03-30-2021, 11:46 | #1 (permalink) |
No Life Poster Join Date: Apr 2004 Location: POland
Member: 60746 Status: Offline Thanks Meter: 56 | CPH1951 reset problem i have CPH1905 with pattern lock i tried all 3 format ways via meta mode Getting Device Hardware Information... done ==================================== SW VER : MOLY.LR13.R1.TC16.P90.PR2.SP.V1.P84 HW VER : OPPO_P0MP3_K79V1_64_BSP_HW BB CHIP : MT6779 ==================================== Reading system Information... Model : CPH1951 Android Ver. : 9 Android OS : Pie Manufacturer : OPPO Platform : mt6779 CPU : arm64-v8a Security Patch : 2020-04-05 Display id : CPH1951EX_11_A.22 Build Date : PPR1.180610.011 Starting Factory Reset... Factory Reset success Now Reboot device manually to recovery mode by Pressing Volume down + power 1. From Recovery Select Wipe data 2. Enter Verification code 3. Select wipe data options but when i put phone to recovery and tick wipe data - there are still pattern lock - no Verification code |
03-30-2021, 13:06 | #2 (permalink) |
Member: 60746 Status: Offline Thanks Meter: 56 | Connection : Meta Mode Process : Factory Reset | OPPO ==================================== Searching for device... device found MediaTek USB Port_V1632 (COM21) Port : COM21 Mode : BROM Port Instance : USB\VID_0E8D&PID_0003\6&1CB61D14&0&3 Rebooting device into Meta Mode... done Searching for device... MediaTek PreLoader USB VCOM_V1632 (Android) (COM11) Port : COM11 Connecting device into META mode... done Mode : Meta Port Instance : USB\VID_22D9&PID_0006\6&1CB61D14&0&3 Getting Device Hardware Information... done ==================================== SW VER : MOLY.LR13.R1.TC16.P90.PR2.SP.V1.P84 HW VER : OPPO_P0MP3_K79V1_64_BSP_HW BB CHIP : MT6779 ==================================== Reading system Information... Model : CPH1951 Android Ver. : 9 Android OS : Pie Manufacturer : OPPO Platform : mt6779 CPU : arm64-v8a Security Patch : 2020-04-05 Display id : CPH1951EX_11_A.22 Build Date : PPR1.180610.011 Starting Factory Reset... Factory Reset success Rebooting device into recovery. All successfully done still pattern lock |
03-31-2021, 05:36 | #3 (permalink) | |
Product Supporter Join Date: Sep 2016 Location: Pakistan
Member: 2620420 Status: Offline Sonork: 100.1678393 Thanks Meter: 1,295 | Quote:
Plz Select Model Flash Mode Click On Format Tab Post The result Last edited by shahzadqadri; 03-31-2021 at 05:44. | |
03-31-2021, 08:18 | #4 (permalink) |
Member: 60746 Status: Offline Thanks Meter: 56 | 1. Power off device 2. Remove Install battery if needed 3. Connect USB cable to powered off device 4. For New sec. Press and Hold Both Volume keys for Brom Mode 5. For Old sec. Press and Hold Volume UP for Brom Mode 6. Do not press any Key for PreLoader Mode 7. Install drivers if needed ==================================== Connection : Flash Mode Method : By Model Brand : OPPO Model : Reno 2Z (CPH1951) Process : Format | Reset FRP ==================================== Searching for device... Device found MediaTek USB Port_V1632 (COM21) Mode : BROM Port Port : COM21 Preparing Download Agent.. DA : MTK_DOWNLOAD_AGENT - UAT DA Version : MTK_AllInOne_DA_v3.3001.12/30/2020.11:23_545866 Drivers : MediaTek Inc. Driver Version : 01/22/2015,3.0.1504.0 Handshaking... done Loading Preloader... done Connecting to Brom... wait couple of min and nothing happened |
03-31-2021, 08:22 | #5 (permalink) |
Member: 60746 Status: Offline Thanks Meter: 56 | 1. Power off device 2. Remove Install battery if needed 3. Connect USB cable to powered off device 4. For New sec. Press and Hold Both Volume keys for Brom Mode 5. For Old sec. Press and Hold Volume UP for Brom Mode 6. Do not press any Key for PreLoader Mode 7. Install drivers if needed ==================================== Connection : Flash Mode Method : By Model Brand : OPPO Model : Reno 2Z (CPH1951) Process : Format | Factory Reset ==================================== Searching for device... Device found MediaTek USB Port_V1632 (COM21) Mode : BROM Port Port : COM21 Preparing Download Agent.. DA : MTK_DOWNLOAD_AGENT - UAT DA Version : MTK_AllInOne_DA_v3.3001.12/30/2020.11:23_545866 Drivers : MediaTek Inc. Driver Version : 01/22/2015,3.0.1504.0 Handshaking... done Loading Preloader... done Connecting to Brom... the same when i tick Format/FActory Reset |
03-31-2021, 08:28 | #6 (permalink) |
Member: 60746 Status: Offline Thanks Meter: 56 | 1. Power off device 2. Remove Install battery if needed 3. Connect USB cable to powered off device 4. For New sec. Press and Hold Both Volume keys for Brom Mode 5. For Old sec. Press and Hold Volume UP for Brom Mode 6. Do not press any Key for PreLoader Mode 7. Install drivers if needed ==================================== Connection : Flash Mode Method : By Model Brand : OPPO Model : Reno 2Z (CPH1951) Process : Format | Factory Reset ==================================== Searching for device... Device found MediaTek USB Port_V1632 (COM21) Mode : BROM Port Port : COM21 Preparing Download Agent.. DA : MTK_DOWNLOAD_AGENT - UAT DA Version : MTK_AllInOne_DA_v3.3001.12/30/2020.11:23_545866 Drivers : MediaTek Inc. Driver Version : 01/22/2015,3.0.1504.0 Handshaking... done Loading Preloader... done Connecting to Brom... Failed |
03-31-2021, 09:02 | #7 (permalink) | |
03-31-2021, 10:32 | #9 (permalink) |
Member: 60746 Status: Offline Thanks Meter: 56 | Connection : Flash Mode Method : By Model Brand : OPPO Model : Reno 2Z (CPH1951) Process : Format | Reset FRP ==================================== Searching for device... Device found MediaTek USB Port_V1632 (COM21) Port : COM21 Device hw code : 0x766 Device hw sub code : 0x8a00 Device hw version : 0xca00 Device sw version : 0x0 Device secure boot : False Device serial link authorization : False Device download agent authorization : False Disabling watchdog timer : Failed Disabling protection : Failed Error : hw code not found in config. sorry for 3 the same posts |
03-31-2021, 10:53 | #11 (permalink) |
Insane Poster Join Date: Apr 2014
Member: 2175541 Status: Offline Thanks Meter: 24 | 1. Power off device 2. Remove Install battery if needed 3. Connect USB cable to powered off device 4. For New sec. Press and Hold Both Volume keys for Brom Mode 5. For Old sec. Press and Hold Volume UP for Brom Mode 6. Do not press any Key for PreLoader Mode 7. Install drivers if needed ==================================== Connection : Meta Mode Process : Factory Reset | OPPO ==================================== Searching for device... device found MediaTek USB Port (COM16) Port : COM16 Mode : BROM Port Instance : USB\VID_0E8D&PID_0003\8&30EBE09&0&8 Rebooting device into Meta Mode... done Searching for device... USB Serial Device (COM17) Port : COM17 Connecting device into META mode... done Mode : Meta Port Instance : USB\VID_22D9&PID_0006\8&30EBE09&0&8 Getting Device Hardware Information... done ==================================== SW VER : MOLY.LR13.R1.TC16.Q.P90.PR2.SP.V1.P29 HW VER : OPPO_Q0MP1_K79V1_64_BSP_HW BB CHIP : MT6779 ==================================== Reading system Information... Model : CPH1951 Android Ver. : 10 Android OS : Android 10 Q Manufacturer : OPPO Platform : mt6779 CPU : arm64-v8a Security Patch : 2021-01-05 Display id : CPH1951EX_11_C.44 Build Date : QP1A.190711.020 Starting Factory Reset... Factory Reset success Now Reboot device manually to recovery mode by Pressing Volume down + power 1. From Recovery Select Wipe data 2. Enter Verification code 3. Select wipe data options All successfully done DONE VIA META BOOT MODE |
The Following 3 Users Say Thank You to albologna For This Useful Post: |
