Old 11-20-2019, 17:39   #1 (permalink)
AhsanNawaz's Avatar
Member: 2081860
Sonork: 100.1608350
Thanks Meter: 120
Post RNE-L21 Reset Screen Lock Remove ???
Who Can Remove Screen Lock Remove With Out Data Lose ..............Am lose 4 6 Phone Data Lose No recovery .......What Option Working??? In Screen Lock Reset????
Old 11-20-2019, 22:35   #2 (permalink)
Thanks Meter: 16,482
it is supported via EFT Pro * test point method
Requirements For model { RNE-L21 8.0.0 [Test point] }:
- Select UPDATE.APP firmware that matches your device version & security
- Select the device lockscreen type
- Connect Huawei device in USB COM 1.0 mode then press Start
Old 11-21-2019, 09:30   #3 (permalink)
AhsanNawaz's Avatar
Member: 2081860
Sonork: 100.1608350
Thanks Meter: 120
Post Check
yes Sir M already try this method....after reboot adb not connect.....my drivers ok
Old 11-21-2019, 09:35   #4 (permalink)
AhsanNawaz's Avatar
Member: 2081860
Sonork: 100.1608350
Thanks Meter: 120
Waiting for USB COM 1 port.....Detected {COM40}
Connecting to device.....OK
Writing data 1.....OK
Writing data 3.....OK
Rebooting device to fastboot.....OK
Reading info.....OK
Device Model: RNE-L21
Device Serial: FFYDU18625000068
Device IMEI: 869354038671435
Device IMEI2: 869354038705449
Device Firmware: :RNE-L21 8.0.0.348(C185)
Device FB Lock: UNLOCKED
Device USER Lock: LOCKED
Device Lock: unlocked
Processing file 1.....OK
Rebooting.....OK
Processing file 2.....OK
Processing file 3.....OK
Switching to ADB mode.....OK
Waiting for device.....OK
Rebooting.....OK
Patching.....Failed: can not patch data1
Operation {Reset ScreenLock} ID: 9A4E7D55019FC17828ED01131803C0B2
Elapsed time 03:28 -- Version 1.7.2
No Icon show memory available no image show....nothing
Old 11-21-2019, 12:41   #5 (permalink)
http://forum.gsmhosting.com/vbb/f101...emove-2705090/
Old 11-21-2019, 13:12   #6 (permalink)
AhsanNawaz's Avatar
Member: 2081860
Sonork: 100.1608350
Thanks Meter: 120
this drivers not run in our system ????????
Old 11-21-2019, 13:40   #7 (permalink)
princemeedo's Avatar
Member: 2737570
Thanks Meter: 116
Bro when u double click on it no setup show its going on background u can not notice the installation wait for 3 min then double click again done .
Sent from my iPhone using Tapatalk
The Following User Says Thank You to princemeedo For This Useful Post:
Old 11-21-2019, 14:45   #8 (permalink)
AhsanNawaz's Avatar
Member: 2081860
Sonork: 100.1608350
Thanks Meter: 120
Waiting for USB COM 1 port.....Detected {COM9}
Reading info.....OK
Rebooting.....OK
Waiting for device.....Time out
- Device not found, Reboot The device to recovery manually
- Hold press 'power & volume up' buttons
- When bootloader logo appears, Release buttons
Rebooting.....OK
Elapsed time 03:46 -- Version 1.7.5
Same problem
Old 11-21-2019, 15:18   #9 (permalink)
AhsanNawaz's Avatar
Member: 2081860
Sonork: 100.1608350
Thanks Meter: 120
No Adb Connecting After update!!!!!!!!
Old 11-21-2019, 19:06   #10 (permalink)
provide screen shot for the device interface please .
Old 11-22-2019, 14:18   #11 (permalink)
AhsanNawaz's Avatar
Member: 2081860
Sonork: 100.1608350
Thanks Meter: 120
Reading device info.....OK
Baseband Version: 21C60B269S006C000,21C60B269S006C000
Device selinux: enforcing
Android version: 8.0.0
Device SDK: 26
Device data encryption: encrypted
Device Hardware: hi6250
Device CPU: arm64-v8a
Device Factory: HUAWEI
Root status.....Not Rooted
Checking.....OK
Waiting for server.....OK
Patching.....OK
- This operation may take a long time depending on the complexity of screen lock, PLEASE WAIT
Reading data from server.....OK
Decrypting.....
After Connecting Adb Decrypting Not Working Am Checking at last 8Hrs check...Need Solution Team.
Old 11-22-2019, 21:15   #12 (permalink)
Device SDK: 26
Checking.....OK
Patching.....OK
Decrypting.....
I already asked for image for device screen !
Old 11-23-2019, 08:39   #13 (permalink)
AhsanNawaz's Avatar
Member: 2081860
Sonork: 100.1608350
Thanks Meter: 120
Old 11-24-2019, 18:53   #14 (permalink)
Member: 144545
I have the same problem. okay drivers. I wrote to the support on a telegram but for several days no response. the client want kill me. I don't think it was supposed to work like that?
all the same as with you.
Checking fastboot device.....OK
Reading info.....OK
Device Model: WAS-LX1
Device Serial: PMF4C17513000662
Device IMEI: 863313035485419
Device IMEI2: 863313035495426
Device Firmware: :WAS-LX1 8.0.0.376(C738)
Device FB Lock: LOCKED
Device Lock: locked
Reading data.....OK
Posting data to server.....OK
Waiting for server response.....OK
Unlocking device.....OK
Rebooting.....OK
Operation {Reset ScreenLock} ID: 5A92112BE6C5B428C788E254B81A62B4
Elapsed time 02:19 -- Version 1.7.2
Old 11-24-2019, 22:38   #15 (permalink)
Contact me on telegram +963958244977
The Following User Says Thank You to easy-team For This Useful Post:
Powered by Searchlight © 2021 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Page generated in 0.20660 seconds with 8 queries
