09-12-2017, 22:04 | #1 (permalink) |
Freak Poster Join Date: Feb 2010 Location: turkey\bayburt
Member: 1232935 Status: Offline Thanks Meter: 15 | t889 translate language (solved) |
09-13-2017, 20:19 | #3 (permalink) |
Member: 1232935 Status: Offline Thanks Meter: 15 | https://i.hizliresim.com/vJoYG6.png first one is not show phone second one show phone but after press R can not press others https://i.hizliresim.com/OydJ6Z.png |
09-13-2017, 22:05 | #4 (permalink) |
Product Manager Join Date: Feb 2016 Location: EFT Dongle
Member: 2536865 Status: Offline Sonork: 100.1584728 Thanks Meter: 21,402 | Bro in second one phone is connected successfully , Why u Press R after connecting to phone ?! You Press R just to see phone and Connect , if u are connected to a phone then no need to press R any more! |
09-14-2017, 09:12 | #7 (permalink) |
Member: 2536865 Status: Offline Sonork: 100.1584728 Thanks Meter: 21,402 | Make Sure you installed Java and net.frame work 3.5 or above . Also install Visual c++ redistributable 2015 |
The Following User Says Thank You to easy-team For This Useful Post: |
09-14-2017, 21:55 | #8 (permalink) |
Member: 1232935 Status: Offline Thanks Meter: 15 | [QUOTE=easy-team;12685549]Make Sure you installed Java and net.frame work 3.5 or above . Also install Visual c++ redistributable everythin is ok but still same problem ı will give phones back to customer thanks sir for help |
09-14-2017, 22:43 | #9 (permalink) |
Member: 2536865 Status: Offline Sonork: 100.1584728 Thanks Meter: 21,402 | Even if u give phones to dealer , plz contact us on facebook page so we can use team viewer to solve ur problem ! Facebook.com/eftdongle |
09-15-2017, 22:33 | #10 (permalink) |
Member: 1232935 Status: Offline Thanks Meter: 15 | sir ı solved my problem after flashing true root frimware thanks again... https://i.hizliresim.com/8N9mnn.png |
09-16-2017, 13:11 | #11 (permalink) | |
No Life Poster Join Date: Feb 2016 Location: Europe
Member: 2536614 Status: Offline Thanks Meter: 2,785 | Quote:
BR, Mohamed Aamri | |
The Following User Says Thank You to Mohammed Aamri For This Useful Post: |
