11-20-2019, 17:39 | #1 (permalink) |
No Life Poster Join Date: Dec 2013 Location: England Manchester
Member: 2081860 Status: Offline Sonork: 100.1608350 Thanks Meter: 128 | RNE-L21 Reset Screen Lock Remove ??? |
11-20-2019, 22:35 | #2 (permalink) |
Product Manager Join Date: Feb 2016 Location: EFT Dongle
Member: 2536865 Status: Offline Sonork: 100.1584728 Thanks Meter: 21,229 | it is supported via EFT Pro * test point method Requirements For model { RNE-L21 8.0.0 [Test point] }: - Select UPDATE.APP firmware that matches your device version & security - Select the device lockscreen type - Connect Huawei device in USB COM 1.0 mode then press Start |
11-21-2019, 09:30 | #3 (permalink) | |
Member: 2081860 Status: Offline Sonork: 100.1608350 Thanks Meter: 128 | Check Quote:
11-21-2019, 09:35 | #4 (permalink) |
Member: 2081860 Status: Offline Sonork: 100.1608350 Thanks Meter: 128 | Waiting for USB COM 1 port.....Detected {COM40} Connecting to device.....OK Writing data 1.....OK Writing data 3.....OK Rebooting device to fastboot.....OK Reading info.....OK Device Model: RNE-L21 Device Serial: FFYDU18625000068 Device IMEI: 869354038671435 Device IMEI2: 869354038705449 Device Firmware: :RNE-L21 8.0.0.348(C185) Device FB Lock: UNLOCKED Device USER Lock: LOCKED Device Lock: unlocked Processing file 1.....OK Rebooting.....OK Processing file 1.....OK Processing file 2.....OK Processing file 3.....OK Switching to ADB mode.....OK Waiting for device.....OK Rebooting.....OK Waiting for device.....OK Patching.....Failed: can not patch data1 Operation {Reset ScreenLock} ID: 9A4E7D55019FC17828ED01131803C0B2 Elapsed time 03:28 -- Version 1.7.2 No Icon show memory available no image show....nothing |
11-21-2019, 14:45 | #8 (permalink) |
Member: 2081860 Status: Offline Sonork: 100.1608350 Thanks Meter: 128 | Waiting for USB COM 1 port.....Detected {COM9} Connecting to device.....OK Writing data 1.....OK Writing data 3.....OK Rebooting device to fastboot.....OK Reading info.....OK Device Model: RNE-L21 Device Serial: FFYDU18625000068 Device IMEI: 869354038671435 Device IMEI2: 869354038705449 Device Firmware: :RNE-L21 8.0.0.348(C185) Device FB Lock: UNLOCKED Device USER Lock: LOCKED Device Lock: unlocked Processing file 1.....OK Rebooting.....OK Processing file 1.....OK Processing file 2.....OK Processing file 3.....OK Switching to ADB mode.....OK Waiting for device.....Time out - Device not found, Reboot The device to recovery manually - Hold press 'power & volume up' buttons - When bootloader logo appears, Release buttons Waiting for device.....OK Rebooting.....OK Waiting for device.....OK Patching.....Failed: can not patch data1 Operation {Reset ScreenLock} ID: 9A4E7D55019FC17828ED01131803C0B2 Elapsed time 03:46 -- Version 1.7.5 Same problem |
11-22-2019, 14:18 | #11 (permalink) |
Member: 2081860 Status: Offline Sonork: 100.1608350 Thanks Meter: 128 | Connecting to device.....OK Reading device info.....OK Baseband Version: 21C60B269S006C000,21C60B269S006C000 Device selinux: enforcing Android version: 8.0.0 Device SDK: 26 Device data encryption: encrypted Device Hardware: hi6250 Device CPU: arm64-v8a Device Factory: HUAWEI Device Model: RNE-L21 Device IMEI: 869354038671435 Root status.....Not Rooted Checking.....OK Waiting for server.....OK Patching.....OK - This operation may take a long time depending on the complexity of screen lock, PLEASE WAIT Reading data from server.....OK Decrypting..... After Connecting Adb Decrypting Not Working Am Checking at last 8Hrs check...Need Solution Team. |
11-22-2019, 21:15 | #12 (permalink) | |
Member: 2536865 Status: Offline Sonork: 100.1584728 Thanks Meter: 21,229 | Quote:
I already asked for image for device screen ! | |
11-24-2019, 18:53 | #14 (permalink) |
Junior Member Join Date: May 2005 Location: Wrocław Age: 42
Member: 144545 Status: Offline Thanks Meter: 2 | I have the same problem. okay drivers. I wrote to the support on a telegram but for several days no response. the client want kill me. I don't think it was supposed to work like that? all the same as with you. Checking fastboot device.....OK Reading info.....OK Device Model: WAS-LX1 Device Serial: PMF4C17513000662 Device IMEI: 863313035485419 Device IMEI2: 863313035495426 Device Firmware: :WAS-LX1 8.0.0.376(C738) Device FB Lock: LOCKED Device USER Lock: LOCKED Device Lock: locked Waiting for server.....OK Reading data.....OK Posting data to server.....OK Waiting for server response.....OK Unlocking device.....OK Processing file 1.....OK Processing file 1.....OK Processing file 2.....OK Switching to ADB mode.....OK Waiting for device.....OK Rebooting.....OK Waiting for device.....OK Patching.....Failed: can not patch data1 Operation {Reset ScreenLock} ID: 5A92112BE6C5B428C788E254B81A62B4 Elapsed time 02:19 -- Version 1.7.2 |
