06-01-2020, 14:58 | #1 (permalink) |
Freak Poster Join Date: Oct 2014 Location: black house
Member: 2280366 Status: Offline Thanks Meter: 19 | j730f u6 drk problem I changed emmc for this phone and after write dump and full firmware flashing phone not booting and restart at logo . on recovery dm-verity failed.... frp off oem on. I tried make rooted recovery but not worked. tried make boot bypass dm verity but still the same. and phone version is J730FXWU6CTA2_OJV6CTA1. please help me. thanks. |
06-01-2020, 16:40 | #3 (permalink) |
Member: 2280366 Status: Offline Thanks Meter: 19 | |
06-01-2020, 18:17 | #5 (permalink) |
Freak Poster Join Date: Apr 2019 Location: Egypt Age: 25
Member: 2906511 Status: Offline Thanks Meter: 136 | If not work ,find a combination file with same binary and flash it and disable oem .after that flash stock rom and root your device.it should be fine and boot up |
The Following User Says Thank You to safina gsm For This Useful Post: |
06-02-2020, 06:39 | #6 (permalink) | |
Member: 2280366 Status: Offline Thanks Meter: 19 | Quote:
flash it phone get error (pit) and when i flash it without pit file gives custom binary blocked by oem lock... there is no other way?? | |
06-02-2020, 20:01 | #7 (permalink) |
Member: 2906511 Status: Offline Thanks Meter: 136 | flash this file in BL :https://firmware.gsm-social.com/inde...=file&id=11478 AFTER THAT :flash only system from same version in your device post result at any way |
06-03-2020, 15:29 | #8 (permalink) | |
06-05-2020, 16:19 | #9 (permalink) | |
what can i do now? | |
06-07-2020, 22:22 | #12 (permalink) |
Member: 2906511 Status: Offline Thanks Meter: 136 | ok , it's funny question but i must ask did you tried to flash another baseband like : j730fxx instead of j730fxw there is two baseband for this device it's not real solution but i'm trying to help good luck #safina |
