GSMSERVER GSM Shop
Old 06-18-2020, 00:00   #1291 (permalink)
Member: 2875052
Thanks Meter: 103
Connecting to device.....OK
Reading device info.....OK
Baseband Version: J327AUCS2ARG2
Serial Number: R28K52YFMNP
Device Arch: exynos7570
Device bootloader: J327AUCS2ARG2
Device selinux: enforcing
Device warranty bit: 0
Device Firmware: J327AUCS2ARG2
Android version: 7.0
Device SDK: 24
Device data encryption: unencrypted
Firmware Country: USA
Device Hardware: samsungexynos7570
Device CPU: armeabi-v7a
Device Factory: samsung
Device Model: SAMSUNG-SM-J327A
Device IMEI: 354775085xxxxxx
Root status.....Not Rooted
Resetting FRP.....OK
Operation {Reset FRP} ID: DF0BB67028EAFDB6
Elapsed time 00:05 -- Version 2.9
The Following User Says Thank You to Trapbay For This Useful Post:
Old 06-18-2020, 18:22   #1292 (permalink)
Member: 2875052
Thanks Meter: 103
Baseband Version: S337TLUDS4ARG1
Serial Number: R28K70MQL1
Device bootloader: S337TLUDS4ARG1
Device Firmware: S337TLUDS4ARG1
Device SDK: 24
Device Model: SM-S337TL
Device IMEI: 3564480833xxxxxx
Operation {Reset FRP} ID: 0B8E0B76AEC1A2D9
Elapsed time 00:06 -- Version 2.9
Old 06-18-2020, 21:46   #1293 (permalink)
Member: 2875052
Thanks Meter: 103
Baseband Version: J727PVPU4ARG2
Serial Number: 00000000000
Device bootloader: J727PVPU4ARG2
Device selinux: permissive
Device Firmware: J727PVPU4ARG2
Device SDK: 24
Device data encryption: encrypted
Device Hardware: qcom
Device CPU: arm64-v8a
Device Model: SM-J727P
Device IMEI: 353559084xxxxxx
Operation {Read Info} ID: 3D694B1285A13674
Elapsed time 00:00 -- Version 2.9
Old 06-18-2020, 21:47   #1294 (permalink)
Member: 2875052
Thanks Meter: 103
Device SDK: 24
Old 06-18-2020, 23:48   #1295 (permalink)
Member: 2875052
Thanks Meter: 103
Serial Number: R52K50HRV5T
Device bootloader: T380DXU1ARB3
Device Firmware: T380DXU1ARB3
Android version: 7.1.1
Device SDK: 25
Device Model: SM-T380
Device IMEI:
Operation {Reset FRP} ID: 74CE97D3F72BE078
Elapsed time 00:04 -- Version 2.9
Old 06-18-2020, 23:49   #1296 (permalink)
Member: 2875052
Thanks Meter: 103
Baseband Version: J320VPPVRU2APG3
Serial Number: R28H91G13HF
Device bootloader: J320VVRU2APE1
Device Firmware: J320VPPVRU2APG3
Android version: 6.0.1
Device SDK: 23
Device Model: SM-J320VPP
Device IMEI: 35692207xxxxx
Operation {Reset FRP} ID: BBD88B50AD91300A
Old 06-22-2020, 15:07   #1297 (permalink)
Member: 1086987
Sonork: 1617504
Thanks Meter: 70
p30 ele-l04 android 10 downgrade done
Searching for upgrade port.....Detected {COM190}
Target model [ELE-L04 10.0.0(C605)]
Reading data from server.....OK
Bypassing downgrade protection.....OK
Rebooting device.....OK
Waiting device to reboot.....OK
- Reboot your device to upgrade mode:
1 - Reboot to recovery by Volume up button
2 - Press on (Update mode)
3 - Press on (USB update mode)
Waiting for upgrade mode device.....OK
Start processing file [E:/Box/EFT/downloads/ELE-L04 10.0.0(C605) Downgrade For FRP Bypass By EFT Pro (AOD)/A.APP] 5,11 GB:
Flashing [sha256rsa.img].....OK
Flashing [crc.img].....OK
Flashing [base_verlist.img].....OK
Flashing [base_ver.img].....OK
Flashing [package_type.img].....OK
Flashing [hisiufs_gpt.img].....OK
Flashing [xloader.img].....OK
Flashing [fastboot.img].....OK
Flashing [dts.img].....OK
Flashing [dto.img].....OK
Flashing [vector.img].....OK
Flashing [fw_lpm3.img].....OK
Flashing [hhee.img].....OK
Flashing [vbmeta.img].....OK
Flashing [teeos.img].....OK
Flashing [trustfirmware.img].....OK
Flashing [sensorhub.img].....OK
Flashing [fw_hifi.img].....OK
Flashing [kernel.img].....OK
Flashing [modemnvm_update.img].....OK
Flashing [modemnvm_cust.img].....OK
Flashing [modem_driver.img].....OK
Flashing [recovery_ramdisk.img].....OK
Flashing [recovery_vendor.img].....OK
Flashing [recovery_vbmeta.img].....OK
Flashing [erecovery_kernel.img].....OK
Flashing [erecovery_ramdisk.img].....OK
Flashing [erecovery_vendor.img].....OK
Flashing [erecovery_vbmeta.img].....OK
Flashing [eng_vendor.img].....OK
Flashing [eng_system.img].....OK
Flashing [hdcp.img].....OK
Flashing [cache.img].....OK
Flashing [system.img].....OK
Flashing [cust.img].....OK
Flashing [isp_firmware.img].....OK
Flashing [modem_fw.img].....OK
Flashing [hisee_img.img].....OK
Flashing [vendor.img].....OK
Flashing [odm.img].....OK
Flashing [product.img].....OK
Flashing [preas.img].....OK
Flashing [preavs.img].....OK
Flashing [patch.img].....OK
Flashing [userdata.img].....OK
Flashing [ufsfw.img].....OK
Start processing file [E:/Box/EFT/downloads/ELE-L04 10.0.0(C605) Downgrade For FRP Bypass By EFT Pro (AOD)/O.APP] 9 MB:
Flashing [cust_verlist.img].....OK
Flashing [cust_ver.img].....OK
Flashing [ptable_cust.img].....OK
Flashing [version.img].....OK
Start processing file [E:/Box/EFT/downloads/ELE-L04 10.0.0(C605) Downgrade For FRP Bypass By EFT Pro (AOD)/D.APP] 166 MB:
Flashing [preload_verlist.img].....OK
Flashing [preload_ver.img].....OK
Flashing [ptable_preload.img].....OK
Flashing [preload.img].....OK
- Now go to recovery and do factory reset then use (Safe mode)
Operation {Downgrade to reset FRP} ID: 31CDC64B51870FB4
Elapsed time 08:02 -- Version 3.0
Old 06-23-2020, 21:17   #1298 (permalink)
Member: 2875052
Thanks Meter: 103
Checking fastboot device.....OK
Reading info.....OK
Device Model: LDN-LX3
Device Serial: VWUBB18830150083
Device IMEI: 867242033xxxxxx
Device Firmware: LDN-LX3 8.0.0.180(C605)
Device Lock: Image is origin | Verify mode is enforcing | Check root info is safe | Lock state is lock | Root State: UNROOT
Waiting for server.....OK
Reading data.....OK
Posting data to server.....OK
Waiting for server response.....OK
Unlocking device.....OK
Operation {Reset FRP using server} ID: 4499CFA9503818BE
Elapsed time 00:20 -- Version 3.1.1
Old 06-23-2020, 21:18   #1299 (permalink)
Member: 2875052
Thanks Meter: 103
Reading info.....OK
Reading data.....OK
Old 06-26-2020, 10:03   #1300 (permalink)
Arafat Mashaka's Avatar
Member: 750759
Sonork: 75101010
Thanks Meter: 112
Infinix X5516B FRP Done
Open EFT Pro 3.1.1 Go in MTK Tab
select INFINIX X5511-H3716-BI [Hot4 Pro LTE DS
stick DA and select MTK_AllInOne_DA
click start button that All
Setting up.....OK
Loading files.....OK
Waiting for MTK port.....Detected {COM21}
Connecting to Brom.....OK
Sending DA.....OK
Reading partitions.....OK
Chip name: MT6761
Reading prop info.....100%OK
Device Firmware: X5516B-H613OPQ-PGo-190326V175
Device SDK: 28
Android version: 9
Device Model: Infinix X5516B
Device Factory: Infinix
Device Factory: INFINIX MOBILITY LIMITED
Resetting frp.....OK
Operation {Reset FRP} ID: BA960047C93614D4
Elapsed time 00:26 -- Version 3.1.1
https://filebin.net/2s7wep49ab7jcupt
Old 06-28-2020, 12:22   #1301 (permalink)
niaz muhammad's Avatar
Member: 1519396
Sonork: 100.1612702
Thanks Meter: 1,926
Infinix_Hot_S3_X573 flashing don
Searching for Qualcomm 9008 port.....Detected {COM68}
Loading Programmer.....OK
Setting up.....OK
Reading hardware info.....OK
Serial number: 0x970b2011
Hardware ID: 0x0004f0e1
OEM Private key: 0xcc3153a80293939b90d02d3bf8b23e0292e452fef662c74998421adad42a380f
Software version: 0x00000000
Sending programmer.....OK
Reading prop info.....OK
Device Firmware: X573-QL1668DEF-O-190119V45
Device SDK: 26
Android version: 8.0.0
Device Model: Infinix X573
Flashing [NON-HLOS.bin].....OK
Flashing [sbl1.mbn].....OK
Flashing [rpm.mbn].....OK
Flashing [tz.mbn].....OK
Flashing [devcfg.mbn].....OK
Flashing [adspso.bin].....OK
Flashing [st1].....OK
Flashing [st2].....OK
Flashing [fsall_image.tar.gz.mbn.img].....OK
Flashing [emmc_appsboot.mbn].....OK
Flashing [boot.img].....OK
Flashing [recovery.img].....OK
Flashing [devinfo.bin].....OK
Flashing [persist_1.img].....OK
Flashing [config.bin].....OK
Flashing [mdtp.img].....OK
Flashing [cmnlib_30.mbn].....OK
Flashing [cmnlib64_30.mbn].....OK
Flashing [keymaster64.mbn].....OK
Flashing [oem.bin].....OK
Flashing [cache_1.img].....OK
Flashing [cache_2.img].....OK
Flashing [cache_3.img].....OK
Flashing [splash.img].....OK
Flashing [vendor_1.img].....OK
Flashing [vendor_2.img].....OK
Flashing [vendor_3.img].....OK
Flashing [vendor_4.img].....OK
Flashing [vendor_5.img].....OK
Flashing [vendor_6.img].....OK
Flashing [vendor_7.img].....OK
Flashing [vendor_8.img].....OK
Flashing [vendor_9.img].....OK
Flashing [vendor_10.img].....OK
Flashing [vendor_11.img].....OK
Flashing [vendor_12.img].....OK
Flashing [vendor_13.img].....OK
Flashing [system_1.img].....OK
Flashing [system_2.img].....OK
Flashing [system_3.img].....OK
Flashing [system_4.img].....OK
Flashing [system_5.img].....OK
Flashing [system_6.img].....OK
Flashing [system_7.img].....OK
Flashing [system_8.img].....OK
Flashing [system_9.img].....OK
Flashing [system_10.img].....OK
Flashing [system_11.img].....OK
Flashing [system_12.img].....OK
Flashing [system_13.img].....OK
Flashing [system_14.img].....OK
Flashing [system_15.img].....OK
Flashing [system_16.img].....OK
Flashing [system_17.img].....OK
Flashing [system_18.img].....OK
Flashing [system_19.img].....OK
Flashing [system_20.img].....OK
Flashing [system_21.img].....OK
Flashing [system_22.img].....OK
Flashing [system_23.img].....OK
Flashing [system_24.img].....OK
Flashing [system_25.img].....OK
Flashing [system_26.img].....OK
Flashing [system_27.img].....OK
Flashing [system_28.img].....OK
Flashing [system_29.img].....OK
Flashing [system_30.img].....OK
Flashing [system_31.img].....OK
Flashing [system_32.img].....OK
Flashing [system_33.img].....OK
Flashing [system_34.img].....OK
Flashing [system_35.img].....OK
Flashing [system_36.img].....OK
Flashing [system_37.img].....OK
Flashing [system_38.img].....OK
Flashing [system_39.img].....OK
Flashing [system_40.img].....OK
Flashing [system_41.img].....OK
Flashing [system_42.img].....OK
Flashing [system_43.img].....OK
Flashing [system_44.img].....OK
Flashing [system_45.img].....OK
Flashing [system_46.img].....OK
Flashing [system_47.img].....OK
Flashing [userdata_1.img].....OK
Flashing [userdata_2.img].....OK
Flashing [userdata_3.img].....OK
Flashing [userdata_4.img].....OK
Flashing [userdata_5.img].....OK
Flashing [userdata_6.img].....OK
Flashing [userdata_7.img].....OK
Flashing [userdata_8.img].....OK
Flashing [userdata_9.img].....OK
Flashing [userdata_10.img].....OK
Flashing [userdata_11.img].....OK
Flashing [userdata_12.img].....OK
Flashing [userdata_13.img].....OK
Flashing [userdata_14.img].....OK
Flashing [userdata_15.img].....OK
Flashing [userdata_16.img].....OK
Flashing [userdata_17.img].....OK
Flashing [userdata_18.img].....OK
Flashing [userdata_19.img].....OK
Flashing [userdata_20.img].....OK
Flashing [userdata_21.img].....OK
Flashing [userdata_22.img].....OK
Flashing [userdata_23.img].....OK
Flashing [userdata_24.img].....OK
Flashing [userdata_25.img].....OK
Flashing [userdata_26.img].....OK
Flashing [userdata_27.img].....OK
Flashing [userdata_28.img].....OK
Flashing [userdata_29.img].....OK
Flashing [userdata_30.img].....OK
Flashing [userdata_31.img].....OK
Flashing [userdata_32.img].....OK
Flashing [userdata_33.img].....OK
Flashing [userdata_34.img].....OK
Flashing [userdata_35.img].....OK
Flashing [gpt_main0.bin].....OK
Flashing [gpt_backup0.bin].....OK
Applying patches.....OK
Operation {Flash Firmware} ID: 3D539C3DA7AFE427
Elapsed time 12:10 -- Version 3.1.2
Old 06-29-2020, 19:46   #1302 (permalink)
Member: 605342
Thanks Meter: 3
Huawei VTR-L09 frp
Waiting for USB COM 1 port.....Detected {COM258}
Writing data 1.....OK
Writing data 2.....OK
Writing data 3.....OK
Rebooting device to fastboot.....OK
Waiting for fastboot device.....OK
Reading info.....OK
Device Model: VTR-L09
Device Serial: WPG0217A24001717
Device IMEI: 865545034235XXX
Device IMEI2: 865545034235XXX
Device Firmware: :VTR-L09 9.1.0.252(C25E4R1P8)
Device FB Lock: UNLOCKED
Device USER Lock: LOCKED
Device Lock: unlocked
Operation {Reset FRP [Test Point]} ID: 761E642B3FEEB29B
Elapsed time 00:34 -- Version 3.1.2
Old 07-02-2020, 17:09   #1303 (permalink)
canliyayin's Avatar
Member: 311558
Thanks Meter: 432
a510f u8 oem unlock on reset screen lock done
Old 07-06-2020, 12:27   #1304 (permalink)
Member: 750759
Sonork: 75101010
Thanks Meter: 112
Tecno KB8 FRP reset done
Setting up.....OK Loading files.....OK
Waiting for MTK port.....Detected {COM11}
Sending DA.....OK
Chip name: MT6761
Device Firmware: KB8-H624BNPQ-P-190717V203
Device SDK: 28
Android version: 9
Device Model: TECNO KB8
Device Factory: TECNO
Device Factory: TECNO MOBILE LIMITED
Operation {Reset FRP} ID: 7EC3161957EE8BC3
Elapsed time 00:54 -- Version 3.1.2
Old Yesterday, 12:03   #1305 (permalink)
Member: 2124329
Thanks Meter: 41
Navon mizu f552
Setting up.....OK
Waiting for MTK port.....Detected {COM22}
Sending DA.....OK
Chip name: MT6580
Device Firmware: MRA58K dev-keys
Device SDK: 23
Device Model: F552
Device Factory: Navon
Operation {Reset FRP} ID: BF847CC7F9201AEA
Elapsed time 01:44 -- Version 3.1.2
Page generated in 0.18345 seconds with 8 queries
