Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Uni-Android Tool - UAT PRO
Old 07-05-2024, 13:58   #4111 (permalink)
CHIEF OF GSM's Avatar
Member: 2750997
Sonork: 100.1678720
Thanks Meter: 1,280
Oppo A3S CPH1803 One click format+frp done by UAT PRO
1. Power off device
2. Press and hold volume up + volume down insert usb cable
3. In some case requires special edl cable or test points
4. Install Qualcomm drivers if needed
- Connection : EDL
- Method : By Model
- Brand : Oppo
- Model : CPH1803 (Oppo A3S)
- Process : Format | FRP - Safe
Waiting for QDLoader port... COM70
Connecting to device... OK
Port : COM70 : Qualcomm HS-USB QDLoader 9008
USB : USB\ROOT_HUB30\4&1CDEB120&0&0
Drivers Info. : Qualcomm Incorporated, qcusbser.sys
Drivers : Qualcomm Technologies, Inc.
Driver Date : 08/02/2017
Driver Version : 2.1.2.7
Waiting for response... OK
Identifying device Mode... OK
Sahara Mode detected
Handshaking... OK
Init Handshake Sequence... OK
Initializing Protocol... OK
Serial : 221D7C32 SoC : [Snapdragon 450] Target : [MSM 8953]
HWID : [0X0009A0E1]
PKhash [0] : 2440693284962AE0DC5F8534D2E131C3
PKhash [1] : 252C1C42F8E89019B9F1B4188731CA6F
Configuring boot... OK
Connecting to flash programmer...OK
Initializing connection... OK
Configuring device... OK
Firehose config : eMMC [Sector:512] [Target:4096] [Host:1048576]
Reading partition map... OK - LUN Count : 1
Reading partition table.. OK [63]
CPU : arm64-v8a
Host : CP-ubuntu-123
eMMC Size : 16GB
Local lang : zh-CN
Manufacturer : OPPO
Android Version : 8.1.0
Android OS : Oreo
Security Patch : 2020-08-05
Factory Reset Format [Safe Method]... OK
Resetting FRP
[Erase Method]... OK
UAT PRO : 172.01 | 05 - July - 2024 [ 4:22:17 PM ] PAKISTAN
Elapsed Time : 8 seconds
Old 07-19-2024, 11:17   #4112 (permalink)
Member: 2750997
Sonork: 100.1678720
Thanks Meter: 1,280
SM-F731U BIT4 (Galaxy Z Flip5) Reset FRP done by UAT PRO
1. Power off device
- Connection : EDL
- Method : By Model
- Brand : SAMSUNG
- Model : SM-F731U BIT4 (Galaxy Z Flip5)
- Process : Reset FRP - SAMSUNG
Waiting for QDLoader port... COM33
Port : COM33 : Qualcomm HS-USB QDLoader 9008
Driver Date : 12/17/2018
Driver Version : 2.1.3.5
Handshaking... OK
Chipset Type... 64 bit
Firehose config : UFS [Sector:4096] [Target:0] [Host:1048576]
Reading partition map... OK - LUN Count : 6
Reading partition table.. OK [92]
Resetting FRP... OK
UAT PRO : 172.01 | 19 - July - 2024 [ 2:43:28 PM ] PAKISTAN
Elapsed Time : 14 seconds
Old 07-25-2024, 06:15   #4113 (permalink)
Member: 2750997
Sonork: 100.1678720
Thanks Meter: 1,280
POCO C61 userdata format + FRP done by UAT PRO
Reported by UAT PRO user
Old 07-25-2024, 06:40   #4114 (permalink)
Member: 2750997
Sonork: 100.1678720
Thanks Meter: 1,280
Vivo V11 format+Frp done by UAT PRO
Old 07-25-2024, 13:27   #4115 (permalink)
Member: 2750997
Sonork: 100.1678720
Thanks Meter: 1,280
Thumbs up Huawei P Smart 2019 Frp Reset Done By UAT PRO
Old 01-28-2025, 10:18   #4116 (permalink)
Member: 3065224
Thanks Meter: 11
Redmi Note 8 Ginkgo No EDL point frp done by UAT PRO
Old 02-03-2025, 19:11   #4117 (permalink)
Member: 3065224
Thanks Meter: 11
Samsung X200 Tab A8 Password remove done by UAT PRO
Old 02-27-2025, 13:10   #4118 (permalink)
Member: 3065224
Thanks Meter: 11
Infinix smart 8 pro(x6525b)(auto mode) frp lock remove done by uat pro
INFINIX SMART 8 PRO(X6525B)(AUTOMODE) FRP LOCK REMOVE DONE BY UAT PRO
MediaTek Process
1. Power off device
2. Remove Install battery if needed
3. Connect USB cable to powered off device
4. For New sec. Press and Hold Both Volume keys for Brom Mode
5. For Old sec. Press and Hold Volume UP for Brom Mode
6. Do not press any Key for PreLoader Mode
7. Install drivers if needed
- Method : Auto detect
- Process : Reset FRP | Erase Method
- Selected Pre Auth : Infinix - 2024
- Protocol : Version - 5
Waiting for device... [COM5]
Port : COM5 : MediaTek PreLoader USB VCOM (Android)
USB : USB\ROOT_HUB30\4&F079BE6&0&0
Drivers : MediaTek Inc. [usb2ser.sys]
Driver Date : 09/11/2014
Driver Version : 3.0.1437.1
Initializing usb... OK
Handshaking... OK
Reading hardware info...
BOOT MODE : PRELOADER
HW ID : MT6765 [766] Helio P35/G35
Details : CA00 , 8A00 , 0000
Sec Config : [SBA:True] [SLA:False] [DAA:True]
MEID : 2CE3E82A0436E62AF93AFB29054FF192
Sending Download-Agent... OK
Jump DA Address... OK
Syncing... OK
Getting Synchronized Signal... OK
Setting Environment... OK
Getting Hardware signal... OK
Setting up device... OK
USB_SPEED : HIGH-SPEED
Connection type... [PRELOADER]
Syncing with DA... OK
Bypassing authentication (preloader auth)... OK
Fetching Storage... OK
CHIP TYPE : eMMC
BOOT 1 : 0x0000000000400000 [4.00 MB ]
BOOT 2 : 0x0000000000400000 [4.00 MB ]
RPMB : 0x0000000001000000 [16.00 MB ]
STORAGE : 0x0000000E67800000 [57.62 GB ]
CID : D60103413341353631120A4A41D0191F
INIT_SRAM : 0x000000000003A000 [232.00 KB ]
EXT_DRAM : 0x0000000100000000 [4.00 GB ]
HW_CODE : 0x7660000000000000
HWSUB_CODE : 0x8A00000000000000
HW_VERSION : 0xCA00000000000000
SW_VERSION : 0x0000000000000000
Reading partition info... OK [55]
Reading device info... SKIPPED !!
Bootloader : LOCKED
Resetting frp [Erase Method] : OK
Rebooting device... OK
UAT PRO™ : 183.01 | 27 - February - 2025 [ 16:10:58 ] INDIA
Old 02-27-2025, 13:13   #4119 (permalink)
Member: 3065224
Thanks Meter: 11
Xiaomi redmi 12 4g(tapas)(android 15) frp lock remove done by uat pro
XIAOMI REDMI 12 4G(TAPAS)(ANDROID15) FRP LOCK REMOVE DONE BY UAT PRO
Edl Process
1. Power off device
Waiting for QDLoader port... COM10
Port : COM10 : Qualcomm HS-USB QDLoader 9008
USB : USB\VID_214B&PID_7250\5&FDC9F79&0&1
Handshaking... OK
Serial : 46A402B4 SoC : [Snapdragon 680 4G] Target : [SM6225]
HWID : [0X001B80E1]
PKhash [0] : 1BEBE3863A6781DB4B01086063007334
PKhash [1] : DE9E5CA14971C7C4F4358EC9D79CDA46
Version [6] Code Size [816] Signature Size [256] Header Type [NEW]
Device requires authorization...
Authorizing device for operations... OK
Firehose config : UFS [Sector:4096] [Target:0] [Host:16384]
Reading partition table... OK [107]
Resetting FRP [Erase Method]... OK
UAT PRO™ : 183.01 | 27 - February - 2025 [ 2:18:10 PM ] INDIA
Elapsed Time : 43 seconds
Old 02-27-2025, 13:25   #4120 (permalink)
Member: 3065224
Thanks Meter: 11
Oppo a59 5g(cph2617) password + frp lock remove done by uat pro
OPPO A59 5G(CPH2617) PASSWORD + FRP LOCK REMOVE DONE BY UAT PRO
MediaTek Process
1. Power off device
Waiting for device... [COM9]
Port : COM9 : MediaTek PreLoader USB VCOM_V1632 (Android)
USB : USB\ROOT_HUB20\4&37566865&0
Driver Date : 01/22/2015
Driver Version : 3.0.1504.0
Handshaking... OK
HW ID : MT6833 [989] Dimensity 700 5G k6833
MEID : 5AF4AB4BFF46BFC66F5C7F504AB4F5B8
Syncing... OK
Booting DA... OK
CHIP TYPE : UFS
UFS_LUN0 : 0x0000000000400000 [4.00 MB ]
UFS_LUN1 : 0x0000000000400000 [4.00 MB ]
STORAGE : 0x0000001DCB000000 [119.17 GB ]
CID : AD01484E385430363245484B58303339
INIT_SRAM : 0x0000000000070000 [448.00 KB ]
HW_CODE : 0x9890000000000000
Reading partition info... OK [68]
Bootloader : LOCKED
Factory resetting [Userdata Method] : OK
Erasing FRP... OK
UAT PRO™ : 183.01 | 27 - February - 2025 [ 10:45:01 AM ] INDIA
Elapsed Time : 1 seconds
Old 02-27-2025, 15:40   #4121 (permalink)
Member: 3065224
Thanks Meter: 11
Oppo f27 pro + 5g(cph2643)(auto mode) frp lock remove done by uat pro
OPPO F27 PRO + 5G(CPH2643)(AUTOMODE) FRP LOCK REMOVE DONE BY UAT PRO
MediaTek Process
1. Power off device
- Selected Pre Auth : OPPO | REALME
Waiting for device... [COM14]
Port : COM14 : USB Serial Device
USB : PCI\VEN_8086&DEV_1C5C&SUBSYS_7B951019&REV_05\3&115 83659&0&F8
Driver Date : 01/22/2016
Handshaking... OK
BOOT MODE : BROM
HW ID : MT6877 [959] Dimensity 900
MEID : 8ADE74E38CE2D1146EE8ABDC1EFBEFB8
Syncing... OK
Booting DA... OK
CHIP TYPE : UFS
STORAGE : 0x0000003B96000000 [238.34 GB ]
CID : CE014B4C55454734524847422D423045
EXT_DRAM : 0x0000000200000000 [8.00 GB ]
HW_CODE : 0x9590000000000000
Reading partition info... OK [77]
Bootloader : LOCKED
UAT PRO™ : 183.01 | 27 - February - 2025 [ 6.21.43 PM ] INDIA
Elapsed Time : 17 seconds
Old 03-01-2025, 06:24   #4122 (permalink)
Member: 3065224
Thanks Meter: 11
Vivo v7(pd1718f)(auto mode) password and frp lock remove done by uat pro
VIVO V7(PD1718F)(AUTOMODE) PASSWORD AND FRP LOCK REMOVE DONE BY UAT PRO
Edl Process
1. Power off device
- Protocol : New
Waiting for QDLoader port... COM4
Port : COM4 : Qualcomm HS-USB QDLoader 9008
Handshaking... OK
Serial : 246221EF SoC : [Snapdragon 450] Target : [MSM 8953]
HWID : [0X0009A0E1]
PKhash [0] : 60BA997FEF6DA9F05885FA11F1DD6D2A
PKhash [1] : 90D052A257A09C2075D7246CC73C0D43
Version [3] Code Size [288] Signature Size [256] Header Type [OLD]
Vendor [QUALCOMM] OEM ID [0000] Qc Version [BOOT.BF.3.3-00221] Variant [JAADANAZA]
Chipset Type... 32 bit
Reading partition table... OK [55]
Reading software info... OK [System]
Brand Name : vivo
Model Name : vivo 1718
Hardware : msm8953
CPU : arm64-v8a
Software : PD1718F_EX_A_3.70.3
Platform : msm8953
EMI ID : msm8953_64
Host : compiler029
Screen : TFT
Base : android-vivo
Platform : QCOM8953
Vivo OS : 4.0
OS Name : Funtouch
eMMC Size : 16GB
Local lang : en-US
Carrier : unknown
GsmVersion : 8.1_201812
HWD Version : PD1718F_EXMA
Product Version : PD1718F_EX_A_3.70.3
Product Name : msm8953_64
Android OS : Oreo
Security Patch : 2020-09-01
UAT PRO™ : 183.01 | 28 - February - 2025 [ 2:08:13 PM ] INDIA
Elapsed Time : 29 seconds
Old 03-01-2025, 15:34   #4123 (permalink)
Member: 3065224
Thanks Meter: 11
Xiaomi redmi 9a(dandelion) password and frp lock remove done by uat pro
XIAOMI REDMI 9A(DANDELION) PASSWORD AND FRP LOCK REMOVE DONE BY UAT PRO
MediaTek Process
1. Power off device
Port : COM5 : MediaTek USB Port
USB : USB\ROOT_HUB30\4&1CD7EA71&0&0
Handshaking... OK
BOOT MODE : BROM
MEID : FCCD7090984C6B07F2B28014369129F7
Bypassing authentication... OK
Handshaking... OK
Analyzing Preloader... preloader_k62v1_64_bsp.bin [Internal] OK
Sending Download-Agent (Stage-1)... OK
Syncing... OK
Connection type... [BROM]
Sending EMI config... OK
Sending Download-Agent (Stage-2)... OK
Syncing with 2nd DA... OK
Booting DA... OK
CHIP TYPE : eMMC
RPMB : 0x0000000000400000 [4.00 MB ]
STORAGE : 0x0000000747C00000 [29.12 GB ]
CID : 150100424A5444345209458FB6F1B711
EXT_DRAM : 0x0000000080000000 [2.00 GB ]
Reading partition info... OK [46]
Reading device info... OK [Super]
Android OS : Quince Tart
Android Version : 10
Base : android-xiaomi
Brand : Redmi
Build : V12.0.17.0.QCDINXM
Build Date : Sun Jul 11 19:23:41 CST 2021
Build ID : QP1A.190711.020
CPU : armeabi-v7a
Device Mod : dandelion_in_global
Display ID : QP1A.190711.020
EMI ID : dandelion
Host : c4-miui-ota-bd174.bj
Local lang. : en-GB
MIUI Code : 10
MIUI Version : V12
Manufacturer : Xiaomi
Market Name : Redmi 9A
Model Name : M2006C3LI
Product Name : dandelion_in
Security Patch : 2021-06-01
Soft. Version : V12.0.17.0.QCDINXM
Bootloader : LOCKED
Erasing USERDATA (SAFE)... OK
Erasing FRP... OK
UAT PRO™ : 183.01 | 01 - March - 2025 [ 19:16:08 ] INDIA
Elapsed Time : 10 seconds
Old 03-01-2025, 15:53   #4124 (permalink)
Member: 3065224
Thanks Meter: 11
Samsung a30(a305f)(adb method) frp lock remove done by uat pro
SAMSUNG A30(A305F)(ADB METHOD) FRP LOCK REMOVE DONE BY UAT PRO
Modem Process
Waiting for modem port... [COM12]
Port : COM12 : SAMSUNG Mobile USB Modem
USB : USB\VID_04E8&PID_6860\RZ8M31KX8YL
Reading device info. ...
Read Info Skipped
Enabling ADB, please wait ...
ADB Enabled done
Please check confirmation dialog on your device screen and allow it
Waiting for adb device ...
Device found
Model : SM-A305F
Manufucture : samsung
Android Version : 11
Android OS : Red Velvet Cake
CPU : arm64-v8a
Security Patch : 2023-01-01
Platform : exynos7904
Hardware : exynos7904
Board : exynos7904
Bootloader : A305FDDS6CWA3
USB Config : mtp,adb
User : dpi
Baseband : A305FXXS6CWA1,A305FXXS6CWA1
Display ID : RP1A.200720.012.A305FDDS6CWA3
Build ID : RP1A.200720.012
PDA : A305FDDS6CWA3
SIM State : ABSENT,ABSENT
Product Code : SM-A305FZKFINS
Soft Version : A305FXXS6CWA1
Build Date : Mon Jan 9 16:05:03 KST 2023
Build Tags : release-keys
Country Code : India
Network Type : Unknown,Unknown
LCD Density : 420
Data Encryption : encrypted
Device IMEI : 354872104415199
Checking Root : Not Rooted
Resetting frp please wait ...
Reset frp done
UAT PRO™ : 183.01 | 01 - March - 2025 [ 5:47:45 PM ] INDIA
Elapsed Time : 22 seconds
Old 03-01-2025, 16:02   #4125 (permalink)
Member: 3065224
Thanks Meter: 11
Samsung a10s(a107f)(auto mode) frp lock remove done by uat pro
SAMSUNG A10S(A107F)(AUTOMODE) FRP LOCK REMOVE DONE BY UAT PRO
Page generated in 0.33277 seconds with 9 queries
