12-19-2020, 12:13 | #1411 (permalink) |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Samsung A10 (A105FN), Androis 10, ROTTED in 5 mins by BIG EFT 1) 2) And here ROTTED BR Allumts |
The Following 3 Users Say Thank You to allumts For This Useful Post: |
12-19-2020, 18:31 | #1413 (permalink) |
No Life Poster Join Date: Mar 2015 Location: Islam Age: 35
Member: 2371500 Status: Offline Thanks Meter: 5,801 | Huawei Y9 2019 JKM-LX1 downgrade done safe mode worked 9.1.0.309 same method in below thread but higher patch \https://forum.gsmhosting.com/vbb/f10...-done-2805311/ https://forum.gsmhosting.com/vbb/f10...224-a-2869723/ https://forum.gsmhosting.com/vbb/f10...282-a-2858747/ https://forum.gsmhosting.com/vbb/f10...orked-2827449/ Checking fastboot device.....OK Reading info.....OK Device Model: JKM-LX1 Device Firmware: :JKM-LX1 9.1.0.309(C185E1R2P1) Base Firmware: :JKM-LGRP2-OVS 9.1.0.309 Custom Firmware: :JKM-LX1-CUST 9.0.1.1(C185) Preload Firmware: :JKM-LX1-PRELOAD 9.1.0.1(C185R2) Device FB Lock: LOCKED Device USER Lock: LOCKED Device Lock: locked Operation {Read info} ID: B7312241C6E53AD2 Elapsed time 00:00 -- Version 3.6.0 Checking fastboot device.....OK Reading info.....OK Device Model: JKM-LX1 Device Firmware: :JKM-LX1 9.1.0.309(C185E1R2P1) Base Firmware: :JKM-LGRP2-OVS 9.1.0.309 Custom Firmware: :JKM-LX1-CUST 9.0.1.1(C185) Preload Firmware: :JKM-LX1-PRELOAD 9.1.0.1(C185R2) Device FB Lock: LOCKED Device USER Lock: LOCKED Device Lock: locked Checking needed files.....OK Writing image 1.....OK Writing image 2.....OK Writing image 3.....OK Switching to upgrade mode.....1OK Waiting for Upgrade Mode port.....OK Connecting to device.....OK Start processing file [D:/New folder (4)/UPDATE.APP] 3,42 GB: Firmware version: JKM 9.0.1(OVS) Flashing [sha256rsa.img].....OK Flashing [crc.img].....OK Flashing [curver.img].....OK Flashing [verlist.img].....OK Flashing [package_type.img].....OK Flashing [hisiufs_gpt.img].....OK Flashing [xloader.img].....OK Flashing [fastboot.img].....OK Flashing [dts.img].....OK Flashing [dto.img].....OK Flashing [vector.img].....OK Flashing [fw_lpm3.img].....OK Flashing [hhee.img].....OK Flashing [teeos.img].....OK Flashing [trustfirmware.img].....OK Flashing [sensorhub.img].....OK Flashing [fw_hifi.img].....OK Flashing [kernel.img].....OK Flashing [vbmeta.img].....OK Flashing [modemnvm_update.img].....OK Flashing [modemnvm_cust.img].....OK Flashing [recovery_ramdisk.img].....OK Flashing [recovery_vendor.img].....OK Flashing [recovery_vbmeta.img].....OK Flashing [eng_vendor.img].....OK Flashing [eng_system.img].....OK Flashing [cache.img].....OK Flashing [system.img].....OK Flashing [cust.img].....OK Flashing [isp_firmware.img].....OK Flashing [modem_fw.img].....OK Flashing [hisee_img.img].....OK Flashing [hisee_fs.img].....OK Flashing [vendor.img].....OK Flashing [version.img].....OK Flashing [odm.img].....OK Flashing [product.img].....OK Flashing [preas.img].....OK Flashing [preavs.img].....OK Flashing [userdata.img].....OK Flashing [preload.img].....OK Flashing [erecovery_kernel.img].....OK Flashing [erecovery_vendor.img].....OK Flashing [erecovery_ramdisk.img].....OK Flashing [erecovery_vbmeta.img].....OK Flashing [patch.img].....OK Rebooting device.....OK Operation {Flash APP Firmware} ID: 321CC1724011247A Elapsed time 07:38 -- Version 3.6.0 [IMG]****************************/convkey/25cf/ysvgy0dt2nsjoe7zg.jpg[/IMG] [IMG]****************************/convkey/5ab1/n9vksr9pwkuu4nezg.jpg[/IMG] |
12-20-2020, 14:41 | #1414 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | Infinix X609 Pinlock Remove Code: Setting up.....OK Loading files.....OK Waiting for MTK port.....Detected {COM21} Connecting to Brom.....OK Sending DA.....OK Chip name: MT6580 Reading prop info.....OK Device Firmware: X609-H8025AB-GO-190320V173 Device SDK: 27 Android version: 8.1.0 Device Factory: Infinix Device Model: Infinix X609 Device Factory: INFINIX MOBILITY LIMITED Device CPU: armeabi-v7a Reading data.....OK Patching data.....OK Operation {ScreenLock} ID: 1029F5D72602B157 Elapsed time 02:37 -- Version 3.6.0 |
12-21-2020, 15:48 | #1416 (permalink) |
Freak Poster Join Date: Oct 2004 Location: Poland Age: 44
Member: 87364 Status: Offline Thanks Meter: 63 | P20 Lite FRP OK: Waiting for USB COM 1 port.....Detected {COM4} Connecting to device.....OK Writing data 1.....OK Writing data 3.....OK Rebooting device to fastboot.....OK Waiting for fastboot device.....OK Reading info.....OK Device Model: ANE-LX1 Device Serial: 9WV4C18929025051 Device IMEI: 862742041306287 Device IMEI2: 862742041346291 Device Firmware: :ANE-LX1 9.1.0.355(C432E6R1P7) Device FB Lock: UNLOCKED Device USER Lock: LOCKED Device Lock: unlocked Resetting FRP.....OK Operation {Reset FRP [Test Point]} ID: 7DC4C88603CAFEE8 Elapsed time 00:17 -- Version 3.6.0 |
The Following User Says Thank You to rgsm For This Useful Post: |
12-22-2020, 09:04 | #1417 (permalink) |
No Life Poster Join Date: Nov 2006 Location: pakistan Age: 39
Member: 384949 Status: Offline Sonork: 1611265 Thanks Meter: 523 | iphone x bypass done Preparing paths.....OK Setting up.....OK Checking iDevices.....OK Reading iDevice info.....OK Activation Status: Unactivated CPU Arch: arm64 Device Class: iPhone Device Name: iPhone Firmware Version: iBoot-4513.260.81 Device IMEI: 353045091168532 Product Name: iPhone OS Product Type: iPhone X GSM IOS Version: 12.3.1 SIM Status: kCTSIMSupportSIMStatusNotInserted Device Serial Number: F2PVT8Y5JCLH MEID Status: Not Supported Preparing.....OK Bypassing.....OK Operation {Bypass iCloud at Hello Screen} ID: 0286217CBEC76B07 Elapsed time 00:51 -- Version 3.6.1 |
The Following User Says Thank You to iftikhar_246 For This Useful Post: |
12-22-2020, 12:12 | #1419 (permalink) |
Freak Poster Join Date: Jan 2015
Member: 2336789 Status: Offline Sonork: [email protected] Thanks Meter: 17 | SM-J730F u3 frp done Opening Port COM4...........OK Verifying Download Mod OK Initialization.......OK Reading Phone Partitation Table........OK Partition Size : 8192 Unpak pit .......OK FLASHING FIRMWARE TO PHONE..... Sending data: ..........OK FLASHING DONE! Rebooting PDA TO NORMAL MODE........OK Waiting For ADB Device.....Detecting Device Info.....DONE Device Model: SM-J730F Device CPU: armeabi-v7a Android SDK: 27 Android Version: 8.1.0 Resetting Samsung Account / Frp .......OK |
The Following User Says Thank You to olger For This Useful Post: |
12-22-2020, 19:45 | #1420 (permalink) |
No Life Poster Join Date: Jun 2013 Location: BANGLADESH+UAE Age: 34
Member: 1969978 Status: Offline Sonork: 100.1613242 Thanks Meter: 693 | Device Model: AGS-W09 Frp Remove Done Checking fastboot device.....OK Reading info.....OK Device Model: AGS-W09 Device Serial: 4JPNU20319401050 Device IMEI: 4JPNU20319401050 Device Firmware: AGS-W09 8.0.0.120(C185) Device Lock: Image is origin | Verify mode is enforcing | Check root info is safe | Lock state is lock | Root State: UNROOT Waiting for server.....OK Reading data.....OK Posting data to server.....OK Waiting for server response.....OK Unlocking device.....OK Resetting FRP.....OK Operation {Reset FRP using server} ID: 69F849685AD1CB35 Elapsed time 00:10 -- Version 3.6.1 |
The Following User Says Thank You to maxmobilephone For This Useful Post: |
12-23-2020, 12:55 | #1421 (permalink) |
No Life Poster Join Date: Mar 2006 Location: London
Member: 241938 Status: Offline Sonork: 100.1663699 Thanks Meter: 477 | oppo a5s cph1909 reset succesfully oppo a5s cph1909 reset succesfully. thanks to eft team kindly add oppo and vivo all models supported by other teams, Regards [IMG][/IMG] |
The Following User Says Thank You to amirsaishi For This Useful Post: |
12-23-2020, 16:42 | #1424 (permalink) |
Junior Member Join Date: Nov 2020 Location: Dhaka
Member: 2974166 Status: Offline Thanks Meter: 13 | honour 9 lite 9.1.0 frp unlock done eft Waiting for device to connect.....Found {COM39} Opening Port.....OK Writing xloader.....OK Writing fastboot.....OK Rebooting to fastboot.....OK Connecting Fastboot ....... Connecting Fastboot .......Ok Model Phone: LLD-AL10 SW: :LLD-AL109.1.0.173(C675E9R1P4) Android Version: 9 SN: P8B4xxxxxx IMEI: 86716803xxxxxxx IMEI: IMEI1:86716xxxxxxx IMEI: MEID:00000000000000 Lock state: FBLockState:UNLOCKED USERLockState:LOCKED Boot info: unlocked battery: 0 Frp Erase ............. Erase Done , The Device Will Reboot And Factory Reset Reboot ............. By EFT Dongle OK |
12-24-2020, 14:17 | #1425 (permalink) |
Product Manager Join Date: Feb 2016 Location: EFT Dongle
Member: 2536865 Status: Offline Sonork: 100.1584728 Thanks Meter: 21,200 | BLL-L21 FRP reset done by EFT Pro Code: Checking fastboot device.....OK Reading info.....OK Device Model: BLL-L21 Device Serial: 2WGDU17406003342 Device IMEI: 862497032931433 Device IMEI2: 862497032967445 Device Firmware: :BLL-L21C185B386 Device FB Lock: LOCKED Device USER Lock: LOCKED Device Lock: locked Waiting for server.....OK Reading data.....OK Posting data to server.....OK Waiting for server response.....OK Unlocking device.....OK Resetting FRP.....OK Operation {Reset FRP using server} ID: B4E30B704C4B8CF3 Elapsed time 00:11 -- Version 3.6.1 |
