03-27-2020, 11:49 | #1 (permalink) |
No Life Poster Join Date: Apr 2017 Location: SYRIA
Member: 2706092 Status: Offline Thanks Meter: 1,560 | STK-L21MDV 10.0.0(C185) Downgread And Remove Frp By EFT Pro STK-L21MDV 10.0.0(C185) Downgread And Remove Frp By EFT Pro Firmware*download here https://easy-firmware.com/index.php?...file&id=260115 Follow the instructions as in the picture: STEP1 Open eft pro and go to flash / flash multi app files .. Flashing 1 2 3 APP in step1 folder BY EFT PRO In Downgrade mode After Flashing Make Safe Mode And install keyboard or connect keyboard and Connect Internet And go to developer opthion and enable oem and make reset for phone.. STEP2 Go To Flash and select multi flash And go step2 folder. Select 1.APP 2.APP 3.APP And Connect Upgrade mode and start flashing .. Congratulations EasyFirmware Team Requirements For { Downgrade to reset FRP (Upgrade Mode) }: - Select your device model & cust - Select 'A & O & D' firmwares - Connect device in upgrade mode and start |
The Following 2 Users Say Thank You to OBEDAKHARAT@EFT For This Useful Post: |
03-12-2021, 21:29 | #3 (permalink) |
Product Manager Join Date: Feb 2016 Location: EFT Dongle
Member: 2536865 Status: Online Sonork: 100.1584728 Thanks Meter: 22,092 | A problem occurred in one of the hosting companies that we use for a large amount of our files in the Easy Firmware and FTP dongle, and this led to the loss of all files hosted on the company's servers, including our files, so you may notice the disappearance of some files previously exists in the site & Dongle. Note that we have started to re-download and upload all the lost files to solve this problem, but this matter may take a period of time. Thank you for your understanding |
03-14-2021, 00:21 | #4 (permalink) | |
Insane Poster Join Date: Jan 2020 Location: Aljeria
Member: 2943348 Status: Offline Thanks Meter: 28 | Quote:
03-31-2021, 08:11 | #5 (permalink) |
Junior Member Join Date: Nov 2009 Location: Swabi pakistan
Member: 1158785 Status: Offline Thanks Meter: 8 | Stk-l21mdv 10.0.0(c185) frp Searching for upgrade port.....Detected {COM21} Target model [STK-L21MDV 10.0.0(C185)] Reading data from server.....OK Bypassing downgrade protection.....Failed: writing failed, Please contact support team Operation {Downgrade to reset FRP} ID: 7AD3C91F7D69D78B Elapsed time 00:03 -- Version 3.9.3 |
03-31-2021, 08:59 | #6 (permalink) | |
Member: 2536865 Status: Online Sonork: 100.1584728 Thanks Meter: 22,092 | Quote:
If your device is 10.0 then check This Tutorial | |
03-31-2021, 09:34 | #7 (permalink) |
Member: 1158785 Status: Offline Thanks Meter: 8 | Checking fastboot device.....OK Reading info.....OK Device Model: STK-L21 Device Firmware: :STK-L21MDV 10.0.0.366(C185E6R2P1) Base Firmware: :STK-LGRP3-OVS 10.0.0.366 Custom Firmware: :STK-L21MDV-CUST 10.0.0.6(C185) Preload Firmware: :STK-L21MDV-PRELOAD 10.0.0.1(C185R2) Device FB Lock: LOCKED Device USER Lock: LOCKED Device Lock: locked Operation {Read info} ID: 6C3780925F38E434 Elapsed time 00:00 -- Version 3.9.3 downloaded firmware from here https://easy-firmware.com/index.php?...file&id=260115 STK-L21MDV 10.0.0(C185) Downgrade For FRP Bypass By EFT Pro (AOD) |
03-31-2021, 09:49 | #8 (permalink) |
Member: 1158785 Status: Offline Thanks Meter: 8 | when try to flash using multi app upgrade mode Searching for upgrade port.....Detected {COM21} Connecting to device.....OK Start processing file [F:/Huawei/STK-L21MDV/STK-L21MDV 10.0.0(C185) Downgrade For FRP Bypass By EFT Pro (AOD)/STK-L21MDV 10.0.0(C185) Downgrade For FRP Bypass By EFT Pro (AOD)/STEP1/A.APP] 3,80 GB: Flashing [sha256rsa.img].....OK Flashing [crc.img].....OK Flashing [base_verlist.img].....OK Flashing [base_ver.img].....Failed: Write failed Operation {Flash multi APP files} ID: 10B7923664F7902A Elapsed time 00:16 -- Version 3.9.3 |
