Old 06-14-2024, 09:49   #1936 (permalink)
Member: 87364
Thanks Meter: 69
Samsung A325F U8 FRP OK by TestPoint:
Waiting For Device Connection...
USB PORT: MediaTek USB Port (COM3)
Port: MediaTek USB Port (COM3)
Manufacturer: MediaTek Inc.
OPEN COM PORT... OK
Handshake... OK
Waiting for server........ OK
Read CHIP ID... OK
HW-CODE: 0X707
CPU: MT6768
Read Chip Version... OK
HW-SUBCODE: 0X8A00
HW-VERSION: 0XCA00
SW-VERSION: 0X0000
Read Phone Configuration... OK
Bypass Security Protection... OK
Dump EMI Config... OK
Send Protection Files BROM... OK
Check BROM status... OK
Setup DEVICE... OK
Init HARDWARE... OK
Setup DEVICE... OK
Read DEVICE Status... BROM
Init EXT RAM... OK
Send Download Agent... OK
Send Download Agent Extended... OK
Read Device Info... OK
EMMC INFO:
EMMC Boot1 Size: 4.00 MB
EMMC Boot2 Size: 4.00 MB
EMMC RPMB Size: 16.00 MB
EMMC USER Size: 116.48 GB
EMMC CID: 150100445636444142008724BE71383D
RAM INFO:
SRAM Size: 448.00 KB
DRAM Size: 4.00 GB
CHANGE TO HIGH-SPEED PORT... OK
Server ... OK
Get Partition ... OK
Read Build Prop Info... OK
Brand: SAMSUNG
Model: SM-A325F
Product: A32XX
Manufacturer: SAMSUNG
Android Version: 13
Security Patch: 2024-05-01
Build ID: TP1A.220624.014
Build Date: THU MAY 16 16:05:17 KST 2024
Display ID: TP1A.220624.014.A325FXXS8DXE5
Build: A325FXXS8DXE5
Read Internal Storage Info... OK
USERDATA: 107.37 GB
USERDATA: ENCRYPTED
Prepare data... OK
RESET FRP... OK
Finalize... OK
Reboot... OK
Elapsed Time: 28 secs, 698 msecs
The Following User Says Thank You to rgsm For This Useful Post:
Old 06-22-2024, 17:58   #1937 (permalink)
KYEJUSA's Avatar
Member: 394869
Sonork: TAKE NO CHANCES
Thanks Meter: 515
NOKIA C31 FRP REMOVED:
USB PORT: SPRD U2S Diag (COM22)
Port: SPRD U2S Diag (COM22)
Manufacturer: UNISOC Communications Inc.
OPEN COM PORT... OK
Handshake NAND_FDL... OK
Boot version: SPRD3
Sending payload... OK
Sending preloader... OK
Sending nand_fdl loader... OK
Brand: NOKIA
Model: NOKIA C31
Product: VISION_00WW
Manufacturer: HMD GLOBAL
Android Version: 12
Security Patch: 2023-12-05
Build ID: SP1A.210812.016
Build Date: MON JAN 15 09:48:19 UTC 2024
Display ID: 00WW_1_340
Build: 00WW_1_340
USERDATA: 50.01 GB
USERDATA: ENCRYPTED
RESET FRP... OK
Rebooting... OK
Elapsed Time: 21 secs, 36 msecs
The Following 2 Users Say Thank You to KYEJUSA For This Useful Post:
Old 06-25-2024, 14:02   #1938 (permalink)
pichi_balea's Avatar
Member: 668010
Thanks Meter: 118
motorola e13 frp ok (test point)
USB PORT: SPRD U2S Diag (COM45)
Port: SPRD U2S Diag (COM45)
OPEN COM PORT... OK
Boot version: SPRD3
Read Build Prop Info... FAIL
[FS ERR] FAILED TO MOUNT /PRODUCT_A/
USERDATA: 52.27 GB
USERDATA: ENCRYPTED
RESET FRP... OK
Rebooting... OK
Elapsed Time: 19 secs, 1 msec
The Following User Says Thank You to pichi_balea For This Useful Post:
Old 06-29-2024, 18:43   #1939 (permalink)
KYEJUSA's Avatar
Member: 394869
Thanks Meter: 515
CAMON 15 PREMIER FORMAT AND FRP DONE:
USB PORT: MediaTek USB Port_V1633 (COM4)
Port: MediaTek USB Port_V1633 (COM4)
OPEN COM PORT... OK
Handshake... OK
Read CHIP ID... OK
HW-CODE: 0X766
CPU: MT6765
HW-SUBCODE: 0X8A00
HW-VERSION: 0XCA00
SW-VERSION: 0X0000
Setup DEVICE... OK
Init HARDWARE... OK
Setup DEVICE... OK
Init EXT RAM... OK
EMMC INFO:
EMMC CID: 90014A68444561503303006677E06721
RAM INFO:
SRAM Size: 224.00 KB
DRAM Size: 6.00 GB
Server ... OK
Brand: TECNO
Model: TECNO CD8J
Product: CD8J-OP
Manufacturer: TECNO MOBILE LIMITED
Android Version: 10 (Android 10)
Security Patch: 2021-03-05
Build ID: QP1A.190711.020
Build Date: SAT MAR 13 11:25:19 CST 2021
Display ID: CD8J-H655EF-Q-OP-210313V199
Build: EF-OP-210313V199
USERDATA: 111.15 GB
USERDATA: ENCRYPTED
Prepare data... OK
RESET FRP... OK
Search Userdata Partition... OK
Format Userdata Partition... OK
Finalize... OK
Reboot... OK
Elapsed Time: 26 secs, 264 msecs
The Following User Says Thank You to KYEJUSA For This Useful Post:
Old 07-02-2024, 12:45   #1940 (permalink)
Super Moderator
mihut's Avatar
Member: 824
Thanks Meter: 25,229
Test Signed Drivers is....ON
Preparing.....OK
Fix Drivers.........OK
Check BOOT.....NO
Checking iDevices.....OK
Reading iDevice info.....OK
Activation Status: Unactivated
BuildVersion: 19H384
CPU Arch: arm64
Device Class: iPhone
Device Name: iPhone
Firmware Version: iBoot-7459.140.15
Device IMEI: 355357084240444
Product Name: iPhone OS
Product Type: iPhone 7 Plus
IOS Version: 15.8.2
SIM Status: kCTSIMSupportSIMStatusNotInserted
Device Serial Number: FCJTL8LMHFY7
DeviceID: ff3d1110cee1bd7e780db6c3d69f878bf254296d
MEID Status: Not Supported
Preparing Hello....OK
Generating Activation Files....OK
Preparing.....OK
Device NAME: iPhone 7 Plus (GSM)
Product NAME: iPhone9,4
Device MODEL: d111ap
Device ECID: 0x1c616104f02326
Device CPID: 8010
Device SRTG: IBOOT-2696.0.0.1.33
Device MODE: DFU
Device CPU: A10
Waiting for server.....OK
Checking PWNDFU.....NO
iDevices PWNDFU :.....
Checking Drivers .....Ok
Device CPU: A10
Preparing.....OK
PWNDFU IS.....Ok
Preparing.....OK
Exploiting Device [1]....
Sending File (iboot).....Failed
Sending File (iboot).....OK
Sending File (devicetree).....OK
Sending File (ramdisk).....OK
Sending File (trustcache).....OK
Sending File (kernel).....OK
Successfully!
Checking SSH......P:16..OK
Mounting IPhone/Ipad partition (Hello/Passcode).......OK
BuildID:159FB784-D19D-11EE-8C06-84D25F1CE8A1
ProductBuildVersion:19H384
ProductCopyright:1983-2024 Apple Inc.
ProductName:iPhone OS
ProductVersion:15.8.2
SystemImageID:EBBB93A2-5BE0-4503-89C2-E03C8A1CFF56
Path:Backups/ff3d1110cee1bd7e780db6c3d69f878bf254296d
Wildcard File:Not Found
Activation Files (Hello Screen).......OK
Skip Setup...OK
Disable Reset Settings and Updates....OK
Operation {Boot Passcode/Hello IOS 11.x Up 16.x One Click} ID: D209CBDE6358579F
Elapsed time 04:42 -- Version 4.7.9 Build 001
__________________
Just Follow the Rules and Be Polite
Saying "thank you" can be hard. But it's so important.
The Following User Says Thank You to mihut For This Useful Post:
Old 07-02-2024, 13:37   #1941 (permalink)
badwily's Avatar
Member: 241933
Thanks Meter: 78
Oppo A78 CPH2483 FRP BYPASS DONE with EFT PRO 4.7.9
Power OFF the PHONE , and than press VOL UP/DOWN and connect to PC
The Following User Says Thank You to badwily For This Useful Post:
Old 07-14-2024, 15:24   #1942 (permalink)
Member: 2576731
Thanks Meter: 96
Itel a04 a632wm frp done eft dongle 2024 security
ITEL A04 A632WM FRP DONE EFT DONGLE 2024 APRIL SECURITY
Waiting For Device Connection... OK
USB PORT: COM83
Port: MediaTek USB Port (COM83)
OPEN COM PORT... OK
Handshake... OK
Setup DEVICE... OK
Init HARDWARE... OK
Setup DEVICE... OK
Read CHIP ID... OK
BB_CPU_PID : MT6580
CPU Version: 0x0000CA00
BLVersion : 0x00000000
Chip Ext Clock: EXT_26M
OPEN COM PORT... OK
Handshake... OK
Read preloader... OK
Handshake... OK
Send Download Agent...... OK
Read Partition Table... OK
USERDATA: 23.54 GB
USERDATA: ENCRYPTED
RESET FRP... OK
The Following User Says Thank You to Nelsonlanga For This Useful Post:
Old 07-15-2024, 10:21   #1943 (permalink)
Member: 2576731
Thanks Meter: 96
Nokia C2nd Edition PASSWORD RESET SUCCESSFULL WITH EFT DONGLE
https://ibb.co/RzxrQgj
Old 07-17-2024, 11:05   #1944 (permalink)
genci titi 2002's Avatar
Member: 193804
Sonork: 100.1684818
Thanks Meter: 1,714
Wink Sm-a226b reset frp... Ok
USB PORT: MediaTek PreLoader USB VCOM_V1632 (Android) (COM18)
Port: MediaTek PreLoader USB VCOM_V1632 (Android) (COM18)
OPEN COM PORT... OK
Handshake... OK
Read CHIP ID... OK
HW-CODE: 0X989
CPU: MT6833
HW-SUBCODE: 0X8A00
HW-VERSION: 0XCA00
SW-VERSION: 0X0000
Switch TO BROM PORT... OK
Wait for brom... OK
Setup DEVICE... OK
Init HARDWARE... OK
Setup DEVICE... OK
Init EXT RAM... OK
Random key: 00000000000000000000000000000000
Sla Version: 12345678 >> 2018915346
EMMC INFO:
EMMC CID: 150100445636444242007E036AB939E9
RAM INFO:
DRAM Size: 4.00 GB
Server ... OK
Brand: SAMSUNG
Model: SM-A226B
Product: A22XNSXX
Android Version: 13
Security Patch: 2023-10-01
Build Date: MON NOV 6 09:25:16 +07 2023
Display ID: TP1A.220624.014.A226BXXS8DWK2
Build: A226BXXS8DWK2
USERDATA: 107.97 GB
USERDATA: ENCRYPTED
Prepare data... OK
RESET FRP... OK
Finalize... OK
Reboot... OK
Elapsed Time: 23 secs, 791 msecs
Old 07-19-2024, 17:30   #1945 (permalink)
KYEJUSA's Avatar
Member: 394869
Thanks Meter: 515
TECNO SPARK7 PASSWORD AND FRP DONE:
OPEN COM PORT... OK
Handshake... OK
Analyzing server data...... OK
Read CHIP ID... OK
HW-CODE: 0X766
CPU: MT6765
HW-SUBCODE: 0X8A00
HW-VERSION: 0XCA00
SW-VERSION: 0X0000
Setup DEVICE... OK
Init HARDWARE... OK
Setup DEVICE... OK
Init EXT RAM... OK
EMMC INFO:
EMMC USER Size: 58.24 GB
EMMC CID: 150100445036384D42027652905A5867
RAM INFO:
DRAM Size: 3.00 GB
Server ... OK
Brand: TECNO
Product: TSSI
Android Version: 11 (Android 11)
Security Patch: 2021-09-05
Build ID: RP1A.200720.011
Build Date: FRI SEP 3 19:45:59 CST 2021
Display ID: KF6I-H6218EFK-R-OP-210903V176
Build: 210902V341
USERDATA: 51.00 GB
USERDATA: ENCRYPTED
Prepare data... OK
RESET FRP... OK
Finalize... OK
Reboot... OK
Elapsed Time: 28 secs, 929 msecs
Page generated in 0.18945 seconds with 9 queries
