Register | FAQ | Donate | Forum Rules | Root any Device | ★iPhone Unlock★ | -= Z3X JTAG PLUS =- | Direct Unlock Source | Search | Today's Posts | Mark Forums Read |
![]() | #1 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Feb 2004 Location: Bulgaria Age: 55
Member: 52180 Status: Offline Thanks Meter: 43 | VOG-L29 10.1.0 can not downgrade for FRP Checking fastboot device.....OK Reading info.....OK Device Model: VOG-L29 Device Firmware: :VOG-L29 10.1.0.123(C431E19R2P5) Device FB Lock: LOCKED Device USER Lock: LOCKED Device Lock: locked Operation {Read info} ID: 0B06B60E306685D8 Elapsed time 00:01 -- Version 2.9 and error: Searching for upgrade port.....Detected {COM778} Target model [VOG-L29 10.0.0(C432)] Reading data from server.....OK Bypassing downgrade protection.....Failed: writing failed, Please contact support team Operation {Downgrade to reset FRP} ID: DA9604E22C6F58CA Elapsed time 00:02 -- Version 2.9 |
![]() | #2 (permalink) | |
No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Nov 2017 Location: Russian
Member: 2778414 Status: Offline Thanks Meter: 335 | Quote:
https://easy-firmware.com/index.php?...file&id=250260 | |
![]() | #4 (permalink) |
Member: 52180 Status: Offline Thanks Meter: 43 | Searching for upgrade port.....Detected {COM778} Connecting to device.....OK Start processing file [D:/HUAWEIIIIIIIIIIIIIII/P30 PRO/VOG-L29 10.0.0(C431) Downgrade For FRP Bypass By EFT Pro (AOD)/A.APP] 5,15 GB: Flashing [sha256rsa.img].....OK Flashing [crc.img].....OK Flashing [base_verlist.img].....OK Flashing [base_ver.img].....Failed: Write failed Operation {Flash multi APP files} ID: BD7FBE834E807CB1 Elapsed time 01:44 -- Version 2.9 This always happens when I try to flash like multi APP AOD VOG-L29 10.0.0(C431) Downgrade For FRP Bypass By EFT Pro (AOD). In my opinion, the reason is because the phone is already on VOG-L29 10.1.0.123(C431E19R2P5). |
![]() | #6 (permalink) |
Member: 52180 Status: Offline Thanks Meter: 43 | After OTG update with the same version 10.1.0.123 (lower does not accept) no any news: Searching for upgrade port.....Detected {COM778} Target model [VOG-L29 10.0.0(C431)] Reading data from server.....OK Bypassing downgrade protection.....Failed: writing failed, Please contact support team Operation {Downgrade to reset FRP} ID: DEA2636E4834BC92 Elapsed time 00:02 -- Version 2.9 |
![]() | #8 (permalink) |
Member: 52180 Status: Offline Thanks Meter: 43 | VOG-L29C 10.1.0.123(C431E19R2P5patch02)_Firmware_EMUI10.1.0 _05016DYH.zip this from here: https://forum.xda-developers.com/hua...9-v10-t4032143 |
![]() | #10 (permalink) |
Member: 52180 Status: Offline Thanks Meter: 43 | What is on your site VOG-L29 10.0.0(C431) Downgrade For FRP Bypass By EFT Pro (AOD).EF I don't see there you have a version for downgrade 10.1.0 See please #4 what happens when i try to flash like multi. Last edited by gerovgsm; 06-22-2020 at 12:43. |
