Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Uni-Android Tool - UAT PRO
Old 01-05-2022, 17:49   #1 (permalink)
Punto-Móvil's Avatar
Member: 1147852
Thanks Meter: 587
Oppo a54 format and frp done
OPPO A54 FORMAT ANF FRP REMOVE DONE
INSTALL LIBUSB AND FILTER FOR MTK PORT
DUMP PRELOADER FROM SAME PHONE WITH UAT PRO ( SERVICES : 4TH COLUMN )
FILL IT IN PRELOADER TAB ( IF NOT WILL GIVE YOU ERROR )
THICK AUTOBYPASS AND AUTOSELECT MODEL
IF FRP STILL EXISTS TRY AGAIN WITH FRP REMOVE OPTION FROM MENU
1. Power off device
2. Remove Install battery if needed
3. Connect USB cable to powered off device
4. For New sec. Press and Hold Both Volume keys for Brom Mode
5. For Old sec. Press and Hold Volume UP for Brom Mode
6. Do not press any Key for PreLoader Mode
7. Install drivers if needed
- Connection : Flash Mode
- Method : Auto detect
- Process : Format | Reset FRP
Authenticating ... DONE
Initializing ... DONE
Waiting for device ...
Device found
MediaTek PreLoader USB VCOM (Android) (COM17)
Mode : BootRom
Port : COM17
Handshaking ... DONE
Initializing : DONE
Hw code: MT6765 - Helio P35/G35
Hw sub code: 8A00
Hw version: CA00
Sw version: 0000
Watchdog disable ... DONE
Protection disable ... DONE
Preparing Download Agent ...
DA Version : MTK_AllInOne_DA_v3.3001.12/30/2020.11:23_545866
Drivers : MediaTek Inc.
Driver Date : 11/06/2014
Driver Version : 2.0.1136.0
Handshaking : DONE
Loading Preloader : DONE
Booting device : DONE
Chip name : [MT6765]
Syncing with DA : DONE
Identifying Hardware ID ...
ChipID : MT6765
Software Ver : 0000
Hardware Ver : CA00
Secure Ver : 00
BootLdr Ver : 00
Ext RAM : 0x100000000
SRAM : 0x0003A000
Storage : 0x1D20400000
RAM Size : 4.000 GB
SRAM Size : 232.000 KB
Storage Size : 116.504 GB
Storage Type : EMMC
Getting partition details : DONE
Partition count : 47
Searching for required data... DONE
Formatting device ... DONE
Searching for frp data... DONE
Resetting FRP...
USING ALGO - 1
Reset FRP DONE
Please disconnect device and reboot it manually
If device stuck on Logo, please use recovery to wipe it and reboot
UAT PRO : 135.02 | 05 - January - 2022 [ 5:35:28 PM ]
Elapsed Time : 10 seconds
The Following 3 Users Say Thank You to Punto-Móvil For This Useful Post:
Page generated in 0.10407 seconds with 8 queries
