02-06-2023, 15:55 | #1 (permalink) |
Insane Poster Join Date: Jun 2016 Location: gsmworld
Member: 2587446 Status: Offline Thanks Meter: 35 | lge-nx9 honor magic 4 pro Code: 1. Power off device 2. Press and hold volume up + volume down insert usb cable 3. In some case requires special edl cable or test points 4. Install Qualcomm drivers if needed ==================================== - Connection : EDL - Method : By Model - Brand : Huawei - Model : LGE-NX9 (Honor Magic 4 Pro) - Process : Reset FRP ==================================== Waiting for QDLoader port ... Port found Device on Port : [ COM66 : Qualcomm HS-USB QDLoader 9008 ] Analyzing Sahara please wait ... Device is not in Sahara Mode. Trying to connect into firehose mode. Executing boot : Error : Unknown |
02-06-2023, 16:34 | #2 (permalink) |
Member: 2587446 Status: Offline Thanks Meter: 35 | when chek auto detect model also without remove TP i get this error Code: 1. Power off device 2. Press and hold volume up + volume down insert usb cable 3. In some case requires special edl cable or test points 4. Install Qualcomm drivers if needed ==================================== - Connection : EDL - Method : Auto detect - Process : Reset FRP ==================================== Waiting for QDLoader port ... Port found Device on Port : [ COM66 : Qualcomm HS-USB QDLoader 9008 ] Analyzing Sahara please wait ... HW_ID : 00001000000 BLOCK_ID_S : 00000432A4CA2933 BLOCK_ID_H : 5955555565555555 BLOCK_ID_H : 5Q55555556555555 Executing boot : Failed Please use correct loader or check USB cable | Port |
02-06-2023, 17:16 | #3 (permalink) |
Product Manager Join Date: Mar 2012 Location: Some Where
Member: 1737175 Status: Offline Sonork: 100.1667675 Thanks Meter: 10,465 | There is problem with this specific Model .. even after detecting it on 9008 Port it does not create Sahara .. Either the Test points are not correct or it is by default Sahara blocked. |
03-24-2024, 21:29 | #4 (permalink) |
No Life Poster Join Date: Jun 2015 Location: the planet earth
Member: 2406539 Status: Offline Thanks Meter: 100 | please add huawei magic 4 pro 5g frp remove, thanks 1. Power off device 2. Press and hold volume up + volume down insert usb cable 3. In some case requires special edl cable or test points 4. Install Qualcomm drivers if needed ==================================== - Connection : EDL - Method : Auto detect - Process : Reset FRP | Erase Method ==================================== Waiting for QDLoader port... COM85 Connecting to device... OK Port : COM85 : Qualcomm HS-USB QDLoader 9008 USB : USB\ROOT_HUB30\4&37E29E7&0&0 Drivers Info. : Qualcomm Incorporated, qcusbser.sys Drivers : Qualcomm Technologies, Inc. Driver Date : 12/17/2018 Driver Version : 2.1.3.5 Waiting for response... OK Identifying device Mode... OK [Sahara Mode] Handshaking...OK Init Handshake Sequence... OK Initializing Protocol... OK Configuring boot... FAILED ! REQUEST_DENIED_FROM_SERVER PLEASE SELECT MODEL OR CUSTOM LOADER OR REPORT UAT PRO TEAM TO ADD THIS MODEL Elapsed Time : 21 seconds |
The Following User Says Thank You to TMAC1122 For This Useful Post: |
