12-11-2021, 10:40 | #1 (permalink) |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,369 | N980f rotted and ldu removed by eft pro at first time IMEI REPAIR AND PATCH CERT WORKED FINE BY OTHER TOOL, NOT LOST ROOT ONLY ONE TIME Who say ROOT Not work, is becouse not know "How ro use" Magisk + EFT PRO" After ROOT can Remove LDU Already for "IMEI REPAIR" + "PATCH NETWORK" NOTE: Tested also in Android 11, (G988B, N970F itc...) same procedure, only be carefully, if Lost "ROOT", Just Send in RECOVERY by "EFT PRO" and ROOT Turn Back BR Allumts |
04-11-2022, 12:41 | #2 (permalink) |
No Life Poster Join Date: Aug 2016 Location: A few details about yourself Age: 34
Member: 2612403 Status: Offline Sonork: 100.1575170 Thanks Meter: 131 | Have same problem but when flashing I receive Custom binary (boot) blocked by OEM lock, while OEM unlocking is active on the Developer options. Phone has this old version : Android Version: 10 [QP1A.190711.020] [SDK 29] Build Date: Mon Aug 3 11:45:33 KST 2020 PDA Version: N980FXXU1A T H 3 [august 2020, rev3] Phone Version: N980FXXU1A T H 3 [august 2020, rev3] CSC Version: N980FOXM1A T H 3 [august 2020, rev3] Board Platform: UNIVERSAL990 Any idea |
04-11-2022, 12:50 | #3 (permalink) |
Member: 2612403 Status: Offline Sonork: 100.1575170 Thanks Meter: 131 | Done after this : 2. Turn off your NOTE 20 and make sure it is disconnected from charger or PC/ Laptop. 3. Hold volume up and volume down. While holding them connect your NOTE 20 to PC/ Laptop. When you see warning screen release both keys. 4. You should 3 options. Long press volume up until bootloader unlock prompt appears. Press volume up again to confirm bootloader unlock. I forget that I should do this |
04-11-2022, 17:20 | #4 (permalink) |
Member: 2612403 Status: Offline Sonork: 100.1575170 Thanks Meter: 131 | Now I can unlock bootloader but I can't write firmware because of the famous error: only official binaries are allowed to be flashed How can I overcome this error? because I don't want to increase the BIT number 1 that is now on the phone, any idea ? I can not write even combination file |
