Old 12-17-2019, 08:44   #1126 (permalink)
Member: 2765424
Thanks Meter: 1,036
samsunf a150f root file creat done with eft
Old 12-17-2019, 08:47   #1127 (permalink)
Member: 2765424
Thanks Meter: 1,036
SAMSUNG J330G root file creat done eft
Old 12-18-2019, 04:21   #1128 (permalink)
Stunman112's Avatar
Member: 2567774
Thanks Meter: 255
SM-G360T1 FRP adb Removed Done
Old 12-18-2019, 08:37   #1129 (permalink)
Member: 760450
Thanks Meter: 4
samsung j500h frp reset by EFT
Opening Port COM9...........OK
Verifying Download Mod
OK
Initialization.......OK
Reading Phone Partitation Table........OK
Partition Size : 8192
Unpak pit .......OK
FRP RESET.......OK
Rebooting PDA TO NORMAL MODE........OK
Old 12-18-2019, 10:22   #1130 (permalink)
Member: 2778229
Thanks Meter: 361
samsung j250f flash
j250f combination fille
j250f 4 fille write
Old 12-19-2019, 11:10   #1131 (permalink)
nicnec's Avatar
Member: 50585
Thanks Meter: 62
EFT Dongle 2.7 P20 lite FRP OK
Extracting files.....Done
Waiting for device to connect.....Found {COM42}
Opening Port.....OK
Writing xloader.....OK
Writing fastboot.....OK
Rebooting to fastboot.....OK
Connecting Fastboot .......
Connecting Fastboot .......Ok
Model Phone: ANE-LX1
SW: :ANE-LX19.1.0.205(C782E5R1P7)
Android Version: 9
SN: 89U7N19506001042
IMEI: 867440049974157
IMEI: IMEI1:000000000000000
IMEI: MEID:00000000000000
Lock state: FBLockState:UNLOCKED USERLockState:LOCKED
Boot info: unlocked
battery: 0
Frp Erase ...............OK
Erase Done , The Device Will Reboot And Factory Reset
Reboot ...............OK
By EFT Dongle OK
Old 12-20-2019, 09:20   #1132 (permalink)
Member: 2765424
Thanks Meter: 1,036
samsung c8 {c7108} root file creat done eft
Old 12-20-2019, 23:41   #1133 (permalink)
Stunman112's Avatar
Member: 2567774
Thanks Meter: 255
Alcatel 4060T FRP removed ADB
Old 12-21-2019, 15:15   #1134 (permalink)
technomak's Avatar
Member: 2035802
Sonork: 100.1675827
Thanks Meter: 787
Huawei NXT-L29 FRP unlock done
Checking fastboot device.....OK
Reading info.....OK
Device Model: HUAWEI NXT-L29
Device Serial: QHC0215C25002326
Device IMEI: 868xxx
Device Firmware: :NXT-L29C185B585
Device FB Lock: LOCKED
Device USER Lock: LOCKED
Device Lock: locked
Waiting for server.....OK
Reading data.....OK
Posting data to server.....OK
Waiting for server response.....OK
Unlocking device.....OK
Resetting FRP.....OK
Operation {Reset FRP using server} ID: 05E2CE3FA28019C9B14692638AF36B32
Elapsed time 00:16 -- Version 1.7.9
Old 12-23-2019, 11:34   #1135 (permalink)
Mohammed Aamri's Avatar
Member: 2536614
Thanks Meter: 2,785
Ane-lx1 8.0.0 180 (c432) reset frp
BR,
Mohammed Aamri
Old 12-24-2019, 15:06   #1136 (permalink)
Member: 2233266
Thanks Meter: 252
... (bootloader) Start Verify: 3
OKAY
Execution time is 1(s)
imei: 352189062859926
Execution time is 10(ms)
modelid: 0P9O11000
cidnum: CWS__001
Execution time is 0(ms)
sending 'zip'... (42921 KB) OKAY
writing 'zip'... (bootloader) adopting the signature contained in this image...
(bootloader) signature checking...
(bootloader) rom parsing start ...
(bootloader) rom parsing finish ...
(bootloader) checking main version...
(bootloader) zip header checking...
(bootloader) zip info parsing...
(bootloader) checking model ID...
(bootloader) checking custom ID...
(bootloader) checking hboot version...
(bootloader) start image[hboot] unzipping for pre-update check...
(bootloader) total_image_number=7
(bootloader) start image[hboot] flushing...
(bootloader) [RUU]WP,hboot,0
(bootloader) [RUU]WP,hboot,99
(bootloader) [RUU]WP,hboot,100
(bootloader) ...... Successful
(bootloader) current_image_number=0
(bootloader) current_image_number=1
(bootloader) current_image_number=2
(bootloader) current_image_number=3
(bootloader) current_image_number=4
(bootloader) current_image_number=5
(bootloader) current_image_number=6
FAIL90 hboot pre-update! please flush image again immediately
FAILED (remote: 90 hboot pre-update! please flush image again immediately)
For "hboot-preupdate" response, restart the same procedure for device HT54WWS00699...
(bootloader) total_image_number=14
(bootloader) start image[sp1] unzipping & flushing...
(bootloader) [RUU]UZ,sp1,0
(bootloader) [RUU]UZ,sp1,100
(bootloader) [RUU]WP,sp1,0
(bootloader) [RUU]WP,sp1,100
(bootloader) start image[tz] unzipping & flushing...
(bootloader) [RUU]UZ,tz,0
(bootloader) [RUU]UZ,tz,100
(bootloader) [RUU]UZ,rpm,0
(bootloader) start image[rpm] unzipping & flushing...
(bootloader) [RUU]UZ,rpm,100
(bootloader) start image[adsp] unzipping & flushing...
(bootloader) [RUU]UZ,adsp,0
(bootloader) [RUU]UZ,adsp,11
(bootloader) [RUU]UZ,adsp,22
(bootloader) [RUU]UZ,adsp,33
(bootloader) [RUU]UZ,adsp,43
(bootloader) [RUU]UZ,adsp,55
(bootloader) [RUU]UZ,adsp,66
(bootloader) [RUU]UZ,adsp,77
(bootloader) [RUU]UZ,adsp,88
(bootloader) [RUU]UZ,adsp,98
(bootloader) [RUU]UZ,adsp,100
(bootloader) [RUU]WP,adsp,0
(bootloader) [RUU]WP,adsp,100
(bootloader) start image[pg2fs_spcustom] unzipping & flushing...
(bootloader) [RUU]UZ,pg2fs_spcustom,0
(bootloader) [RUU]UZ,pg2fs_spcustom,100
(bootloader) start image[wcnss] unzipping & flushing...
(bootloader) [RUU]UZ,wcnss,0
(bootloader) [RUU]UZ,wcnss,22
(bootloader) [RUU]UZ,wcnss,44
(bootloader) [RUU]UZ,wcnss,67
(bootloader) [RUU]UZ,wcnss,98
(bootloader) [RUU]UZ,wcnss,100
(bootloader) [RUU]WP,wcnss,0
(bootloader) [RUU]WP,wcnss,100
(bootloader) start image[sdi] unzipping & flushing...
(bootloader) [RUU]UZ,sdi,0
(bootloader) [RUU]UZ,sdi,100
(bootloader) [RUU]WP,sdi,0
(bootloader) [RUU]WP,sdi,100
(bootloader) start image[sbl1] unzipping & flushing...
(bootloader) [RUU]UZ,sbl1,0
(bootloader) [RUU]UZ,sbl1,100
(bootloader) ..... Bypassed
(bootloader) verified fail
(bootloader) current_image_number=7
(bootloader) current_image_number=8
(bootloader) current_image_number=9
(bootloader) current_image_number=10
(bootloader) start image[recovery] unzipping & flushing...
(bootloader) [RUU]UZ,recovery,0
(bootloader) [RUU]UZ,recovery,5
(bootloader) [RUU]UZ,recovery,11
(bootloader) [RUU]UZ,recovery,19
(bootloader) [RUU]UZ,recovery,26
(bootloader) [RUU]UZ,recovery,35
(bootloader) [RUU]UZ,recovery,41
(bootloader) [RUU]UZ,recovery,49
(bootloader) [RUU]UZ,recovery,57
(bootloader) [RUU]UZ,recovery,64
(bootloader) [RUU]UZ,recovery,74
(bootloader) [RUU]UZ,recovery,79
(bootloader) [RUU]UZ,recovery,87
(bootloader) [RUU]UZ,recovery,95
(bootloader) [RUU]UZ,recovery,100
(bootloader) [RUU]WP,recovery,0
(bootloader) [RUU]WP,recovery,99
(bootloader) [RUU]WP,recovery,100
(bootloader) [RUU]UZ,radio,0
(bootloader) current_image_number=11
(bootloader) start image[radio] unzipping & flushing...
(bootloader) [RUU]UZ,radio,9
(bootloader) [RUU]UZ,radio,14
(bootloader) [RUU]UZ,radio,23
(bootloader) [RUU]UZ,radio,28
(bootloader) [RUU]UZ,radio,37
(bootloader) [RUU]UZ,radio,42
(bootloader) [RUU]UZ,radio,47
(bootloader) [RUU]UZ,radio,56
(bootloader) [RUU]UZ,radio,61
(bootloader) [RUU]UZ,radio,70
(bootloader) [RUU]UZ,radio,75
(bootloader) [RUU]UZ,radio,84
(bootloader) [RUU]UZ,radio,90
(bootloader) [RUU]UZ,radio,95
(bootloader) [RUU]UZ,radio,100
(bootloader) trying to rename MBA
(bootloader) [RUU]WP,radio,0
(bootloader) [RUU]WP,radio,37
(bootloader) [RUU]WP,radio,75
(bootloader) [RUU]WP,radio,100
(bootloader) current_image_number=12
(bootloader) start image[rcdata] unzipping & flushing...
(bootloader) [RUU]UZ,rcdata,0
(bootloader) [RUU]WP,rcdata,0
(bootloader) current_image_number=13
OKAY
sending 'zip'... (359846 KB) OKAY
(bootloader) start image[system] unzipping & flushing...
(bootloader) [RUU]UZ,system,0
(bootloader) [RUU]UZ,system,3
(bootloader) [RUU]UZ,system,7
(bootloader) [RUU]UZ,system,13
(bootloader) [RUU]UZ,system,18
(bootloader) [RUU]UZ,system,23
(bootloader) [RUU]UZ,system,29
(bootloader) [RUU]UZ,system,34
(bootloader) [RUU]UZ,system,39
(bootloader) [RUU]UZ,system,44
(bootloader) [RUU]UZ,system,50
(bootloader) [RUU]UZ,system,55
(bootloader) [RUU]UZ,system,60
(bootloader) [RUU]UZ,system,66
(bootloader) [RUU]WP,system,0
(bootloader) [RUU]WP,system,5
(bootloader) [RUU]WP,system,10
(bootloader) [RUU]WP,system,15
(bootloader) [RUU]WP,system,21
(bootloader) [RUU]WP,system,26
(bootloader) [RUU]WP,system,31
(bootloader) [RUU]WP,system,36
(bootloader) [RUU]WP,system,42
(bootloader) [RUU]WP,system,47
(bootloader) [RUU]WP,system,52
(bootloader) [RUU]WP,system,58
(bootloader) [RUU]WP,system,63
(bootloader) [RUU]WP,system,66
(bootloader) [RUU]UZ,system,68
(bootloader) [RUU]UZ,system,71
(bootloader) [RUU]UZ,system,74
(bootloader) [RUU]UZ,system,76
(bootloader) [RUU]UZ,system,79
(bootloader) [RUU]UZ,system,82
(bootloader) [RUU]UZ,system,85
(bootloader) [RUU]UZ,system,87
(bootloader) [RUU]UZ,system,90
(bootloader) [RUU]UZ,system,93
(bootloader) [RUU]UZ,system,95
(bootloader) [RUU]UZ,system,98
(bootloader) [RUU]WP,system,68
(bootloader) [RUU]WP,system,71
(bootloader) [RUU]WP,system,74
(bootloader) [RUU]WP,system,76
(bootloader) [RUU]WP,system,79
(bootloader) [RUU]WP,system,82
(bootloader) [RUU]WP,system,85
(bootloader) [RUU]WP,system,87
(bootloader) [RUU]WP,system,90
(bootloader) [RUU]WP,system,93
(bootloader) [RUU]WP,system,95
(bootloader) [RUU]WP,system,98
(bootloader) [RUU]WP,system,100
OKAY
sending 'zip'... (344753 KB) OKAY
(bootloader) [RUU]UZ,system,10
(bootloader) [RUU]UZ,system,15
(bootloader) [RUU]UZ,system,20
(bootloader) [RUU]UZ,system,26
(bootloader) [RUU]UZ,system,31
(bootloader) [RUU]UZ,system,36
(bootloader) [RUU]UZ,system,42
(bootloader) [RUU]UZ,system,47
(bootloader) [RUU]UZ,system,52
(bootloader) [RUU]UZ,system,57
(bootloader) [RUU]UZ,system,63
(bootloader) [RUU]UZ,system,69
(bootloader) [RUU]WP,system,20
(bootloader) [RUU]WP,system,57
(bootloader) [RUU]WP,system,69
(bootloader) [RUU]UZ,system,73
(bootloader) [RUU]UZ,system,75
(bootloader) [RUU]UZ,system,77
(bootloader) [RUU]UZ,system,81
(bootloader) [RUU]UZ,system,83
(bootloader) [RUU]UZ,system,89
(bootloader) [RUU]UZ,system,91
(bootloader) [RUU]UZ,system,97
(bootloader) [RUU]UZ,system,100
(bootloader) [RUU]WP,system,77
OKAY
sending 'zip'... (194623 KB) OKAY
(bootloader) [RUU]UZ,system,37
(bootloader) [RUU]UZ,system,41
(bootloader) [RUU]UZ,system,53
(bootloader) [RUU]UZ,system,64
(bootloader) [RUU]UZ,system,84
(bootloader) [RUU]WP,system,37
(bootloader) [RUU]WP,system,41
(bootloader) [RUU]WP,system,53
(bootloader) [RUU]WP,system,84
(bootloader) [RUU]UZ,system,94
OKAY
sending 'zip'... (502 KB) OKAY
(bootloader) [RUU]UZ,system,12
(bootloader) [RUU]UZ,system,19
(bootloader) [RUU]UZ,system,25
(bootloader) [RUU]UZ,system,38
(bootloader) [RUU]UZ,system,51
(bootloader) [RUU]UZ,system,70
(bootloader) [RUU]WP,system,12
(bootloader) [RUU]WP,system,19
(bootloader) [RUU]WP,system,25
(bootloader) [RUU]WP,system,38
(bootloader) [RUU]WP,system,44
(bootloader) [RUU]WP,system,50
(bootloader) [RUU]WP,system,88
OKAY
sending 'zip'... (37513 KB) OKAY
(bootloader) total_image_number=3
(bootloader) start image[dzdata] unzipping & flushing...
(bootloader) [RUU]UZ,dzdata,0
(bootloader) [RUU]UZ,dzdata,6
(bootloader) [RUU]UZ,dzdata,12
(bootloader) [RUU]UZ,dzdata,19
(bootloader) [RUU]UZ,dzdata,25
(bootloader) [RUU]UZ,dzdata,31
(bootloader) [RUU]UZ,dzdata,38
(bootloader) [RUU]UZ,dzdata,44
(bootloader) [RUU]UZ,dzdata,51
(bootloader) [RUU]UZ,dzdata,57
(bootloader) [RUU]UZ,dzdata,63
(bootloader) [RUU]UZ,dzdata,70
(bootloader) [RUU]UZ,dzdata,77
(bootloader) [RUU]UZ,dzdata,83
(bootloader) [RUU]UZ,dzdata,89
(bootloader) [RUU]UZ,dzdata,96
(bootloader) [RUU]UZ,dzdata,100
(bootloader) [RUU]WP,dzdata,0
(bootloader) [RUU]WP,dzdata,36
(bootloader) [RUU]WP,dzdata,68
(bootloader) [RUU]WP,dzdata,73
(bootloader) [RUU]WP,dzdata,78
(bootloader) [RUU]WP,dzdata,83
(bootloader) [RUU]WP,dzdata,89
(bootloader) [RUU]WP,dzdata,96
(bootloader) [RUU]WP,dzdata,100
(bootloader) start image[tp] unzipping & flushing...
(bootloader) [RUU]UZ,tp,0
(bootloader) [RUU]UZ,tp,100
(bootloader) [RUU]WP,tp,0
(bootloader) start image[boot] unzipping & flushing...
(bootloader) [RUU]UZ,boot,0
(bootloader) [RUU]UZ,boot,12
(bootloader) [RUU]UZ,boot,24
(bootloader) [RUU]UZ,boot,36
(bootloader) [RUU]UZ,boot,49
(bootloader) [RUU]UZ,boot,62
(bootloader) [RUU]UZ,boot,72
(bootloader) [RUU]UZ,boot,85
(bootloader) [RUU]UZ,boot,98
(bootloader) [RUU]UZ,boot,100
(bootloader) [RUU]WP,boot,0
(bootloader) [RUU]WP,boot,99
(bootloader) [RUU]WP,boot,100
sending time = 2.840 secs
OKAY
Flash Zip Complete
Execution time is 1014(s)
sending time = 2.810 secs
sending time = 25.758 secs
sending time = 24.944 secs
sending time = 18.712 secs
sending time = 8.891 secs
sending time = 11.652 secs
rebooting...
Execution time is 20(ms)
Old 12-24-2019, 15:09   #1137 (permalink)
Member: 2783598
Sonork: not have
Thanks Meter: 23
Waiting for USB COM 1 port.....Detected {COM332}
Connecting to device.....OK
Writing data 1.....OK
Writing data 2.....OK
Writing data 3.....OK
Rebooting device to fastboot.....OK
Waiting for fastboot device.....OK
Reading info.....OK
Device Model: EML-L29
Device Serial: AEJ7N18724000185
Device IMEI: 861197041182546
Device IMEI2: 861197041192552
Device Firmware: :EML-L29 9.1.0.345(C432E10R1P12)
Device FB Lock: UNLOCKED
Device Lock: unlocked
Operation {Reset FRP [Test Point]} ID: 768A802C1919B5BCAC935FC038342523
Elapsed time 01:16 -- Version 1.7.9.1
Old 01-03-2020, 08:08   #1138 (permalink)
Member: 1948180
Thanks Meter: 35
Samsung J530F U5 FRP reset by EFT
Old 01-03-2020, 10:25   #1139 (permalink)
Member: 450051
Thanks Meter: 406
Tecno i3 reset lock done with format
Wating Device..........OK
CPU: MT6737M
Chip Version: 0x0000ca00
Chip Ext Clock: EXT_26M
Writing Mode..........OK
Internal RAM:
Internal SRAM Size: 128.00 KB
External RAM: Type DRAM
External Ram Size: 2.00 GB
EMMC:
EMMC PART BOOT1 Size: 4.00 MB
EMMC PART BOOT2 Size: 4.00 MB
EMMC PART RPMB Size: 4.00 MB
EMMC PART USER Size: 14.56 GB
Battery:
Battery Voltage: 4103
Injection..........OK
Detecting Parts info............OK
[ID: 1] [preloader] BaseAddr(0x00000000) Size(0x00400000)
[ID: 8] [pgpt] BaseAddr(0x00000000) Size(0x00080000)
[ID: 8] [proinfo] BaseAddr(0x00080000) Size(0x00300000)
[ID: 8] [nvram] BaseAddr(0x00380000) Size(0x00500000)
[ID: 8] [protect1] BaseAddr(0x00880000) Size(0x00a00000)
[ID: 8] [protect2] BaseAddr(0x01280000) Size(0x00a00000)
[ID: 8] [lk] BaseAddr(0x01c80000) Size(0x00080000)
[ID: 8] [para] BaseAddr(0x01d00000) Size(0x00080000)
[ID: 8] [boot] BaseAddr(0x01d80000) Size(0x01000000)
[ID: 8] [recovery] BaseAddr(0x02d80000) Size(0x01000000)
[ID: 8] [logo] BaseAddr(0x03d80000) Size(0x00800000)
[ID: 8] [expdb] BaseAddr(0x04580000) Size(0x00a00000)
[ID: 8] [seccfg] BaseAddr(0x04f80000) Size(0x00080000)
[ID: 8] [oemkeystore] BaseAddr(0x05000000) Size(0x00200000)
[ID: 8] [secro] BaseAddr(0x05200000) Size(0x00600000)
[ID: 8] [keystore] BaseAddr(0x05800000) Size(0x00800000)
[ID: 8] [tee1] BaseAddr(0x06000000) Size(0x00500000)
[ID: 8] [tee2] BaseAddr(0x06500000) Size(0x00500000)
[ID: 8] [frp] BaseAddr(0x06a00000) Size(0x00100000)
[ID: 8] [nvdata] BaseAddr(0x06b00000) Size(0x02000000)
[ID: 8] [metadata] BaseAddr(0x08b00000) Size(0x02500000)
[ID: 8] [system] BaseAddr(0x0b000000) Size(0x126800000)
[ID: 8] [cache] BaseAddr(0x131800000) Size(0x19000000)
[ID: 8] [userdata] BaseAddr(0x14a800000) Size(0x258580000)
[ID: 8] [flashinfo] BaseAddr(0x3a2d80000) Size(0x01000000)
[ID: 8] [sgpt] BaseAddr(0x3a3d80000) Size(0x00080000)
Detecting Device info.......OK
Product: TECNO
Device Model: TECNO i3
Sw Internal:
Build Date: Wed Jan 31 18:41:25 CST 2018
Chip Ver: S01
Android Version: 7.0
Architecture: arm64-v8a
Formating... [USERDATA] .....OK
All Done By EFT Dongle
Old 01-03-2020, 10:29   #1140 (permalink)
Member: 450051
Thanks Meter: 406
redmi note 4 reset frp done
Serial Number: 0x5FEC1488
MSM HW ID: 000460E100000000
OEM Public Key Hash: 57158eaf1814d78fd2b3105ece4db18a817a08ac664a5782a9 25f3ff8403d39a
SBL SW Version: 0x0000000000000000
Sending Boot..........OK
unpack QC .......OK
Product: Xiaomi
Device Model: Redmi Note 4
Sw Internal:
Build Date: Thu May 24 21:46:24 WIB 2018
Chip Ver:
FRP RESET... [FRP]
Write config:...............OK
Page generated in 0.33450 seconds with 9 queries
