08-31-2022, 07:03 | #3751 (permalink) |
Product Supporter Join Date: Mar 2016 Location: Bangladesh
Member: 2548908 Status: Offline Sonork: 100.1672479 Thanks Meter: 765 | Samsung M215F FRP Remove Done By UAT Pro Code: Waiting for MTP port ... Device found Port : [ COM102 : SAMSUNG Mobile USB Modem ] Reading device info. ... Brand : Samsung Electronics Co., Ltd. Model : SM-M215F Country : BKD SW Version : M215FXXU2CVCC/M215FODM2CVCC/M215FDDU2CVCC/M215FXXU2CVCC HW Version : M215FXXU2CVCC MNC : 02, MCC : 470, Serial : R58N626A4WB IMEI : 353646370075387 Unqiue Code : CE032043C5708316057E Connection : AT,MTP Read Info done Enabling ADB .... ADB Enabled done Please check confirmation dialog on your device screen and allow it Waiting for adb device ... Device found Model : SM-M215F Manufucture : samsung Android Version : 12 CPU : arm64-v8a Platform : exynos9611 Hardware : exynos9611 Board : exynos9611 Bootloader : M215FXXU2CVCC USB Config : mtp,adb User : dpi Baseband : M215FDDU2CVCC,M215FDDU2CVCC Display ID : SP1A.210812.016.M215FXXU2CVCC Build ID : SP1A.210812.016 PDA : M215FXXU2CVCC SIM State : ABSENT,ABSENT Product Code : SM-M215FZKDBKD Soft Version : M215FDDU2CVCC Build Date : Tue Mar 29 23:33:30 KST 2022 Build Tags : release-keys Country Code : Bangladesh Network Type : Unknown,Unknown LCD Density : 420 Data Encryption : encrypted Device IMEI : Checking Root : Not Rooted Resetting frp please wait ... Reset frp done UAT PRO : 143.02 | 24 - August - 2022 [ 3:26:35 AM ] Elapsed Time : 8 seconds |
08-31-2022, 07:09 | #3752 (permalink) |
Member: 2548908 Status: Offline Sonork: 100.1672479 Thanks Meter: 765 | Samsung A750F FRP Remove Done By UAT Pro Samsung A750F FRP Remove Done By UAT Pro Code: Waiting for MTP port ... Device found Port : [ COM106 : SAMSUNG Mobile USB Modem ] Reading device info. ... Brand : Samsung Electronics Co., Ltd. Model : SM-A750F Country : BRUNEI SW Version : A750FXXU4CTBC/A750FODM4CTBC/A750FNXXU4CTBA/A750FXXU4CTBC HW Version : A750FXXU4CTBC MNC : 01,03 MCC : 470,470 Serial : RZ8KA2F0RMF IMEI : 351578103889853 Unqiue Code : CCU006DF3BA9F95 Connection : AT,MTP Read Info done Enabling ADB .... ADB Enabled done Please check confirmation dialog on your device screen and allow it Waiting for adb device ... Device found Model : SM-A750F Manufucture : samsung Android Version : 10 CPU : arm64-v8a Platform : exynos7885 Hardware : exynos7885 Board : exynos7885 Bootloader : A750FXXU4CTBC USB Config : mtp,adb User : dpi Baseband : A750FNXXU4CTBA,A750FNXXU4CTBA Display ID : QP1A.190711.020.A750FXXU4CTBC Build ID : QP1A.190711.020 PDA : A750FXXU4CTBC SIM State : LOADED,LOADED Product Code : SM-A750FZBDBNG Serial No. : RZ8KA2F0RMF Soft Version : A750FNXXU4CTBA Build Date : Fri Feb 28 21:49:44 KST 2020 Build Tags : release-keys Country Code : Bangladesh Network Type : LTE,LTE SIM Operator : GramenPhone,Banglalink LCD Density : 420 Data Encryption : encrypted Device IMEI : 351578103889853 Checking Root : Not Rooted Resetting frp please wait ... Reset frp done UAT PRO : 143.02 | 24 - August - 2022 [ 3:32:12 AM ] Elapsed Time : 7 seconds |
08-31-2022, 14:28 | #3757 (permalink) |
Member: 2548908 Status: Offline Sonork: 100.1672479 Thanks Meter: 765 | Oppo F9 Pro (CPH1823) Password+FRP Remove Done By UAT Pro Oppo F9 Pro (CPH1823) Password+FRP Remove Done By UAT Pro Code: 1. Power off device 2. Remove Install battery if needed 3. Connect USB cable to powered off device 4. For New sec. Press and Hold Both Volume keys for Brom Mode 5. For Old sec. Press and Hold Volume UP for Brom Mode 6. Do not press any Key for PreLoader Mode 7. Install drivers if needed ==================================== - Connection : Flash Mode - Method : By Model - Brand : OPPO - Model : Oppo F9 Pro (CPH1823) - Process : Format | Factory Reset ==================================== Authenticating ... DONE Initializing ... DONE ==================================== Waiting for device ... Device found MediaTek USB Port_V1632 (COM83) Mode : BootRom Port : COM83 Handshaking ... DONE Initializing : DONE Hw code: MT6771 - Helio P60/P70/G80 Hw sub code: 8A00 Hw version: CA00 Sw version: 0000 Watchdog disable ... DONE Protection disable ... DONE Preparing Download Agent ... DA Version : MTK_AllInOne_DA_v3.3001.12/30/2020.11:23_545866 Drivers : MediaTek Inc. Driver Date : 01/22/2015 Driver Version : 3.0.1504.0 Handshaking : DONE Loading Preloader : DONE Booting device : DONE Chip name : [MT6771] Syncing with DA : DONE Identifying Hardware ID ... ==================================== ChipID : MT6771 Software Ver : 0000 Hardware Ver : CA00 Secure Ver : 00 BootLdr Ver : 00 Ext RAM : 0x180000000 SRAM : 0x00039000 Storage : 0x0E91000000 ==================================== RAM Size : 6.000 GB SRAM Size : 228.000 KB Storage Size : 58.266 GB Storage Type : EMMC ==================================== Getting partition details : DONE Partition count : 46 Reading system Information... Android Ver. : 10 Android OS : Android 10 Q CPU : arm64-v8a Display id : QP1A.190711.020 release-keys Build Date : Tue Jan 26 23:23:39 CST 2021 Build id : QP1A.190711.020 Security Patch : 2021-02-05 Product : oppo6771 Local lang. : en-US Searching for required data... DONE Formatting device ... DONE All successfully done Please disconnect device and reboot it manually If device stuck on Logo, please use recovery to wipe it and reboot UAT PRO : 144.01 | 31 - August - 2022 [ 4:38:28 PM ] Elapsed Time : 29 seconds |
09-02-2022, 03:54 | #3758 (permalink) |
No Life Poster Join Date: May 2008
Member: 772651 Status: Offline Thanks Meter: 1,695 | Realme C21Y (RMX3263) format and FRp done UAT PRO 1. Device must be Power off with battery inside 2. Press and Hold VOl-, or some phones requires press and hold VOl- and VOL+ together 3. Insert usb cable 4. Install spd drivers if needed ==================================== - Connection : Flash Mode - Brand : RealMe - Model : Realme C21Y (RMX3263) - Process : Format | FRP ==================================== Waiting for device port ... Port found Port : [ COM7 : SPRD U2S Diag ] Handshaking with device ... Handshake done Protocol : SPRD3 Detected SoC : Unisoc Tiger T610 Sending config : OK Sending Boot [UAT PRO.boot1] : DONE Sending Boot [UAT PRO.boot2] : DONE BootVersion : Spreadtrum Boot Block version 1.1 Reseting Frp please wait ... Reset Frp done Formatting Userdata please wait ... Format userdata done UAT PRO : 144.02 | 02 - September - 2022 [ 8:21:10 AM ] Elapsed Time : 57 seconds |
09-06-2022, 13:40 | #3763 (permalink) |
Product Supporter Join Date: Sep 2016 Location: Pakistan
Member: 2620420 Status: Offline Sonork: 100.1678393 Thanks Meter: 1,297 | OPPO A3s CPH-1803 Screen Lock Reset Without Data Loss Done BY UAT PRO OPPO A3s CPH-1803 Screen Lock Reset Without Data Loss Done BY .:: UAT PRO ::. |
09-06-2022, 17:21 | #3764 (permalink) |
Freak Poster Join Date: Jan 2008 Location: RO-HD
Member: 668010 Status: Offline Thanks Meter: 119 | JLN-LX1 (Nova 9 SE) Remove Huawei ID Done BY UAT PRO - Connection : EDL - Method : By Model - Brand : Huawei - Model : JLN-LX1 (Nova 9 SE) - Process : Remove Huawei ID ==================================== Waiting for QDLoader port ... Port found Device on Port : [ COM10 : Qualcomm HS-USB QDLoader 9008 ] Analyzing Sahara please wait ... HW_ID : 0001E08B100 BLOCK_ID_S : 24895E3A BLOCK_ID_H : O70QRPQ30Q762S0Q4O08QP8P97RS2391 BLOCK_ID_H : QPRS04QQ8R5NS9Q67151644S0544SS78 Executing boot : Done Configuring : Done Reading Parts : Done Capacity : 14.75 GB Userdata : 13.67 GB Partition Count : 76 MEM_TYPE : UFS Max_Payload_Size_InBytes : 1048576 Max_Payload_Size_Supp. : 1048576 Max_XML_Size : 4096 Version : 1 Date_Time : Mar 11 2022 - 18:36:43 Userdata : Encrypted Processing Huawei id data ... Process done Prepairing id data please wait.... Data prepairation done Patching Huawei id ... Huawei ID Patch done Setting up device please wait... Device setup done 1. If Huawei ID is not removed 2. Please press and hold volume up + power to goto recovery 3. Wipe cache / userdata or wipe all data from recovery and reboot. 4. First startup may take few minutes to power on UAT PRO : 144.02 | 06 - September - 2022 [ 12:24:44 ] Elapsed Time : 5 seconds |
