![]() | #1 (permalink) |
Product Manager ![]() ![]() ![]() ![]() ![]() Join Date: Feb 2016 Location: EFT Dongle
Member: 2536865 Status: Offline Sonork: 100.1584728 Thanks Meter: 22,286 | iPhone X - iOS 16.7.10 ✅ Bypass iCloud Passcode With Signal 💯 EFT Pro 👑 Bypass iCloud Passcode With Signal 💯 EFT Pro 👑 ![]() ![]() |
The Following User Says Thank You to easy-team For This Useful Post: |
![]() | #2 (permalink) |
Moderator ![]() Join Date: Jan 2008 Location: <jeddah al saudia> Age: 37
Member: 668050 Status: Offline Sonork: 100.1656307 Thanks Meter: 1,023 | plz look at this problem IOS 16.7.1 X PASSCODE TRY MORE THAN 10 TIME PHONE os ALSO CRASHED AFTER MOUNT ERROR TRY MOUNT AUTO.MTH1,MTH2 ONE CLICK,ALSO MANUAL SAME RESULT Successfully! Checking iDevices.....OK Checking SSH......P:16..P:15..P:8..OK Waiting for server.....OK Mounting IPhone/Ipad partition (Hello/Passcode).......Failed Checking iDevices.....Error: No devices found, Please connect you iDevice to this PC Operation {Boot Passcode/Hello IOS 11.x Up 16.x One Click} ID: 4D138EA7B285FB7D Elapsed time 05:46 -- Version 4.9.2 Release 0001 Build 418 |
![]() | #3 (permalink) | |
Member: 2536865 Status: Offline Sonork: 100.1584728 Thanks Meter: 22,286 | Quote:
you use wrong boot sir correct boot is 16.6 fellow steps in video | |
![]() | #4 (permalink) |
Member: 668050 Status: Offline Sonork: 100.1656307 Thanks Meter: 1,023 | =easy-team-you use wrong boot sir correct boot is 16.6 fellow steps in video[/B] Code: Test Signed Drivers is....ON Preparing.....OK Fix Drivers.........OK Check BOOT.....NO Reading iDevice info.....OK Device NAME: iPhone X (GSM) Product NAME: iPhone10,6 Device MODEL: d221ap Device ECID: 0x458542098a02e Device CPID: 8015 Device SRTG: IBOOT-3332.0.0.1.23 Device MODE: DFU Device CPU: A11 Waiting for server.....OK Checking PWNDFU.....NO iDevices PWNDFU :..... Verifying drivers .....Ok Device CPU: A11 Preparing.....OK Fix Drivers.........OK PWNDFU IS.....Ok Preparing.....OK Fix Drivers.........OK Exploiting Device [1].... Sending File (iBSS.img4).....Failed Sending File (iBSS.img4).....OK Sending File (iBEC.img4).....OK Sending File (devicetree).....OK Sending File (ramdisk).....OK Sending File (adc).....OK Sending File (trustcache).....OK Sending File (kernel).....OK Successfully! Checking iDevices.....OK Checking SSH......P:16..P:15..P:8..OK Waiting for server.....OK Mounting IPhone/Ipad partition (Hello/Passcode).......OK BuildID:A782B4B6-4E58-11EF-BA37-5345BE3EFD64 ProductBuildVersion:20H350 ProductCopyright:1983-2024 Apple Inc. ProductName:iPhone OS ProductVersion:16.7.10 SystemImageID:CA14588B-DCF2-4233-9AF9-C077BAAF631E Checking iDevices.....OK Preparing paths.....OK Checking SSH......P:8..OK Waiting for server.....OK Activation Files Restoring .......OK Skip Setup...OK Disable Reset Settings and Updates....OK Operation {Boot Passcode/Hello IOS 11.x Up 16.x One Click} ID: 87AECB171CD2D8D4 Elapsed time 02:38 -- Version 4.9.2 Release 0001 Build 418 |
The Following User Says Thank You to chand_gee For This Useful Post: |
