11-28-2023, 18:45 | #1 (permalink) |
Freak Poster Join Date: Sep 2017 Location: anywhere
Member: 2754769 Status: Offline Thanks Meter: 276 | mate 50 pro failed log with auto detect Code: 1. Power off device 2. Press and hold volume up + volume down insert usb cable 3. In some case requires special edl cable or test points 4. Install Qualcomm drivers if needed ==================================== - Connection : EDL - Method : Auto detect - Process : Remove Huawei ID ==================================== Waiting for QDLoader port ... Port found Device on Port : [ COM6 : Qualcomm HS-USB QDLoader 9008 ] Analyzing Sahara please wait ... HW_ID : 00001000000 BLOCK_ID_S : 000000010000000D0000001000000004 BLOCK_ID_H : 5955555565555555 BLOCK_ID_H : 5Q55555556555555 Executing boot : Code: 1. Power off device 2. Press and hold volume up + volume down insert usb cable 3. In some case requires special edl cable or test points 4. Install Qualcomm drivers if needed ==================================== - Connection : EDL - Method : By Model - Brand : Huawei - Model : DCO-AL00 (Mate 50 Pro) - Process : Remove Huawei ID ==================================== Waiting for QDLoader port ... Port found Device on Port : [ COM6 : Qualcomm HS-USB QDLoader 9008 ] Analyzing Sahara please wait ... Device is in Sahara mode but can't read sahara info Please remove USB from Device and reinsert. Code: 1. Power off device 2. Press and hold volume up + volume down insert usb cable 3. In some case requires special edl cable or test points 4. Install Qualcomm drivers if needed ==================================== - Connection : EDL - Method : By Model - Brand : Huawei - Model : DCO-AL00 (Mate 50 Pro) - Process : Remove Huawei ID ==================================== Waiting for QDLoader port ... Port found Device on Port : [ COM6 : Qualcomm HS-USB QDLoader 9008 ] Analyzing Sahara please wait ... Device is not in Sahara Mode. Trying to connect into firehose mode. Executing boot : Failed Please use correct loader or check USB cable | Port |
