Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Uni-Android Tool - UAT PRO
Old 06-05-2024, 07:25   #1 (permalink)
kiusnga's Avatar
Member: 1917228
Sonork: 100.1645067
Thanks Meter: 290
CET-AL00 do not work with UAT PRO
1. Power off device
2. Press and hold volume up + volume down insert usb cable
3. In some case requires special edl cable or test points
4. Install Qualcomm drivers if needed
- Connection : EDL
- Method : Auto detect
Waiting for QDLoader port... COM36
Connecting to device... OK
Port : COM36 : Qualcomm HS-USB QDLoader 9008
USB : USB\ROOT_HUB30\5&38C3ECE1&0&0
Drivers Info. : Qualcomm Incorporated, qcusbser.sys
Drivers : Qualcomm Technologies, Inc.
Driver Date :
Driver Version :
Waiting for response... OK
Identifying device Mode... OK
Sahara Mode detected
Handshaking... OK
Init Handshake Sequence... OK
Initializing Protocol... OK
Configuring boot... FAILED !
REQUEST_DENIED_FROM_SERVER
PLEASE SELECT MODEL OR CUSTOM LOADER OR REPORT UAT PRO TEAM TO ADD THIS MODEL
UAT PRO : 170.02 | 05 - June - 2024 [ 7:19:01 AM ] DEMOCRATIC REPUBLIC OF THE CONGO
Elapsed Time : 6 seconds
The phone has Huawei id issue.
Old 06-05-2024, 12:39   #2 (permalink)
Mehmood Riaz 1's Avatar
Member: 1737175
Thanks Meter: 10,620
Originally Posted by kiusnga View Post
1. Power off device
- Connection : EDL
Driver Date :
Driver Version :
Handshaking... OK
If you read error message then you need to select either Model from list or need to use custom preloader file.
Old 06-08-2024, 16:21   #3 (permalink)
kiusnga's Avatar
Member: 1917228
Sonork: 100.1645067
Thanks Meter: 290
1. Power off device
- Connection : EDL
- Method : By Model
- Brand : Huawei
- Model : CET-AL00 (Mate 50)
- Process : Remove Huawei ID M1
Driver Date :
Driver Version :
Handshaking... OK
Configuring boot... OK
Version [65537] Code Size [1] Signature Size [55] Header Type [NEW]
Connecting to flash programmer...FAILED
FIREHOSE DOES NOT MATCH WITH THIS DEVICE
UAT PRO : 170.02 | 08 - June - 2024 [ 4:20:15 PM ] UNITED STATES
Elapsed Time : 52 seconds
Old 06-09-2024, 03:53   #4 (permalink)
Member: 1737175
Use Method 2 or contact me on Telegram
Page generated in 0.17333 seconds with 8 queries
