Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Uni-Android Tool - UAT PRO
Old 06-07-2024, 08:03   #1 (permalink)
Member: 1210902
Thanks Meter: 317
Talking OPPO a74 format perfect
1. Power off device
2. Press and hold volume up + volume down insert usb cable
3. In some case requires special edl cable or test points
4. Install Qualcomm drivers if needed
- Connection : EDL
- Method : By Model
- Brand : Oppo
- Model : CPH2219 (Oppo A74)
- Process : Format | OPPO - New Sec
Waiting for QDLoader port... COM17
Connecting to device... OK
Port : COM17 : Qualcomm HS-USB QDLoader 9008
USB : PCI\VEN_8086&DEV_27B8&SUBSYS_0DF2105B&REV_01\3&241 1E6FE&0&F8
Drivers Info. : Qualcomm Incorporated, qcusbser.sys
Drivers : Qualcomm Technologies, Inc.
Driver Date : 12/17/2018
Driver Version : 2.1.3.5
Waiting for response... OK
Identifying device Mode... OK
Firehose Mode detected
Handshaking... OK
Chipset Type... 64 bit
Initializing connection... OK
Configuring device... OK
Firehose config : UFS [Sector:4096] [Target:0] [Host:1048576]
Reading partition map... OK - LUN Count : 6
Requesting server... OK
Reading data... OK
Erasing USERDATA [OPPO Method]... OK
UAT PRO : 170.02 | 07 - Haziran - 2024 [ 10:02:17 ] TURKEY
Elapsed Time : 4 seconds
The Following User Says Thank You to master353535 For This Useful Post:
Old 06-07-2024, 08:11   #2 (permalink)
Member: 1210902
Thanks Meter: 317
frp perfect
1. Power off device
- Connection : EDL
- Method : By Model
- Brand : Oppo
- Process : Reset FRP | OPPO - New Sec
Sahara Mode detected
Handshaking... OK
Init Handshake Sequence... OK
Initializing Protocol... OK
Serial : B8B96611 SoC : [Snapdragon 662] Target : [SM6115]
HWID : [0X0014D0E1]
PKhash [0] : 49445E14621312DFECCD4389F267E6B7
PKhash [1] : 1674DDD36B1BC41D1F605AA991D14AD6
Configuring boot... OK
Version [6] Code Size [816] Signature Size [256] Header Type [NEW]
Connecting to flash programmer...OK
Reading data... OK
Erasing FRP [OPPO Method]... OK
UAT PRO : 170.02 | 07 - Haziran - 2024 [ 10:11:32 ] TURKEY
Elapsed Time : 14 seconds
Page generated in 0.12862 seconds with 8 queries
