Old 03-30-2024, 20:49   #1 (permalink)
Member: 342175
Thanks Meter: 5
iphone 11 16.6 icloud open menu
Waiting for server.....OK
Checking iDevices.....OK
Remove icloud with UDID .....(00008030-00194D103412802E)...
ERROR: DATA NOT FOUND OR TOKEN EXPIRED
Please follow the instructions below and try again:
1 - Before connecting the DEVICE WITH ICLOUD to the WIFI network go to the wifi settings and configure Proxy Server: 51.178.81.232 Port:8881 press Save, and then connect
2 - Go from safari to "51.178.81.232:8881" and press download , then Allow
3 - Go to Settings General->Profile and Install the profile you downloaded
4 - Then go Settings->General->About-> scroll down and after go to Certificate Trust Settings and enable DO_NOT_TRUST
5 - Go to iCloud > Turn OFF Game Center->Then Turn ON again (only 1 times)
6-After completing the previous steps, go apple Tap select (Remove Icloud Open Menu with UDID (FMI OFF with UDID)) and click Start again
go to icloud turn on and off game center
If the process is successful, Turn OFF WiFi then check iCloud services before flashing.
Operation {Remove Icloud Open Menu with UDID} ID: 2AB59E6CD0E87896
Elapsed time 00:02 -- Version 4.7.0 Build 001
Old 03-30-2024, 21:29   #2 (permalink)
Thanks Meter: 21,197
https://www.youtube.com/watch?v=1OFo...nnel=EFTDongle
Follow the explanation here and repeat turning off and on the Game Center until it is on the dongle. After that, check via IMEI phone that it is off.
Old 03-30-2024, 22:27   #3 (permalink)
Member: 342175
Thanks Meter: 5
all is ok but i turn it off whene turn it on it ask about password
Old 03-31-2024, 04:22   #4 (permalink)
Y Michael's Avatar
Member: 2947987
Sonork: Null
Thanks Meter: 71
That means the phone is not supported
Sent from my M2103K19G using Tapatalk
The Following User Says Thank You to Y Michael For This Useful Post:
Old 03-31-2024, 08:33   #5 (permalink)
Not supported sir Only Game Center answers and does not ask you for your password
The Following User Says Thank You to easy-team For This Useful Post:
Page generated in 0.15239 seconds with 8 queries
