Old 02-16-2021, 13:56   #1 (permalink)
Member: 601566
Sonork: 100.1637134
Thanks Meter: 587
jsn-l22 dongrad failed
Checking fastboot device.....OK
Reading info.....OK
Device Model: JSN-L22
Device Firmware: :JSN-L22 10.0.0.231(C185E3R2P1)
Base Firmware: :JSN-LGRP2-OVS 10.0.0.231
Custom Firmware: :JSN-L22-CUST 10.0.0.3(C185)
Preload Firmware: :JSN-L22-PRELOAD 10.0.0.1(C185R2)
Device FB Lock: LOCKED
Device USER Lock: LOCKED
Device Lock: locked
Operation {Read info} ID: BE1AC6AFD7FCFB53
Elapsed time 00:01 -- Version 3.9.1
Old 02-17-2021, 11:50   #2 (permalink)
Thanks Meter: 21,927
why downgrade ? use test point for frp reset
Old 02-18-2021, 23:59   #3 (permalink)
Member: 601566
Sonork: 100.1637134
Thanks Meter: 587
Searching for upgrade port.....Detected {COM23}
Target model [JSN-L22 10.0.0(C185)]
Reading data from server.....OK
Bypassing downgrade protection.....OK
Rebooting device.....OK
Waiting device to reboot.....OK
- Reboot your device to upgrade mode:
1 - Reboot to recovery by Volume up button
2 - Press on (Update mode)
3 - Press on (USB update mode)
Waiting for upgrade mode device.....OK
Connecting to device.....OK
Start processing file [H:/jsn-l22/JSN-L22 10.0.0(C185) Downgrade For FRP Bypass By EFT Pro (AOD)/step1/A.APP] 4,44 GB:
Flashing [sha256rsa.img].....OK
Flashing [crc.img].....OK
Flashing [base_verlist.img].....OK
Flashing [base_ver.img].....OK
Flashing [package_type.img].....OK
Flashing [hisiufs_gpt.img].....OK
Flashing [xloader.img].....OK
Flashing [fastboot.img].....OK
Flashing [hhee.img].....OK
Flashing [dts.img].....OK
Flashing [trustfirmware.img].....OK
Flashing [fw_lpm3.img].....OK
Flashing [dto.img].....OK
Flashing [kernel.img].....OK
Flashing [teeos.img].....OK
Flashing [isp_firmware.img].....OK
Flashing [vector.img].....OK
Flashing [sensorhub.img].....OK
Flashing [fw_hifi.img].....OK
Flashing [vbmeta.img].....OK
Flashing [modemnvm_update.img].....OK
Flashing [modemnvm_cust.img].....OK
Flashing [recovery_ramdisk.img].....OK
Flashing [recovery_vendor.img].....OK
Flashing [recovery_vbmeta.img].....OK
Flashing [preas.img].....OK
Flashing [preavs.img].....OK
Flashing [erecovery_kernel.img].....OK
Flashing [erecovery_ramdisk.img].....OK
Flashing [erecovery_vendor.img].....OK
Flashing [erecovery_vbmeta.img].....OK
Flashing [eng_vendor.img].....OK
Flashing [eng_system.img].....OK
Flashing [cache.img].....OK
Flashing [system.img].....OK
Flashing [cust.img].....OK
Flashing [modem_fw.img].....OK
Flashing [hisee_img.img].....OK
Flashing [hisee_fs.img].....OK
Flashing [vendor.img].....OK
Flashing [odm.img].....OK
Flashing [product.img].....OK
Flashing [patch.img].....OK
Flashing [userdata.img].....OK
Flashing [version.img].....OK
Flashing [preload.img].....OK
Start processing file [H:/jsn-l22/JSN-L22 10.0.0(C185) Downgrade For FRP Bypass By EFT Pro (AOD)/step1/O.APP] 554 KB:
Flashing [cust_verlist.img].....OK
Flashing [cust_ver.img].....OK
Flashing [ptable_cust.img].....OK
Start processing file [H:/jsn-l22/JSN-L22 10.0.0(C185) Downgrade For FRP Bypass By EFT Pro (AOD)/step1/D.APP] 554 KB:
- Now go to recovery and do factory reset then use (Safe mode)
Operation {Downgrade to reset FRP} ID: 241D006D5E8A5CD7
Elapsed time 10:01 -- Version 3.9.1
Old 02-19-2021, 11:39   #4 (permalink)
You could use test point method in less than a minute and without dead risk !
Page generated in 0.11333 seconds with 8 queries
