iPhone SE Passcode Bypass ios 15.5 Done By EFT Pro iPhone SE Passcode Bypass ios 15.5 Done By EFT Pro 1- Update ios to 15.5 3uTools 2- PWNDFU EFT Pro 3- Boot Passcode EFT Pro 4- Backup Passcode EFT Pro 5- Restore ios to 15.5 3uTools 6- PWNDFU EFT Pro 7- Boot Passcode EFT Pro 8- Restore Passcode EFT Pro All Done EFT Pro https://www10.0zz0.com/2022/07/12/13/535698148.png https://www10.0zz0.com/2022/07/12/13/585198362.png Code: iDevices PWNDFU :..... Code: Preparing.....OK Code: Checking iDevices.....OK https://www7.0zz0.com/2022/07/12/13/506881992.png Code: Checking iDevices.....OK https://www14.0zz0.com/2022/07/12/13/444849423.png B.R |
notifications work after bypass ? |
what a miracle i try more than 10 device to passcode bypass only one worked after too much time wasted |
i got many devices unlocked For PWNDFU mode, i use iramexpert 3.0.6 on Mac with cable DSCD Then go to Windows and run EFT Dongle to boot mode and backup data Restore device with itunes or 3utools Then go back to Mac and use PWNDFU mode from iramexpert 3.0.6 on Mac with cable DSCD Go back to Windows, run EFT Dongle to boot device and restore |
thank you very much and more power to you! |
Thank you very much Brother, it is very well explained |
Sir you get phone in Hello screen before backup password before, is it possible to bypass icloud with network in os15x? Quote:
in this case you can not do backup or Passcode Bypass proces bypass icloud (Hello screen) with network in os 15 not suppert by eft until now waiting for the team eft if there is anything new |
[HELP] EFT PRO iPhone 8 restore passcode backup not working Quote:
I backed up iPhone 8 (disabled) on EFT pro. When I restore it everything shows "successfully" but the phone is still "locked to owner". I tried many times still the same. Another thing to note: The email showing on EFT backup is different from the email showing on "Locked to owner" screen. Please help me fix this problem. Thank you |
