Old 03-29-2021, 11:08   #1 (permalink)
Member: 14423
Thanks Meter: 25
Oppo A93 Formatting Failed ???
Tried on 2 different Pcs and it gives the same error
Any Suggestions ?
File Type: jpg 166228695_125023506257850_2461342174048625490_n.jpg (40.4 KB, 35 views)
Old 03-29-2021, 13:23   #2 (permalink)
Thanks Meter: 16,618
The Following User Says Thank You to easy-team For This Useful Post:
Old 04-01-2021, 10:52   #3 (permalink)
Member: 2080569
Thanks Meter: 2
Please Help! Oppo A93 not connecting to system even after installing drivers, stuck on WAITING FOR MTK PORT.
Old 04-01-2021, 14:45   #4 (permalink)
Arafat Mashaka's Avatar
Member: 750759
Sonork: 75101010
Thanks Meter: 114
Format done but the phone still has FRP Locked can you help me too?
Waiting for server.....OK
Loading files.....OK
Setting up.....OK
Waiting for MTK port.....Detected {COM29}
Switching to Meta Mode.....OK
Waiting for Meta port.....Detected {COM30}
Connecting to Meta port.....OK
Reading info.....OK
Device SDK: 29
Device data encryption: encrypted
Device Hardware: mt6779
Device CPU: arm64-v8a
Device Factory: OPPO
Device Model: CPH2121
Android version: 10
Device Firmware: CPH2121_11_A.19
Executing Erase command.....OK
- Note: if device not entered to recovery and process format automatically then
- Boot to recovery manually and perform factory reset
Operation {Factory Reset META Recovery} ID: 32A1627366DE127A
Elapsed time 00:39 -- Version 3.9.3
The Following User Says Thank You to Arafat Mashaka For This Useful Post:
Old 04-01-2021, 21:42   #5 (permalink)
Setting up.....OK
Reading info.....OK
Device SDK: 29
Android version: 10
This is format process not FRP Sir .
Old 04-02-2021, 09:13   #6 (permalink)
Member: 750759
Sonork: 75101010
Thanks Meter: 114
Thank you sir, is it possible to remove or bypass FRP? If yes can you help me?
Old 04-02-2021, 11:31   #7 (permalink)
Not supported by us sorry !
Old 04-03-2021, 09:47   #8 (permalink)
Member: 750759
Sonork: 75101010
Thanks Meter: 114
I have remove it by dialing this code *#812# and following this stape
https://www.bypassfrpfiles.com/2021/...unlock-google/
Old 04-06-2021, 16:21   #9 (permalink)
Member: 2773558
*#813# english easy theard
Powered by Searchlight © 2021 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Page generated in 0.16863 seconds with 8 queries
