02-27-2024, 10:41 | #1 (permalink) |
Junior Member Join Date: Oct 2023 Location: negresti-oas Age: 60
Member: 3048419 Status: Offline Thanks Meter: 6 | Eft pro open menu Checking iDevices.....OK Remove icloud with UDID .....(00008020-0005484A3A8A002E)... ERROR: DATA NOT FOUND OR TOKEN EXPIRED Please follow the instructions below and try again: 1 - Before connecting the DEVICE WITH ICLOUD to the WIFI network go to the wifi settings and configure Proxy Server: 51.178.81.232 Port:8882 press Save, and then connect 2 - Go from safari to "51.178.81.232:8882" and press download , then Allow 3 - Go to Settings General->Profile and Install the profile you downloaded 4 - Then go Settings->General->About-> scroll down and after go to Certificate Trust Settings and enable DO_NOT_TRUST 5 - Go to iCloud > Turn OFF Game Center->Then Turn ON again (only 1 times) 6-After completing the previous steps, go apple Tap select (Remove Icloud Open Menu with UDID (FMI OFF with UDID)) and click Start again go to icloud turn on and off game center If the process is successful, Turn OFF WiFi then check iCloud services before flashing. Operation {Remove Icloud Open Menu with UDID} ID: 1D87DE391719E73E Elapsed time 00:01 -- Version 4.6.8 Build 002 |
02-27-2024, 11:18 | #2 (permalink) | |
Product Manager Join Date: Feb 2016 Location: EFT Dongle
Member: 2536865 Status: Offline Sonork: 100.1584728 Thanks Meter: 21,271 | Quote:
