03-28-2024, 18:09 | #1 (permalink) |
No Life Poster Join Date: Apr 2013 Location: DRC KINSHASA
Member: 1917228 Status: Offline Sonork: 100.1645067 Thanks Meter: 290 | Huawei NTH-NX9 demo failed on new update [SOLVED] - Method : By Model - Brand : Huawei - Model : NTH-NX9 (HONOR 50) - Process : Huawei Remove Demo ==================================== Waiting for QDLoader port... COM17 Connecting to device... OK Port : COM17 : Qualcomm HS-USB QDLoader 9008 USB : USB\VID_0403&PID_6001\AL007RY9 Drivers Info. : Qualcomm Incorporated, qcusbser.sys Drivers : Qualcomm Technologies, Inc. Driver Date : Driver Version : Waiting for response... OK Identifying device Mode... OK [Sahara Mode] Handshaking...OK Init Handshake Sequence... OK Initializing Protocol... OK Serial : 095D9A50 SoC : [Snapdragon 778G] Target : [SDM680] HWID : [0X001920E1] PKhash [0] : AD5B862DFA03DBFAD2EAB816A259183E PKhash [1] : DDACB346799833D781DE8321DE553657 Configuring boot... OK Version [6] Code Size [816] Signature Size [512] Header Type [NEW] OEM ID [01A4] Connecting to flash programmer...OK Chipset Type... 64 bit Chipset Initializing connection... OK Configuring device... OK Firehose config : UFS [Sector:4096] [Target:0] [Host:1048576] Reading partition map... OK - LU Count : 6 Reading partition table... OK [152] Processing demo data... OK Prepairing data please wait.... Data prepairation done Removing demo please wait ... FAILED : Demo remove failed UAT PRO : 165.02 | 28 - March - 2024 [ 6:03:07 PM ] Elapsed Time : 6 minutes 20 seconds P.S:Worked fined on previous update |
03-29-2024, 16:26 | #4 (permalink) |
Member: 1917228 Status: Offline Sonork: 100.1645067 Thanks Meter: 290 | Done by Upcoming Update 1. Power off device 2. Press and hold volume up + volume down insert usb cable 3. In some case requires special edl cable or test points 4. Install Qualcomm drivers if needed ==================================== - Connection : EDL - Method : Auto detect - Process : Huawei Remove Demo ==================================== Waiting for QDLoader port... COM3 Connecting to device... OK Port : COM3 : Qualcomm HS-USB QDLoader 9008 USB : BTH\MS_RFCOMM\6&69EECD6&0&0 Drivers Info. : Qualcomm Incorporated, qcusbser.sys Drivers : Qualcomm Technologies, Inc. Driver Date : 03/19/2014 Driver Version : 2.1.1.2 Waiting for response... OK Identifying device Mode... OK [Sahara Mode] Handshaking...OK Init Handshake Sequence... OK Initializing Protocol... OK Serial : 6D44DEC7 SoC : [Snapdragon 778G] Target : [SDM680] HWID : [0X001920E1] PKhash [0] : AD5B862DFA03DBFAD2EAB816A259183E PKhash [1] : DDACB346799833D781DE8321DE553657 Configuring boot... OK Version [6] Code Size [816] Signature Size [512] Header Type [NEW] OEM ID [01A4] Connecting to flash programmer...OK Chipset Type... 64 bit Initializing connection... OK Configuring device... OK Firehose config : UFS [Sector:4096] [Target:0] [Host:1048576] Reading partition map... OK - LU Count : 6 Reading partition table... OK [146] Processing demo data... OK Prepairing data please wait.... Data prepairation done Removing demo please wait ... Demo remove done UAT PRO : 166.01 | 29 - March - 2024 [ 4:22:53 PM ] DEMOCRATIC REPUBLIC OF THE CONGO Elapsed Time : 1 minutes 58 seconds |
