Old 03-14-2023, 22:36   #1 (permalink)
Member: 15521
Thanks Meter: 57
Temporary unlock bootloader and unlock FRP not work
I try temporary unlock bootloader ATU-L21 but not work. Reset FRP, the same problem, not work. Some time ago this model was supported, now is not, or some bug? Can You Fix this?
Checking fastboot device.....OK
Reading info.....OK
Device Model: ATU-L21
Device Serial: xxxxx258
Device IMEI: xxxxx963
Device Firmware: ATU-L21 8.0.0.167(C432)
Device Lock: Image is origin | Verify mode is enforcing | Check root info is safe | Lock state is lock | Root State: UNROOT
Waiting for server.....OK
Reading data.....OK
Posting data to server.....OK
Waiting for server response.....Failed: The data is empty
Operation {Temporary unlock bootloader} ID: D586C4A49A1BE0CF
Elapsed time 05:52 -- Version 4.4.3 Build 008
Reading info.....OK
Reading data.....OK
Operation {Reset FRP using server} ID: 9D9A39219D7359DA
Elapsed time 05:50 -- Version 4.4.3 Build 008
This is post from year 2020 :
https://forum.gsmhosting.com/vbb/f10...-done-2800166/
Old 03-15-2023, 04:22   #2 (permalink)
hamada-almasry's Avatar
Member: 619738
Sonork: 100.1582811
Thanks Meter: 5,205
I find you using fastboot mode why? Use better edl mode selection
Old 03-15-2023, 09:07   #3 (permalink)
Thanks Meter: 19,542
try again sir now.......
Old 03-15-2023, 09:07   #4 (permalink)
The Following User Says Thank You to easy-team For This Useful Post:
Old 03-16-2023, 22:58   #5 (permalink)
Member: 15521
Thanks Meter: 57
Now is all ok. Thank You.
The Following User Says Thank You to Sakura For This Useful Post:
Page generated in 0.12953 seconds with 9 queries
