01-27-2021, 12:54 | #1472 (permalink) |
No Life Poster Join Date: Oct 2015 Location: Unknown
Member: 2469611 Status: Offline Thanks Meter: 389 | Huawei AUM-L29 FRP Done Code: Checking fastboot device.....OK Reading info.....OK Device Model: AUM-L29 Device Serial: Q*******5 Device IMEI: 3*************8 Device Firmware: AUM-L29 8.0.0.157(C432) Device Lock: Image is origin | Verify mode is enforcing | Check root info is safe | Lock state is lock | Root State: UNROOT Waiting for server.....OK Reading data.....OK Posting data to server.....OK Waiting for server response.....OK Unlocking device.....OK Resetting FRP.....OK Operation {Reset FRP using server} ID: 77336CC18A93AF14 Elapsed time 00:12 -- Version 3.8.2 |
02-01-2021, 07:38 | #1475 (permalink) |
No Life Poster Join Date: Apr 2015 Location: LOOLCANO Taba Day.
Member: 2385819 Status: Offline Sonork: No More Used Thanks Meter: 827 | G532 Lock Screen Unlock Done WitOut Data Losse. |
The Following User Says Thank You to ahmer5050 For This Useful Post: |
02-02-2021, 06:39 | #1476 (permalink) |
No Life Poster Join Date: May 2006 Location: Sambrial (Sialkot)
Member: 282066 Status: Offline Sonork: 100.1590696 Thanks Meter: 569 | Huawei p10 lite frp done Checking fastboot device.....OK Reading info.....OK Device Model: WAS-LX1A Device Serial: H3XDU17B09017209 Device IMEI: 86xxxxxxxxxxxxxxx Device IMEI2: 000000000000000 Device Firmware: : Preload Firmware: : Device FB Lock: LOCKED Device USER Lock: LOCKED Device Lock: locked Waiting for server.....OK Reading data.....OK Posting data to server.....OK Waiting for server response.....OK Unlocking device.....OK Resetting FRP.....OK Operation {Reset FRP using server} ID: E34930B3E344F272 Elapsed time 00:14 -- Version 3.9.1 |
The Following User Says Thank You to zeerik For This Useful Post: |
02-03-2021, 09:42 | #1477 (permalink) |
No Life Poster Join Date: Nov 2006 Location: pakistan Age: 39
Member: 384949 Status: Offline Sonork: 1611265 Thanks Meter: 523 | j500f frp bypass Searching for Samsung ODIN protocol.....Detected {COM3} Connecting to device.....OK Reading PIT.....OK Flashing [data].....OK Rebooting device.....OK Operation {Reset FRP} ID: 7122AFFF3140DF41 Elapsed time 00:05 -- Version 3.9.1 |
02-04-2021, 10:02 | #1478 (permalink) |
No Life Poster Join Date: Sep 2011 Location: a
Member: 1647504 Status: Offline Thanks Meter: 236 | iPhone X bypass full signal ok Preparing paths.....OK Setting up.....OK Checking iDevices.....OK Reading iDevice info.....OK Activation Status: Unactivated CPU Arch: arm64 Device Class: iPhone Device Name: iPhone Firmware Version: iBoot-6723.80.19 Device IMEI: 353043093565540 Product Name: iPhone OS Product Type: iPhone X GSM IOS Version: 14.4 SIM Status: kCTSIMSupportSIMStatusNotInserted Device Serial Number: DNQVW3DSJCLH MEID Status: Not Supported Preparing.....OK Bypassing.....OK Operation {Bypass iCloud at Hello Screen} ID: B849F7308F9A0FC7 Elapsed time 01:44 -- Version 3.9.1 |
The Following User Says Thank You to td_mobile_2007 For This Useful Post: |
02-05-2021, 13:02 | #1479 (permalink) |
No Life Poster Join Date: Oct 2005 Location: TITI 2002 SERVIS CELULAR PG/AL
Member: 193804 Status: Offline Sonork: 100.1684818 Thanks Meter: 1,693 | 7plus 14.3 icloud and notification fix Preparing paths.....OK Setting up.....OK Checking iDevices.....OK Reading iDevice info.....OK Activation Status: Unactivated CPU Arch: arm64 Device Class: iPhone Device Name: iPhone Firmware Version: iBoot-6723.62.3 Device IMEI: 353xxxxxxx07 Product Name: iPhone OS Product Type: iPhone 7 Plus IOS Version: 14.3 SIM Status: kCTSIMSupportSIMStatusNotInserted Device Serial Number: F2LSP0FTHG07 MEID Status: Not Supported Preparing.....OK Bypassing.....OK Operation {Bypass iCloud at Hello Screen} ID: 5E17A17EA61A1EF6 Elapsed time 01:06 -- Version 3.9.1 Preparing paths.....OK Setting up.....OK Checking iDevices.....OK Reading iDevice info.....OK Activation Status: FactoryActivated CPU Arch: arm64 Device Class: iPhone Device Name: iPhone Firmware Version: iBoot-6723.62.3 Device IMEI: 3538xxxxxxx07 Product Name: iPhone OS Product Type: iPhone 7 Plus IOS Version: 14.3 SIM Status: kCTSIMSupportSIMStatusNotInserted Device Serial Number: F2LSP0FTHG07 MEID Status: Not Supported Preparing.....OK Processing.....OK Operation {Fix Notifications after Bypass} ID: CE5C03474A79B693 Elapsed time 00:33 -- Version 3.9.1 |
02-07-2021, 23:57 | #1480 (permalink) |
Freak Poster Join Date: Nov 2018 Location: Everywhere Your Not
Member: 2875052 Status: Offline Thanks Meter: 211 | Iphone 7 Plus IC REMOVAL Preparing paths.....OK Setting up.....OK Checking iDevices.....OK Reading iDevice info.....OK Activation Status: Unactivated CPU Arch: arm64 Device Class: iPhone Device Name: iPhone Firmware Version: iBoot-6723.80.19 Device IMEI: 355355088xxxxxx Product Name: iPhone OS Product Type: iPhone 7 Plus IOS Version: 14.4 SIM Status: kCTSIMSupportSIMStatusNotInserted Device Serial Number: FCDY20RAHG04 MEID Status: Not Supported Preparing.....OK Bypassing.....OK Operation {Bypass iCloud at Hello Screen} ID: 9AF1B9629B28B587 Elapsed time 00:51 -- Version 3.9.1 |
02-09-2021, 09:00 | #1481 (permalink) |
No Life Poster Join Date: Oct 2011 Location: online
Member: 1680232 Status: Offline Sonork: 100.1611221 Thanks Meter: 227 | Searching for Samsung ODIN protocol.....Detected {COM7} Total flash size: 6,49 GB Connecting to device.....OK Setting PIT.....OK Reading PIT.....OK Flashing [sboot.bin].....OK Flashing [param.bin].....OK Flashing [up_param.bin].....OK Flashing [cm.bin].....OK Flashing [keystorage.bin].....OK Flashing [uh.bin].....OK Flashing [vbmeta.img].....OK Flashing [boot.img].....OK Flashing [recovery.img].....OK Flashing [dt.img].....OK Flashing [dtbo.img].....OK Flashing [system.img].....OK Flashing [vendor.img].....OK Flashing [carrier.img].....OK Flashing [modem.bin].....OK Flashing [modem_debug.bin].....OK Flashing [cache.img].....OK Flashing [omr.img].....OK Flashing [product.img].....OK Rebooting device.....OK Operation {Flash Firmware} ID: D18567840EA0D8AC Elapsed time 03:02 -- Version 3.9.1 |
02-09-2021, 11:33 | #1482 (permalink) |
Freak Poster Join Date: Jul 2013 Location: CAPE VERDE
Member: 1973366 Status: Offline Sonork: 100.1646895 Thanks Meter: 42 | Huawei fig-lx1 frp unlock _Waiting for USB COM 1 port.....Detected {COM16} Connecting to device.....OK Writing data 1.....OK Writing data 3.....OK Rebooting device to fastboot.....OK Waiting for fastboot device.....OK Reading info.....OK Device Model: FIG-LX1 Device Serial: XED7N19314001399 Device IMEI: 865689047480557 Device IMEI2: 865689047492560 Device Firmware: :FIG-LX1 9.1.0.216(C432E22R1P5) Device FB Lock: UNLOCKED Device USER Lock: LOCKED Device Lock: unlocked Resetting FRP.....Failed Operation {Reset FRP [Test Point]} ID: E3D1970F91FF471A Elapsed time 00:27 -- Version 3.9.1 |
02-10-2021, 14:18 | #1484 (permalink) |
Member: 384949 Status: Offline Sonork: 1611265 Thanks Meter: 523 | y7 2019 frp done Waiting for server.....OK Searching for Qualcomm 9008 port.....Detected {COM54} Loading Programmer.....OK Setting up.....OK Reading hardware info.....OK Serial number: 0xe2eebcc4 Hardware ID: 0x0009a0e1 OEM Private key: 0x6bc369511da9cadb3a7af61574f89db385003d6241bdd1ff 573dba61bf6ae119 Software version: 0x00000000 Sending programmer.....OK Reading partitions.....OK Reading prop info.....OK Device SDK: 27 Android version: 8.1.0 Device CPU: arm64-v8a Device Factory: unknown Device SDK: 27 Android version: 8.1.0 Device CPU: arm64-v8a Resetting FRP.....OK Rebooting device.....OK Operation {Reset FRP} ID: 366BBEC59BBE44FF Elapsed time 00:52 -- Version 3.9.1 |
02-11-2021, 17:34 | #1485 (permalink) |
No Life Poster Join Date: Oct 2011 Location: Nigeria
Member: 1677653 Status: Offline Thanks Meter: 2,769 | Huawei ags-lo9 frp reset done Checking fastboot device.....OK Reading info.....OK Device Model: AGS-L09 Device Serial: 9CXNU20B11102581 Device IMEI: 864653042045584 Device Firmware: AGS-L09 8.0.0.161(C185) Device Lock: Image is origin | Verify mode is enforcing | Check root info is safe | Lock state is lock | Root State: UNROOT Waiting for server.....OK Reading data.....OK Posting data to server.....OK Waiting for server response.....OK Unlocking device.....OK Resetting FRP.....OK Operation {Reset FRP using server} ID: BFD1EF3BBE447561 Elapsed time 00:16 -- Version 3.9.1 |
The Following User Says Thank You to Yusuf Lawal For This Useful Post: |
