Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Uni-Android Tool - UAT PRO
Old 12-29-2023, 17:12   #1 (permalink)
Member: 575293
Thanks Meter: 40
Cricket Nokia C2 TA 1218 FRP Removal and Bootloader Unlock
Ive had this Cricket Nokia TA 1218 on my plate since Feb 2023, Finally got FRP off !!!!
I'm not one to write tutorials but since this phone gave me such a hard time and there are a number of methods I used and programs, so please bare with me as I will link to 2 threads and a YouTube video I'm posting due to the level of difficulty Ive had getting FRP off on this phone.
credit to mvikrant97:
First follow this thread here to load MTK drivers only, I did not use his method to bootloader unlock this device, you can try it if you want to but the MTK client in the thread could not detect my phone. Read further below to see how I bootloader unlocked the device.
https://xdaforums.com/t/bootloader-...-3-nokia-c2-tava-and-nokia-c2-tennen.4640922/
or the driver from this thread here, I'm not sure which worked because the programs were not fully detecting my device
credit to:
skeleton1911 you have to use LibUSB to add the drivers in mvikran97's thread above.
[Guide]Windows 10 MTK VCOM USB Drivers for 32 & 64 bit + Driver install tutorial
Windows 10 MTK VCOM USB Drivers for 32 & 64 bit + Driver install tutorial To determine the version of Windows 10 that you have (32 bit or 64 bit): - Right-click on Start then click on System - In the System window that opens, in System...
xdaforums.com
A program that mvikrant97 has posted from another thread used only to wipe/cache due to hanging startup, after watching my video you'll understand- TFTUnlock
TFTUnlock-2023-3.1.1.2
MediaFire is a simple to use free service that lets you put all your photos, documents, music, and video in a single place so you can access them anywhere and share them everywhere.
www.mediafire.com
For FRP removal and Bootloader unlocking I used a paid program found here:
Uni-Android Tool - Multi Platform Android Tool
Uni Android Tool is A Multi Platform Professional Android Tool , Its A Online Software , to use no need Box or Dongle Just need only Activation .
shop.uni-android.com
Now, due to trial and error and not being entirely sure exactly what worked, after the first FRP bypass attempt I could of used TFTUnlock to wipe cache and saved 15 mins, you can try that and see, if not just follow my video. I wish I can not give you definitive answers because I've tried so many things, but this phone as some may know was said to be impossible to FRP reset or no solution existed online.
Steps taken to Unlock bootloader and erase, reset and remove FRP:
  1. Bootloader - Use UAT Pro to unlock bootloader:
  2. a: Click MediaTek in the services tab
  3. b: choose your device, my device wasnt listed so I selected Nokia TA 1206
  4. c: click Unlock Bootloader permanent MT6765
  5. d: do selected
  6. From here your bootloader should be unlocked
For reset and FRP removal, like I said due to phone hanging at startup, I cant be sure what exactly worked, but try this to see.
  1. Using UAT Pro in the same tab:
  2. a: format , factory reset - USER DATA (this is where the hang started)
  3. b: Open TFT Unlock
  4. c: Open Nokia Tab and select Nokia 2.4 MT6765 Ta-1277
  5. d: Connect in Fastboot mode
  6. e: Click Function Tab
  7. f: click [FB] Wipe Data/Cache
This should fix hanging and phone should boot up!
Congratulations!! You should now have a bootloader unlock FRP free device!!
Heres the link to my video, https://*********/iWacLTHlVMk?si=6EvgRjjnZEVvWttE&fs=1" width="644" height="390">https://*********/iWacLTHlVMk?si=6EvgRjjnZEVvWttE&fs=1" />https://*********/iWacLTHlVMk?si=6EvgRjjnZEVvWttE">http://www.youtube.com/watch?v=https://*********/iWacLTHlVMk?si=6EvgRjjnZEVvWttE
The Following User Says Thank You to cellfonepimp For This Useful Post:
Page generated in 0.13831 seconds with 8 queries
