![]() | #1 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Apr 2011
Member: 1552610 Status: Offline Sonork: 100.1604734 Thanks Meter: 1,370 | ![]() team any solution Opening Port COM10...........OK Verifying Download Mod OK Initialization.......OK Reading Phone Partitation Table........OK Partition Size : 8192 Unpak pit .......OK FLASHING FIRMWARE TO PHONE..... Writing: recovery.img.......OK FLASHING Patch........OK FLASHING DONE! Rebooting PDA TO NORMAL MODE...... ERROR : phone unable to accept data, wrong command sent..OK |
![]() | #2 (permalink) |
Member: 1552610 Status: Offline Sonork: 100.1604734 Thanks Meter: 1,370 | detailed solution plz i have done s7 edge before but s8+ not flashing eft patched recovery i have stock recovery matched with firmware in the phone |
![]() | #3 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Aug 2016
Member: 2616438 Status: Offline Thanks Meter: 147 | Can you post the state of the oem lock in download mode. If oem is on even if frp off you still cant flash any costum made image |
The Following User Says Thank You to wadda7o For This Useful Post: |
![]() | #6 (permalink) |
Member: 1552610 Status: Offline Sonork: 100.1604734 Thanks Meter: 1,370 | model number g955f samsung/dream21texx/dream21lte 7.0/nrd90m/g955fxxu1aql5 in recovery mode i downloaded the same file then flashed the phone without user data file then make recovery and successfully patched via eft but when i flash eft patched recovery then ERROR : phone unable to accept data, wrong command sent |
![]() | #7 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Jan 2018
Member: 2802156 Status: Offline Thanks Meter: 173 | flash eng root and usb adb commands NOTE: if secure startup turned on cannot bypass that, as far as I know atleast message me on skype will help you out if you need assistance, but not free http://eng-root.firmware.ir/sm-g955f/ |
![]() | #8 (permalink) | |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Dec 2014
Member: 2309595 Status: Offline Thanks Meter: 112 | Quote:
I confirm this method work fine. Use ENG Root/Boot to active ADB then Use Gtalk command to remove screen lock. Also if the secure startup pop up then you only can use hacked recovery to remove the whole thing but keep the data. This method is risky because it can wept the whole thing. AND THIS IS NOT ALWAYS SUCCESS | |
The Following User Says Thank You to matthew.ebay For This Useful Post: |
![]() | #9 (permalink) |
Product Manager ![]() ![]() ![]() ![]() ![]() Join Date: Feb 2016 Location: EFT Dongle
Member: 2536865 Status: Offline Sonork: 100.1584728 Thanks Meter: 22,469 | As long as OEM is on then you cannot flash any custom recovery or kernel so it is not supported by EFT Dongle, you can follow users experiences in this field ! But we take no responsibility for any damage ! |
The Following User Says Thank You to easy-team For This Useful Post: |
![]() | #10 (permalink) |
Member: 2616438 Status: Offline Thanks Meter: 147 | Eng root may silve your problem but you should take into consideration that eng root should be of the same build as device firmware or it will not boot up and be aware of the reset pop up screen of decryption fail |
