Old 06-27-2023, 10:55   #1816 (permalink)
Thanks Meter: 21,539
Originally Posted by awais ali007 View Post
iphone x 16.5 icloud bypass error
pleas do some thing am stuck here minimum 2 weeks.
Checking iDevices.....OK
Reading iDevice info.....OK
Activation Status: Unactivated
BuildVersion: 20F66
CPU Arch: arm64
Device Class: iPhone
Device Name: iPhone
Firmware Version: iBoot-8422.120.66
Device IMEI: 356726086175502
Device MEID: 35672608617550
Product Name: iPhone OS
Product Type: iPhone X Global
IOS Version: 16.5
SIM Status: kCTSIMSupportSIMStatusNotInserted
Device Serial Number: F17LTC4YFFDQ
DeviceID: 4ca1e93e8d79a3fa5053e54aa458145b48ac3464
MEID Status: Supported
Preparing Hello....Waiting for server.....OK
Generating Activation Files....SERVER-ERROR: Error transferring https://tools.eftpro.es-dongle.com/H...4/IC-Info.sisv - server replied: Not Found(IC-Info.sisv)
Failed
Operation {Hello Screen: Generate Activation files ios 15.x/16.x} ID: 43FEE61B1B80A663
Elapsed time 00:04 -- Version 4.4.8 Build 005
There are some modifications and repair of internet servers that need some time, about 24 hours, and they are finished
Old 06-27-2023, 10:56   #1817 (permalink)
awais ali007's Avatar
Member: 2158722
Sonork: 1668812
Thanks Meter: 39
https://ibb.co/GR4csRS
Old 06-27-2023, 10:56   #1818 (permalink)
Member: 2158722
Sonork: 1668812
Thanks Meter: 39
Old 06-27-2023, 10:57   #1819 (permalink)
Member: 2158722
Sonork: 1668812
Thanks Meter: 39
thnx for good responce but am so happy to see your reply
Old 06-27-2023, 11:55   #1820 (permalink)
Member: 1677653
Thanks Meter: 2,769
Samsung m11 frp reset done
Searching for Qualcomm 9008 port.....Detected {COM39}
Loading Programmer.....OK
Setting up.....OK
Reading hardware info.....OK
Serial number: 0x5435ac00
Hardware ID: 0x0009a0e1
OEM Private key: 0x11ac510c97c59fad3c04611b6affd671a9a60a53e35bbaec aa55a985cc21f07d
Software version: 0x00000001
Sending programmer.....OK
Reading partitions.....OK
Reading prop info.....OK
Device Firmware: SP1A.210812.016.M115FXXU3CVF6
Device SDK: 31
Android version: 12
Device CPU: armeabi-v7a
Device Firmware: M115FXXU3CVF6
Device Factory: samsung
Resetting FRP.....OK
Rebooting device.....OK
Operation {Reset FRP} ID: E776F3F98920D074
Elapsed time 00:28 -- Version 4.4.8 Build 005
The Following User Says Thank You to Yusuf Lawal For This Useful Post:
Old 06-27-2023, 20:23   #1821 (permalink)
Khan Bhaie's Avatar
Member: 2276949
Thanks Meter: 160
Iphone XR IOS 16 MDM Remove Done
Preparing paths.....OK
Setting up.....OK
Activation Status: Activated
BuildVersion: 20D67
CPU Arch: arm64e
Device Name: iPhone
Firmware Version: iBoot-8419.82.1
Device IMEI: 35xxxxxxxxx72
Device MEID: 35xxxxxxxx7
Product Type: iPhone XR
IOS Version: 16.3.1
SIM Status: kCTSIMSupportSIMStatusReady
Device Serial Number: C6KYF1SEKXKR
DeviceID: 00008020-001E25110A09002E
Preparing.....OK
Reading Data.....OK
Patching.....OK
Bypassing.....OK
Operation {Bypass MDM}
Elapsed time 00:58 -- Version 4.4.8 Build 005
Old 07-04-2023, 08:40   #1822 (permalink)
Member: 2175688
BuildVersion: 16H71
CPU Arch: arm64
Device Class: iPad
Device Name: iPad
Firmware Version: iBoot-4513.270.14
Device IMEI: 351977063525277
Device MEID: 35197706352527
Product Type: iPad Air (GSM+CDMA)
IOS Version: 12.5.6
Device Serial Number: DMPMQ29ZF4YD
DeviceID: e5dea5aea2e30fbc7a81dee7880f0f4d431a2124
Checking SSH......Checking SSH......P:14..OK
Preparing device......OK
IDevicePair...Mount......OK
Find Activations......OK
Delete Previous Activations...OK
Snappy Starting!......OK
Restart Lockdown!......OK
iDevicePair......OK
Checking Server......Checking Server......Checking Server......Checking Server......Checking Server.........OK
Download Activations...OK
Create Activations.....FAIL!...FAIL!...FAIL!...FAIL!...OK
Upload Activation Files ......1....2....3....4.....OK
Operation {Bypass iCloud GSM With Signal Up 14.5} ID: E35BAA2B9B95120A
Elapsed time 01:17 -- Version 4.4.8 Build 005
Old 07-07-2023, 18:14   #1823 (permalink)
Member: 2612403
Sonork: 100.1575170
Thanks Meter: 108
Asus ZenFone Max M1 ZB555KL X00PD FRP reset with the almighty EFT
Searching for Qualcomm 9008 port.....Detected {COM4}
Setting up.....OK
Serial number: 0x8bb83a51
Hardware ID: 0x000560e1
OEM Private key: 0xfbd4de360136046bbf581dc5eff178e1f716188e6834da71 4e485695230d00f3
Software version: 0x00000000
Device SDK: 26
Android version: 8.0.0
Device Factory: asus
Device CPU: arm64-v8a
Device Firmware: WW_Phone-15.00.2007.122-20200618
Operation {Reset FRP} ID: 7BBD4E6A1A64EB40
Elapsed time 00:13 -- Version 4.4.9 Build 001
The Following User Says Thank You to byteforce2016 For This Useful Post:
Old 07-11-2023, 12:13   #1824 (permalink)
genci titi 2002's Avatar
Member: 193804
Sonork: 100.1684818
Thanks Meter: 1,710
Wink SM-J415FN Resetting FRP.....OK
Connecting to device.....OK
Reading device info.....OK
Baseband Version: J415FNXXU6BUC1,J415FNXXU6BUC1
Serial Number: R58M31ZVA8T
Device Arch: msm8937_32
Device bootloader: J415FNXXS6BVJ1
Device selinux: permissive
Device warranty bit: 0
Device Firmware: J415FNXXS6BVJ1
Android version: 9
Device SDK: 28
Device data encryption: encrypted
Firmware Country: Greece
Device Hardware: qcom
Device Model: SM-J415FN
Device IMEI: 355866105503101
Root status.....Not Rooted
Operation {Remove FRP Direct} ID: 1A66DECFEF0100A4
Elapsed time 00:56 -- Version 4.4.9 Build 001
Old 07-11-2023, 16:09   #1825 (permalink)
Member: 2157664
Thanks Meter: 43
Originally Posted by marcin7904 View Post
And after that with what method did you reset or bypassed the frp?
Old 07-12-2023, 14:26   #1826 (permalink)
Member: 193804
Sonork: 100.1684818
Thanks Meter: 1,710
Wink SM-A515F Resetting FRP.....OK
Baseband Version: A515FXXU5FVG3,A515FXXU5FVG3
Device Arch: exynos9610
Device bootloader: A515FXXS5FVI2
Device selinux: enforcing
Device Firmware: A515FXXS5FVI2
Android version: 12
Device SDK: 31
Firmware Country: Germany
Device Hardware: exynos9611
Device Model: SM-A515F
Device IMEI:
Operation {Remove FRP Direct} ID: BC88D1B86F570F29
Elapsed time 00:58 -- Version 4.4.9 Build 001
The Following User Says Thank You to genci titi 2002 For This Useful Post:
Old 07-14-2023, 09:03   #1827 (permalink)
Member: 1034743
Sonork: 100.1619212
Thanks Meter: 193
spark 10c reset done tnx eft
problem Tecno id not remove without password
report good
Waiting For Device Connection.....OK
USB PORT: SPRD U2S Diag (COM8)
Port: SPRD U2S Diag (COM8)
OPEN COM PORT......OK
Handshake...OK
Enter Diag Mode......OK
Waiting For Device Connection......OK
USB PORT: (COM8)
Handshake...OK
Read Device Info......OK
Platform Version:MOCORTM_22A_W22.43.4_P20_Debug
Project Version:qogirl6_pub
BASE Version:4G_MODEM_22A_W22.43.4_P20
HW Version:qogirl6_modem
05-12-2023 11:00
Ap Version:KI5k-F065ABCDEAgAh-S-GL-20230614V447
Search Userdata Partition......OK
Format Userdata Partition......OK
Operation {Factory Reset} ID: 39B90CDB07BB67B4
Elapsed time 00:31 -- Version 4.4.9 Build 001
The Following User Says Thank You to shaongsm For This Useful Post:
Old 07-15-2023, 13:39   #1828 (permalink)
Member: 193804
Sonork: 100.1684818
Thanks Meter: 1,710
Wink ASUS_X008D Resetting frp.....OK
Setting up.....OK
Loading files.....OK
Waiting for MTK port.....Detected {COM114}
Connecting to Brom.....OK
Sending DA.....OK
Chip name: MT6737M
Device Firmware: NRD90M.WW_Phone-14.10.1808.119-20180803
Device SDK: 24
Android version: 7.0
Device Model: ASUS_X008D
Operation {Reset FRP} ID: CCE63F9BE033B20E
Elapsed time 00:37 -- Version 4.4.9 Build 001
Old 07-19-2023, 13:51   #1829 (permalink)
Member: 2605244
Originally Posted by FullFlash™ View Post
Huawei Mediapad T3 KOB-L09
tab cannot remove via manual
done EFT
Checking fastboot device.....OK
Reading info.....OK
Device Model: KOB-L09
Device Serial: WBM4T17705000069
Device IMEI: 864004032074780
Device Firmware: KOB-L09C199B280
Device Lock: Image is origin | Verify mode is enforcing | Check root info is safe | Lock state is lock | Root State: UNROOT
Reading data.....OK
Posting data to server.....OK
Waiting for server response.....OK
Unlocking device.....OK
Operation {Reset FRP using server} ID: 6CC6EF49DE710AE1
Elapsed time 00:10 -- Version 2.5
Hi mate hope your doing well , please I badly need a firmware for this model its on bootloader lock but bootloop cant enter isnide its system anymore.
Old 07-23-2023, 10:40   #1830 (permalink)
marcin7904's Avatar
Member: 290272
Thanks Meter: 435
https://www.youtube.com/watch?v=1Z2g...st=WL&index=23
Page generated in 0.12706 seconds with 9 queries
