Old 06-27-2024, 18:29   #1 (permalink)
Arafat Mashaka's Avatar
Member: 750759
Sonork: 75101010
Thanks Meter: 176
iphone x open menu FMI need help
Waiting for server.....OK
Checking iDevices.....OK
Reading iDevice info.....OK
Activation Status: Activated
BuildVersion: 20H343
CPU Arch: arm64
Device Class: iPhone
Device Name: iPhone
Firmware Version: iBoot-8422.142.2.700.1
Device IMEI: 354872095187849
Product Name: iPhone OS
Product Type: iPhone X GSM
IOS Version: 16.7.8
SIM Status: kCTSIMSupportSIMStatusReady
Device Serial Number: DNPYKHL8JCLH
DeviceID: 9fc73e3b968810ae15601b4c691fc102fe015cf6
MEID Status: Not Supported
Info.....Backup Successful.
Get Auth Info.....
2024/06/27 19:23:02 Bad password
Operation {Remove Icloud Open Menu with BACKUP} ID: 4CF0A81F10151ACE
Elapsed time 05:59 -- Version 4.7.9 Build 00
i already set password to 1234 but says bad password help please
Old 06-27-2024, 18:45   #2 (permalink)
Thanks Meter: 21,546
CPU Arch: arm64
Device Name: iPhone
IOS Version: 16.7.8
Get Auth Info.....
Don't put the same password on your phone, make it different
The Following User Says Thank You to easy-team For This Useful Post:
Old 06-28-2024, 09:09   #3 (permalink)
Member: 750759
Sonork: 75101010
Thanks Meter: 176
CPU Arch: arm64
Device Name: iPhone
IOS Version: 16.7.8
MEID Status: Not SuBackup Successful.
Get Auth Info.....
2024/06/28 10:06:42 Bad password
Operation {Remove Icloud Open Menu with BACKUP} ID: BB8AB283C0CFC263
Elapsed time 02:18 -- Version 4.7.9 Build 001
same problem sir
Old 06-28-2024, 15:40   #4 (permalink)
CPU Arch: arm64
Device Name: iPhone
IOS Version: 16.7.8
Get Auth Info.....
same problem sir
Reset all settings without wiping data, put a new password on the phone, and repeat
Old 07-01-2024, 11:21   #5 (permalink)
Member: 750759
Sonork: 75101010
Thanks Meter: 176
After reset i got this change
CPU Arch: arm64
Device Name: iPhone
IOS Version: 16.7.8
Get Auth Info.....
OK
Apple ID:[email protected]
PET Token:GV4R7o7s0fetcAug/D3/PNJCw+gBUh0C+IiQwew6VZyh47xc5dwE+gjCpuZQ4pr+pw8+6Z xzNVdfWzl6jddiaeLCM3BujUv+WkdiWeQk+UPFd8+YnQ7LWpFn 5QPmZb2nQymWFuacyK2E2KXmEBB8szw50/IfL6vEc9bpQh9xeP4spouA+YFJ3x+EDfIErkj5PoefYKobe1M+ LVKOSd99wmEn/G8ti2CJ6vBa5x5kSBtEFFNo7yoSIr7wZr6jWrwVlv0xNXFZZxZ pWSYCpYIThYvMwP+s2Y/tL7E5GhyFD+iT1+fJ1Q0XnEmm1KqO1lFtO2LgQafUT4Bpmuzeb EAMmPXtSWo/1di0+8XgjfQYUtmpuUsQ3g+JKLD5M3XCih4Mx1uBJuFIYVFnry BW9u4x5W13FsmbsJpfITRuz2dF+7iDZNi1JHnprEle4tEqJpix QRqoIsvphBumctPYVrJY5BiKRSWuPET
ERROR: DATA NOT FOUND OR TOKEN EXPIRED
Please follow the instructions below and try again:
If it expires, you need to turn the game center off and on again and backup again to get the token back
Token Expired. status code: 401
Operation {Remove Icloud Open Menu with BACKUP} ID: B9A4E7DAB11A4C6F
Elapsed time 03:02 -- Version 4.7.9 Build 001
CPU Arch: arm64
Device Name: iPhone
IOS Version: 16.7.8
Get Auth Info.....
OK
Operation {Remove Icloud Open Menu with BACKUP} ID: D16FEB32E4B74183
Elapsed time 01:08 -- Version 4.7.9 Build 001
Old 07-03-2024, 17:50   #6 (permalink)
Member: 750759
Sonork: 75101010
Thanks Meter: 176
Dear sir game center is off but when i swich it on it ask for apple id password. what can i do
Old 07-03-2024, 18:49   #7 (permalink)
sorry sir this not supported
Page generated in 0.16934 seconds with 8 queries
