03-15-2019, 07:05 | #16 (permalink) | |
No Life Poster Join Date: Apr 2016
Member: 2561651 Status: Offline Sonork: 100.******* Thanks Meter: 292 | Quote:
The Following User Says Thank You to .:D:. For This Useful Post: |
04-03-2019, 13:35 | #17 (permalink) |
Junior Member Join Date: Jul 2008 Location: Faisalabad
Member: 806294 Status: Offline Thanks Meter: 32 | N950f MDM Done. N950F 9.0 Remove mdm samsung remove knox samsung Done. With EFT Dongle |
The Following User Says Thank You to SAJID338 For This Useful Post: |
04-03-2019, 16:02 | #18 (permalink) |
Product Manager Join Date: Feb 2016 Location: EFT Dongle
Member: 2536865 Status: Offline Sonork: 100.1584728 Thanks Meter: 21,230 | Unfortunately Devices not going into Download Mode not supported by us yet . |
The Following User Says Thank You to easy-team For This Useful Post: |
04-05-2019, 08:56 | #22 (permalink) |
Freak Poster Join Date: Jun 2016 Location: New ****** U.S.A
Member: 2590666 Status: Offline Thanks Meter: 130 | Just leave the phone 7 days without turning off and the prenormal state will change to normal state. |
The Following User Says Thank You to yonic69 For This Useful Post: |
06-26-2019, 11:45 | #25 (permalink) |
No Life Poster Join Date: Nov 2004 Location: USA
Member: 92260 Status: Offline Thanks Meter: 843 | S10 FRP + MDM + User Lock I have an S10 which has all 3 locks on at the same time 1. FRP 2. MDM (RAC) 3. User lock So, starting with the S10 series the MDM security locks out both download and upload modes, including the following AT commands on the USB-Modem port: AT+FUS? AT+SUDDLMOD=0,0 After the above commands the phone turns off trying to go into download mode but MDM prevents it. But at least they provide enough delay right after bootup and before the MDM popping up to allow quickly going into Settings > Lock Screen > Screen Lock Type > None (of course must know your lock code) There are a bunch of other AT commands which seem to work on the USB-Modem port, but none of them are too useful to unlock MDM: AT+AIRPLANEVALUE? AT+BATGETLEVEL? AT+CIMI AT+DEVCONINFO - Long info AT+DLMODE - ?? AT+FACTORST=0,0 - Factory reset AT+FUS? - DL mode AT+GSN - IMEI AT+IMEINUM AT+SERIALNO AT+SIZECHECK - Storage info AT+SIZECHECK=1,0 - Storage info AT+SUDDLMOD=0,0 AT+SVCIFPGM=1,1 - Short Info AT+SWDLMODE - ?? AT+SWVER=1,0 - DL mode AT+SWVERSION=1,0 AT+SYSSCOPE=1,0 AT+WPROTECT=1,0 The only mode that works is recovery (unfortunately not much can be done there), and the USB-Modem port which accepts AT commands, including encrypted challenge-respose lock commands which need to be calculated by a server. Here's the log of the FRP unlock via server, after which I was able to activate ADB but not OEM Unlock or download mode: Open Usb Port - PASS Detected Testing - PASS Read phone info.... Model Name : SM-G973F Customer Code : TTT S/W version : G973FXXU1ASE7 Unique Number : CE11182BF3538932xxxx Serial Number : R28M30xxxx Imei Number : 35463410028xxxx Check Unlock Status - TRIGGERED Start Clear Process Please waiting ... DBMS Get RandomKey... OK DBMS Calculation RSAKey... OK Finished - Successfully Check Unlock Status - UNLOCK So, still can't turn on OEM Unlock (grayed out), and can't enter download mode to flash an eng-boot/combination in order to erase the security partitions (persdata, persist, persistent, aboot-sec, etc) Samsung may have some special resistor values or a special jig which could kick the phone into download mode, but I haven't found anything working along those lines. |
The Following 6 Users Say Thank You to BillA For This Useful Post: |
06-28-2019, 05:29 | #26 (permalink) | |
No Life Poster Join Date: Feb 2006 Location: Sri Lanka@cellularsolutions
Member: 230004 Status: Offline Thanks Meter: 174 | Quote:
The Following User Says Thank You to gayansuranga For This Useful Post: |
06-29-2019, 02:35 | #27 (permalink) |
Freak Poster Join Date: Sep 2017 Location: merida, yucatan
Member: 2754756 Status: Offline Thanks Meter: 37 | New MDM security no dowload, no at comands, no 15 failes attemps of patternlock. Solution is JTAG only 100% tested on EMMC devices, and someday UFS. Enviado desde mi SM-A505G mediante Tapatalk |
The Following 2 Users Say Thank You to Krlozv94 For This Useful Post: |
07-12-2019, 00:36 | #30 (permalink) |
Registered User Join Date: Aug 2007 Location: United Kingdom
Member: 567838 Status: Offline Thanks Meter: 64 | For the procedure to remove MDM using EFT 1. What is the definition of boot image to make kernel Please explain what file to use , stock rom ,combination file 2. Is EFT pro generated automatically or you have to create Or download from somewhere Please can you explain so I have better understanding thank you |
The Following User Says Thank You to MORRISGSM For This Useful Post: |
