Huawei Y7 Prime 2018 LDN L21 FRP Remove Testpoints LDN-L21 8.0.0.166 https://dc555.4shared.com/img/R7fB5V...-2023_17-39-21 https://dc555.4shared.com/img/45iLkp...a46d70/f0UgSQz Waiting fastboot device ... Device found Reading device Info ... Device Model : LDN-L21 Device Firmware : LDN-L21 8.0.0.166(C185) Country : MIDDLE EAST and AFRICA Current Status : RISK Image : origin Verify Mode : enforcing Root Info. : risk Lock State : LOCK Root State : ROOT Serial Number : 26EBB18716151296 Device IMEI : 864009049118017 FB Lock : LOCK FRP Unlock : LOCK Device tampered : False Device unlocked : False Device critical unlocked : False Charger screen enabled : False 1. Power off device 2. Press and hold volume up + volume down insert usb cable 3. In some case requires special edl cable or test points 4. Install Qualcomm drivers if needed ==================================== - Connection : EDL - Method : By Model - Brand : Huawei - Model : LDN-L21 (Y7 Prime 2018) - Process : Reset FRP ==================================== Waiting for QDLoader port ... Port found Device on Port : [ COM19 : Qualcomm HS-USB QDLoader 9008 ] Analyzing Sahara please wait ... HW_ID : 0001E0F4000 | Snapdragon 430 BLOCK_ID_S : B82E33F2 BLOCK_ID_H : 1OP814066QN4PNQO8N2NS16029S34QO8 BLOCK_ID_H : 30558Q1796OQQ6SS028QON16OS1NR664 Executing boot : DONE Version : 3 Code Size : 288 Signature Size : 256 Header Type : OLD FhVendor : QUALCOMM HW ID : 0004F0E100150041 SW ID : 0000000000000003 OEM ID : 0015 Vendor : HUAWEI Model ID : 0041 Pk Hash : CF4C483C77ACE109941508B766EF82E15DF69B90BC9E7A67E3 BA17B88D8F1989 OEM Version : SIA1000073869 Image Variant : FAADANAZA Qc Version : BOOT.BF.3.3-00221 Configuring : DONE Reading Parts : DONE Capacity : 29.12 GB Userdata : 24.81 GB Reading GPT : DONE Partition Count : 55 Drivers : Qualcomm Technologies, Inc. Driver Version : 05/29/2019,2.1.3.7 MEM_TYPE : eMMC Max_Payload_Size_InBytes : 16384 Max_Payload_Size_Supp. : 16384 Max_Bytes : 4096 Max_XML_Size : 4096 Version : 1 Target_Name : [MSM 8937] Userdata : Encrypted Reading Device Information... Android Ver. : 8.0.0 CPU : arm64-v8a Android OS : Oreo Display id : System 8.0.0.073(091T) Build Date : Tue Feb 25 18:12:27 CST 2020 Build id : OPR6.170623.013 Security Patch : 2020-02-01 Manufacturer : unknown Local lang. : en-US GsmVersion : 8.0_201812 Searching FRP Data.... Frp data found Resetting frp.... Reset frp success UAT PRO : 150.01 | 13 - كانون*الثاني - 2023 [ 05:36:55 م ] Elapsed Time : 12 seconds |
