Old 11-20-2020, 13:52   #1 (permalink)
Member: 341207
Thanks Meter: 14
i phone 14.1 no problem 14.2 problem
i phone 7 14.1 versıon no problem good work but phone restore 14.2 then jailbreak eft ı cloud bypass failed sim kart phone egain bypass problem problem solve how ?
Preparing paths.....OK
Setting up.....OK
Checking iDevices.....OK
Reading iDevice info.....OK
Activation Status: Unactivated
CPU Arch: arm64
Device Class: iPhone
Device Name: iPhone
Firmware Version: iBoot-6723.42.3
Device IMEI: ****************
Product Name: iPhone OS
Product Type: iPhone 7
IOS Version: 14.2
SIM Status: kCTSIMSupportSIMStatusReady
Device Serial Number: DV6VT066HG7P
MEID Status: Not Supported
Preparing.....OK
Bypassing.....Error: Connection Exception, Please be sure from JailBreaking Your iDeviceFailed to get ActivationInfo from mobileactivation
Operation {Bypass iCloud at Hello Screen} ID: BB97C2C675CFEA13
Elapsed time 00:39 -- Version 3.5.0
Old 11-21-2020, 22:05   #2 (permalink)
Thanks Meter: 21,229
We will investigate the issue once we have iPhone 7 in our hands ~\!
The Following User Says Thank You to easy-team For This Useful Post:
Old 11-21-2020, 22:49   #3 (permalink)
Member: 349343
Thanks Meter: 32
Setting up.....OK
CPU Arch: arm64
Device Name: iPhone
IOS Version: 14.2
Preparing.....OK
This error is often associated with errors in the Wifi, BT, SN address. Before making the bypass, you need to check the activation, if it asks for a username and password, then everything is fine and the bypass should go through.
Page generated in 0.14859 seconds with 9 queries
