Register | FAQ | Donate | Forum Rules | Root any Device | ★iPhone Unlock★ | [ Easy-JTAG ] | Direct Unlock Source | Search | Today's Posts | Mark Forums Read |
![]() | #1 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: May 2004 Age: 53
Member: 65145 Status: Offline Sonork: skype: hristo_el1 Thanks Meter: 3 | Huawei nova 9SE after remove Huawei ID security chip damaged [SOLVED] How can fix this problem Thanks |
![]() | #2 (permalink) | |
No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Apr 2016 Location: OneTheWay
Member: 2554807 Status: Offline Thanks Meter: 606 | already Supported on UAT Quote:
Release Notes: [ADDED] - ONE CLICK HUAWEI HONOR FIX DAMAGED CHIP No need of erase oeminfo, No need to write persist, No need multi reboots and bla bla .. just one click | |
![]() | #3 (permalink) | |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Feb 2008 Location: Cavite,Philippines
Member: 710668 Status: Offline Thanks Meter: 116 | Quote:
WHAT ABOUT YOU " hrito5 " did it solve your problem? Last edited by nhoy'sbarage; 01-11-2023 at 02:08. | |
![]() | #4 (permalink) | |
Junior Member ![]() ![]() Join Date: Oct 2004 Age: 53
Member: 85100 Status: Offline Thanks Meter: 15 | Quote:
1. Power off device 2. Press and hold volume up + volume down insert usb cable 3. In some case requires special edl cable or test points 4. Install Qualcomm drivers if needed ==================================== - Connection : EDL - Method : By Model - Brand : Huawei - Model : JLN-LX3 (Nova 9 SE) - Process : Remove Huawei ID ==================================== Waiting for QDLoader port ... Port found Device on Port : [ COM53 : Qualcomm HS-USB QDLoader 9008 ] Analyzing Sahara please wait ... HW_ID : 0001E08B100 BLOCK_ID_S : 18452D48 BLOCK_ID_H : O70QRPQ30Q762S0Q4O08QP8P97RS2391 BLOCK_ID_H : QPRS04QQ8R5NS9Q67151644S0544SS78 Executing boot : DONE Version : 6 Code Size : 816 Signature Size : 512 Header Type : NEW FhVendor : QUALCOMM HW ID : 000000000015006D SW ID : 00000003 OEM ID : 0015 Vendor : HUAWEI Model ID : 006D APP ID : 00000000 Pk Hash : B25DECD85D217F5D9B53DC3C42EF7846DCEF59DD3E0AF4D126 06199F5099FF23 Configuring : DONE Reading Parts : DONE Capacity : 14,75 GB Userdata : 13,67 GB Reading GPT : DONE Partition Count : 76 MEM_TYPE : UFS Max_Payload_Size_InBytes : 1048576 Max_Payload_Size_Supp. : 1048576 Max_XML_Size : 4096 Version : 1 Date_Time : Mar 11 2022 - 18:36:43 Userdata : Encrypted Processing Huawei id data ... Process done Prepairing id data please wait.... Data prepairation done Patching Huawei id ... Huawei ID Patch done Setting up device please wait... Device setup done 1. If Huawei ID is not removed 2. Please press and hold volume up + power to goto recovery 3. Wipe cache / userdata or wipe all data from recovery and reboot. 4. First startup may take few minutes to power on UAT PRO : 150.01 | 12 - január - 2023 [ 19:26:59 ] Elapsed Time : 10 seconds After remove Huawei id chip is damaged Repair not work 1. Power off device 2. Press and hold volume up + volume down insert usb cable 3. In some case requires special edl cable or test points 4. Install Qualcomm drivers if needed ==================================== - Connection : EDL - Method : By Model - Brand : Huawei - Model : JLN-LX3 (Nova 9 SE) - Process : Honor Fix Chip Damage ==================================== Waiting for QDLoader port ... Port found Device on Port : [ COM53 : Qualcomm HS-USB QDLoader 9008 ] Analyzing Sahara please wait ... HW_ID : 0001E08B100 BLOCK_ID_S : 18452D48 BLOCK_ID_H : O70QRPQ30Q762S0Q4O08QP8P97RS2391 BLOCK_ID_H : QPRS04QQ8R5NS9Q67151644S0544SS78 Executing boot : DONE Version : 6 Code Size : 816 Signature Size : 512 Header Type : NEW FhVendor : QUALCOMM HW ID : 000000000015006D SW ID : 00000003 OEM ID : 0015 Vendor : HUAWEI Model ID : 006D APP ID : 00000000 Pk Hash : B25DECD85D217F5D9B53DC3C42EF7846DCEF59DD3E0AF4D126 06199F5099FF23 Configuring : DONE Reading Parts : DONE Capacity : 14,75 GB Userdata : 13,67 GB Reading GPT : DONE Partition Count : 76 MEM_TYPE : UFS Max_Payload_Size_InBytes : 1048576 Max_Payload_Size_Supp. : 1048576 Max_XML_Size : 4096 Version : 1 Date_Time : Mar 11 2022 - 18:36:43 Userdata : Encrypted Processing data from device ... Process done Prepairing data please wait.... Data prepairation done Checking damaged data in device ... Error : data not found UAT PRO : 150.01 | 12 - január - 2023 [ 19:25:34 ] Elapsed Time : 7 seconds | |
![]() | #5 (permalink) | |
