10-12-2020, 15:51 | #1 (permalink) |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Cannot Root A505FN Android 9 and 10, LDU ( SOLVED ) Since i was losting the ROOT each 10 mins, have Upgrated to Android 10, but haven't gain the root only one time with this FW: A505FNXXU4BTC9 and his root file. with Android 9: Code: Connecting to device.....OK Reading device info.....OK Baseband Version: A505FXXS3A***,A505FXXS3A*** Serial Number: R58M34QGRBE Device Arch: exynos9610 Device bootloader: A505FNXXS3A*** Device selinux: enforcing Device warranty bit: 1 Device Firmware: A505FNXXS3A*** Android version: 9 Device SDK: 28 Device data encryption: encrypted Firmware Country: ITALY Device Hardware: exynos9610 Device CPU: arm64-v8a Device Factory: samsung Device Model: SM-A505F Device IMEI: 352698116117883 Root status.....Rooted { 3.19:EFTSU } Operation {Read Info} ID: 41E90E5217A74C1D Elapsed time 00:00 -- Version 3.4.5 Connecting to device.....OK Reading device info.....OK Baseband Version: A505FXXS3A***,A505FXXS3A*** Serial Number: R58M34QGRBE Device Arch: exynos9610 Device bootloader: A505FNXXS3A*** Device selinux: enforcing Device warranty bit: 1 Device Firmware: A505FNXXS3A*** Android version: 9 Device SDK: 28 Device data encryption: encrypted Firmware Country: ITALY Device Hardware: exynos9610 Device CPU: arm64-v8a Device Factory: samsung Device Model: SM-A505F Device IMEI: 352698116117883 Root status.....Rooted { 3.19:EFTSU } Patching LDU security.....OK Operation {Fix Demo devices Network} ID: 8BADF14D63714ED1 Elapsed time 00:01 -- Version 3.4.5 I need of Remove LDU from *#0011# otherwise never i can have Signal, how can do since have tryed all? Br allumts |
10-12-2020, 21:19 | #2 (permalink) |
Product Manager Join Date: Feb 2016 Location: EFT Dongle
Member: 2536865 Status: Offline Sonork: 100.1584728 Thanks Meter: 21,225 | Already A505F is rooted so many times , Provide log for creating and flashing root file android 10 ! Notice , You MUST create root file with EFT Pro from same firmware on device , dont use files from eftsu for now ! |
The Following User Says Thank You to easy-team For This Useful Post: |
10-13-2020, 08:35 | #3 (permalink) | |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Quote:
I've rotted many device in one click with file of EFTSU and LDU Patched Perfect. Ok i've seen thet EFTSU have some issue, (sure you are working in it), so i want create, how you suggest, Root file from same Firmware have in device and let know you. Br allumts | |
10-13-2020, 12:30 | #4 (permalink) | |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | All Solved, Thanks to EFT :) Finally Rotted by Boot Method of BEST EFT Quote:
LDU REMOVED By EFT Imei Repaired and patched by chimera thx to ROOT of EFT Br allumts | |
