GSMSERVER GSM Shop
Old 03-21-2018, 00:32   #1 (permalink)
Member: 2616438
Thanks Meter: 144
RMM ( Remote Monitoring and Management)
RMM is a new security 2018 level patch introduced by samsung to new devices such as A520 A720 S8 and Note8
So whats new:
RMM is presented in two states
RMM STATE : Prenormal
In this case you are not able to flash any costum made image and you will get an error :
#Only official released binaries are allowed to be flashed#
**Note by this has nothing to do with OEM LOCK even if its off
RMM STATE : Normal
In this case you are free to flash what ever you want.
To change the Prenormal state back to normal you will need to keep the device active for total runtime of 169 hrs without any turn off or restart
The Following User Says Thank You to wadda7o For This Useful Post:
Old 02-20-2019, 20:06   #2 (permalink)
Member: 2436297
Thanks Meter: 26
i have the same problem on a720f is there any other solution?
Old 02-20-2019, 20:56   #3 (permalink)
Thanks Meter: 14,808
You must wait 7 days until rmm state becomes normal
Old 03-06-2019, 04:57   #4 (permalink)
Member: 1957238
Thanks Meter: 62
no need to wait for such a time the solution is easy and straight. after a couple of hours I managed to bypass it on j730gm n root the phone
The Following User Says Thank You to Kukuphilmur For This Useful Post:
Old 03-06-2019, 05:21   #5 (permalink)
Member: 770229
Sonork: 29050
Thanks Meter: 97
dear sir how can we doit ? u have whats app no ?+923324004266
Old 03-12-2019, 21:15   #6 (permalink)
Member: 1957238
Thanks Meter: 62
Is your phone frp off oem off? then if so you are a few minutes out of your problem.
Old 03-13-2019, 07:16   #7 (permalink)
.:D:.'s Avatar
Member: 2561651
Sonork: 100.*******
Thanks Meter: 262
hi, 1st 1 is merical crack,,,,, it,ll solve but in few devices like J701,,,,,
2nd i tested i also bypassed(only 1 time), but its also need time, trick and luck, and most important thing, need your own brain coz its not easy to bypass it in 1st try, so i,m also searching for perfect solution without time waste,
well FRP OEM is easy to OFF bro, but as i mention RMM is hard to change in normal.....
Old 03-13-2019, 08:21   #8 (permalink)
Member: 1957238
Thanks Meter: 62
Try this write eng boot for that model then write twrp
Sent from my SM-A510F using Tapatalk
Page generated in 0.25477 seconds with 7 queries
