, 12:36   #2 (permalink)
Arslanmayo's Avatar
Member: 2478233
Thanks Meter: 374
after flash this file phone stuck on error mode now in upgrademode showing this erro
here is file name which i was trying to flash but flashing stuck JSN-L22 10.0.0(C185) Downgrade For FRP Bypass By EFT Pro (AOD)
Searching for upgrade port.....Detected {COM45}
Target model [JSN-L22 10.0.0(C185)]
Reading data from server.....OK
Bypassing downgrade protection.....Failed: writing failed, Please contact support team
Operation {Downgrade to reset FRP} ID: 766C628766DA4E4E
Elapsed time 00:04 -- Version 3.4.5
Old 09-14-2020, 13:36   #3 (permalink)
Arslanmayo's Avatar
Member: 2478233
Thanks Meter: 374
solved by flashing this file throgh otg Johnson-L22C 9.1.0.217(C185E3R2P1T8)_Firmware_9.0.0_r3_EMUI9.1. 0_05015KFK File By (www.needromarab.com)
after that hard reset phone and use safe mode to bypass frp
Old 09-14-2020, 21:45   #4 (permalink)
Thanks Meter: 15,020
file and feature is already tested thousands of times !
https://easy-firmware.com/solution/e...-with-eft-pro/
Old 09-15-2020, 14:59   #5 (permalink)
Arslanmayo's Avatar
Member: 2478233
Thanks Meter: 374
yup bro but my flashing got stuck in the middle thats why there was only recovery but device dont have usb update mode but done with otg and used safe mode bug and bypassed frp
Page generated in 0.42397 seconds with 7 queries
