03-07-2023, 13:27 | #1 (permalink) |
Product Supporter Join Date: Mar 2016 Location: Bangladesh
Member: 2548908 Status: Offline Sonork: 100.1672479 Thanks Meter: 761 | Huawei Nova 9 SE JLN-LX1 Huawei ID Remove Done By UAT Pro Code: 1. Power off device 2. Press and hold volume up + volume down insert usb cable 3. In some case requires special edl cable or test points 4. Install Qualcomm drivers if needed ==================================== - Connection : EDL - Method : Auto detect - Process : Remove Huawei ID ==================================== Waiting for QDLoader port ... Port found Device on Port : [ COM13 : Qualcomm HS-USB QDLoader 9008 ] Analyzing Sahara please wait ... HW_ID : 0001E08B100 BLOCK_ID_S : 61B4E9C9 BLOCK_ID_H : O70QRPQ30Q762S0Q4O08QP8P97RS2391 BLOCK_ID_H : QPRS04QQ8R5NS9Q67151644S0544SS78 Executing boot : DONE Version : 6 Code Size : 816 Signature Size : 512 Header Type : NEW FhVendor : QUALCOMM HW ID : 000000000015006D SW ID : 00000003 OEM ID : 0015 Vendor : HUAWEI Model ID : 006D APP ID : 00000000 Pk Hash : B25DECD85D217F5D9B53DC3C42EF7846DCEF59DD3E0AF4D12606199F5099FF23 Configuring : DONE Reading Parts : DONE Capacity : 14.75 GB Userdata : 13.6 GB Reading GPT : DONE Partition Count : 76 MEM_TYPE : UFS Max_Payload_Size_InBytes : 1048576 Max_Payload_Size_Supp. : 1048576 Max_XML_Size : 4096 Version : 1 Date_Time : Mar 11 2022 - 18:36:43 Userdata : Encrypted Processing Huawei id data ... Process done Prepairing id data please wait.... Data prepairation done Analyzing data in ... Removing Huawei id ... Huawei ID remove done Setting up device please wait... Device setup done 1. If Huawei ID is not removed 2. Please press and hold volume up + power to goto recovery 3. Wipe cache / userdata or wipe all data from recovery and reboot. 4. First startup may take few minutes to power on UAT PRO : 151.02 | 07 - March - 2023 [ 2:07:27 PM ] Elapsed Time : 12 seconds |
The Following User Says Thank You to nobichanmaruf For This Useful Post: |
