04-21-2018, 09:59 | #1428 (permalink) |
No Life Poster Join Date: Jul 2008 Location: Bangladesh
Member: 821462 Status: Offline Thanks Meter: 838 | Samsung J500H FRP Done -- Checking Current Version -- Current Version OK -- Checking User Login -- User Login OK. -- Searching for Device -- Device Found. -- Port : COM400 : SAMSUNG Mobile USB Modem #224 -- BaudRate : 115200 -- Reading Data from device !! -- Data Read SuccessFully -- Launching Frp Lock New Method... Okay -- Searching For Frp Data ... Please Wait... -- Frp data : found -- Cleaning Data... ok -- Verifying Data... ok -- Writing Data... ok -- FRP Reset Successfully...done -- Rebooting Device ... |
The Following 2 Users Say Thank You to sajid01913 For This Useful Post: |
04-22-2018, 00:10 | #1429 (permalink) |
No Life Poster Join Date: May 2002 Location: TX Age: 49
Member: 12427 Status: Offline Thanks Meter: 78 | Log#3 Unlock Samsung T357T -- Checking Current Version -- Current Version OK -- Checking User Login -- User Login OK. 1 - Dial *#0808# Chose DM+Modem+ADB 2 - Connect Usb cable and Install Driver if need 3 - Select Samsung Serial port and click unlock Button if Device Android Version 5.x.x or Higher then 1 - Root the device 2 - Connect usb cable and enable usb debbug 3 - Going to Samsung Tab -> Utilities -> Click Enable Diag Button 4 - Dial *#0808# Chose DM+Modem+ADB 5 - Select Samsung Serial port and click unlock Button Searching Device Device Found Selected Port : COM141 [ Port @921600] Unlock Process Started .. Reading Phone Information ... Relase Date : Jun 15 2015 Compile Date : Dec 8 2016 Build No : MPSS.DPM.2.0.c5-00086-M8936FAAAANUZM-1 IMEI : 351969070864476 ESN : B0000000 Analizing Security... OK -> New Security Detected! Unlocking Device Unlock... OK Rebooting....... if ask code put 00000000 or 11111111 if not reboot please do it manually, do not remove battery! |
The Following User Says Thank You to abcchoier For This Useful Post: |
04-22-2018, 18:47 | #1430 (permalink) |
Insane Poster Join Date: Feb 2018 Location: Brazil
Member: 2807526 Status: Offline Thanks Meter: 67 | Zenfone 4 Selfie FRP Done!!! Checking Current Version Current Version OK Checking User Login User Login OK. Searching device Device on Port : [ COM12 ] Analyzing Please wait ... MODEL : Asus ZenFone 4 Selfie ZD553KL(X00LD) MEM_TYPE : EMMC BLOCK_ID_S : 3EFAF265 BLOCK_ID_L : 00000000 BLOCK_ID_H : AD38BEB6615BA7FBA38361DAE6BF2DF1 BLOCK_ID_H : 4AF5E7AC6AF8E78DB46C3ADD435E4174 Starting Asus Frp Removal Method Reading Data .. Please wait Sending loader Please wait ... Loader successfully Sent ... Model : ASUS_X00LDA Android Version : 7.1.1 Name : WW_Phone Display ID : NMF26F.WW_Phone-14.0400.1712.181-20171205 Device : ASUS_X00LD_3 Manufacturer : asus Product : ASUS_X00LD_3 Reading Frp Data FRP Data Found Removing Frp data .. Please Wait Writting Data @ 512kb/s Write data done Frp Removal Succeeded. Rebooting Device |
The Following 2 Users Say Thank You to DanielSantoz For This Useful Post: |
04-24-2018, 15:20 | #1434 (permalink) |
Member: 821462 Status: Offline Thanks Meter: 838 | Samsung J320FN Network Unlock Done -- Checking Current Version -- Current Version OK -- Checking User Login -- User Login OK. Searching Device Device Found Selected Port : COM614 : SAMSUNG Mobile USB Modem #373 [ Port @115200] Selected Model : SM-J320FN Reading Device Info... Model : SM-J320FN Software Ver. : J320FNXXU0ARA1 : J320FNITV0ARA1 : J320FNXXU0ARA1 : J320FNXXU0ARA1 Hardware Ver. : J320FNXXU0ARA1 : J320FNITV0ARA1 : J320FNXXU0ARA1 : J320FNXXU0ARA1 Serial Number : RF8JC1QBVKX Base : SM-N900 PRD : SM-J320FZKNITV);;OMCCODE( Unique Number : CQN002B2BE0B4B4 IMEI : 359965087820487 Conection Type : AT,MTP Unlocking Please wait ... Unlock Done !! Rebooting Device... if not reboot please do it manually. if ask Unlock code Please Put 00000000 or 11111111 |
The Following User Says Thank You to sajid01913 For This Useful Post: |
04-24-2018, 20:20 | #1437 (permalink) |
Member: 2807526 Status: Offline Thanks Meter: 67 | XT1763 FRP DONE!!! Checking Current Version Current Version OK Checking User Login User Login OK. 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Searching Device Device found Sending data Please wait ... Data Sent Successfully Chip Type : MT6737M Software Version : 0000 Hardware Version : 00CB Ram info. : 0xFD03350000 Resetting Frp Frp Reset Succeeded Elapsed Time : 0 minutes - 8 seconds |
04-25-2018, 15:48 | #1439 (permalink) |
Product Supporter Join Date: Dec 2010 Location: Brazil Fortaleza Ceará
Member: 1474113 Status: Offline Sonork: 100.1604217 Thanks Meter: 474 | alcatel pixi 4 FRP DONE 4 se****s Checking Current Version Current Version OK Checking User Login User Login OK. 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Searching Device Device found Sending data Please wait ... Data Sent Successfully Chip Type : MT6737M Software Version : 0000 Hardware Version : 00CB Ram info. : 0xFD03350000 Resetting Frp Frp Reset Succeeded Elapsed Time : 0 minutes - 6 seconds |
The Following 2 Users Say Thank You to paulo pessoa For This Useful Post: |
04-25-2018, 17:20 | #1440 (permalink) |
Freak Poster Join Date: Aug 2009 Location: India
Member: 1090266 Status: Offline Thanks Meter: 25 | Infinix X573 Password Unlock Reset Locks ======== Checking Current Version Current Version OK Checking User Login User Login OK. Searching device Device on Port : [ COM49 ] Analyzing Please wait ... CPU_ID : [MSM 8937] MEM_TYPE : EMMC BLOCK_ID_S : 518075FF BLOCK_ID_L : 00000000 BLOCK_ID_H : CC3153A80293939B90D02D3BF8B23E02 BLOCK_ID_H : 92E452FEF662C74998421ADAD42A380F Starting Qualcomm Reset Locks Method Reading Data .. Please wait Sending loader Please wait ... Loader successfully Sent ... Model : Infinix X573 Android Version : 8.0.0 Name : QL1668 Display ID : X573-QL1668DEF-O-IN-20180105V19 Device : Infinix-X573 Manufacturer : INFINIX MOBILITY LIMITED Product : Infinix-X573 Reading Data pleas wait Read Data done.. Resetting Locks Please wait ... Reset Locks Successfully Done Not Done Format ====== Checking Current Version Current Version OK Checking User Login User Login OK. Searching device Device on Port : [ COM49 ] Analyzing Please wait ... CPU_ID : [MSM 8937] MEM_TYPE : EMMC BLOCK_ID_S : 518075FF BLOCK_ID_L : 00000000 BLOCK_ID_H : CC3153A80293939B90D02D3BF8B23E02 BLOCK_ID_H : 92E452FEF662C74998421ADAD42A380F Starting Qualcomm Format Method Reading Data .. Please wait Sending loader Please wait ... Loader successfully Sent ... Model : Infinix X573 Android Version : 8.0.0 Name : QL1668 Display ID : X573-QL1668DEF-O-IN-20180105V19 Device : Infinix-X573 Manufacturer : INFINIX MOBILITY LIMITED Product : Infinix-X573 Reading Data pleas wait Formatting Device Please wait ... Format Successfully Done 100% Done Thanks Team |
The Following User Says Thank You to smondal For This Useful Post: |
