01-22-2018, 09:05 | #811 (permalink) |
No Life Poster Join Date: Aug 2012 Location: under pross
Member: 1798174 Status: Offline Sonork: 100.114149 Thanks Meter: 1,047 | huawei y600-u20 flash done with uat Tips: 1. Remove Battery, Insert usb cable, Insert battery 2. power off Phone, Remove & Reinsert Battery , insert USB Cable (In Case Some Phone Requires to hold bootkey) Waiting for Phone Usb.... Phone found on : COM87 COM port is open. Trying to sync with the target... Waiting for Phone Usb.... Phone found on : COM87 Flashing Device Please Wait .... Flashing Successfuly Done. Rebooting Device into Normal Mode ... Please Wait few Seconds to get Device in Normal Mode ... Elapsed Time : 3 minutes - 0 seconds Last edited by namyelus; 01-22-2018 at 12:23. Reason: Put IMAGE |
The Following User Says Thank You to Pastime_GSM For This Useful Post: |
01-22-2018, 10:07 | #812 (permalink) |
Member: 1798174 Status: Offline Sonork: 100.114149 Thanks Meter: 1,047 | evertek everstar d40 flash done with uat Flash Process started... Tips: 1. Remove Battery, Insert usb cable, Insert battery 2. power off Phone, Remove & Reinsert Battery , insert USB Cable (In Case Some Phone Requires to hold bootkey) Waiting for Phone Usb.... Phone found on : COM19 COM port is open. Trying to sync with the target... Flashing Device Please Wait .... Flashing Successfuly Done. Rebooting Device into Normal Mode ... Please Wait few Seconds to get Device in Normal Mode ... Elapsed Time : 3 minutes - 30 seconds Last edited by namyelus; 01-22-2018 at 12:23. |
01-22-2018, 10:59 | #813 (permalink) |
Member: 1798174 Status: Offline Sonork: 100.114149 Thanks Meter: 1,047 | Flash Process started... Tips: 1. Remove Battery, Insert usb cable, Insert battery 2. power off Phone, Remove & Reinsert Battery , insert USB Cable (In Case Some Phone Requires to hold bootkey) Waiting for Phone Usb.... Phone found on : COM19 COM port is open. Trying to sync with the target... Flashing Device Please Wait .... Flashing Successfuly Done. Rebooting Device into Normal Mode ... Please Wait few Seconds to get Device in Normal Mode ... Elapsed Time : 3 minutes - 30 seconds |
01-22-2018, 12:24 | #816 (permalink) |
Freak Poster Join Date: Feb 2017
Member: 2686635 Status: Offline Thanks Meter: 94 | MICROMAX Q465 FRP REMOVE DONE IN FASTBOOT MODE... Last edited by ultimatebadal; 04-08-2018 at 05:41. |
The Following User Says Thank You to ultimatebadal For This Useful Post: |
01-22-2018, 12:35 | #817 (permalink) |
Member: 2686635 Status: Offline Thanks Meter: 94 | LENOVO A526 FLASHING DONE..... Flash Process started... Tips: 1. Remove Battery, Insert usb cable, Insert battery 2. power off Phone, Remove & Reinsert Battery , insert USB Cable (In Case Some Phone Requires to hold bootkey) Waiting for Phone Usb.... Phone found on : COM14 COM port is open. Trying to sync with the target... Flashing Device Please Wait .... Flashing Successfuly Done. Rebooting Device into Normal Mode ... Please Wait few Seconds to get Device in Normal Mode ... Elapsed Time : 3 minutes - 5 seconds |
01-22-2018, 12:44 | #818 (permalink) |
Freak Poster Join Date: Jul 2007 Location: Rawalpindi Pakistan Age: 37
Member: 541180 Status: Offline Sonork: 100.1626680 Thanks Meter: 147 | Samsung GT B5512 hardreset with Uni Android Tool Samsung GT B5512 Pattern Lock Remove with Uni Android Tool by one click |
The Following User Says Thank You to qaiser_ali123 For This Useful Post: |
01-22-2018, 13:57 | #820 (permalink) |
No Life Poster Join Date: Jul 2008 Location: Bangladesh
Member: 821462 Status: Offline Thanks Meter: 833 | Samsung J200H FRP Done Just in a Second! -- Checking Current Version -- Current Version OK -- Checking User Login -- User Login OK. -- Searching for Device -- Device Found. -- Port : COM400 : SAMSUNG Mobile USB Modem #224 -- BaudRate : 115200 -- Reading Data from device !! -- Data Read SuccessFully -- Launching Frp Lock New Method... Okay -- Searching For Frp Data ... Please Wait... -- Frp data : found -- Cleaning Data... ok -- Verifying Data... ok -- Writing Data... ok -- FRP Reset Successfully...done -- Rebooting Device ... |
The Following User Says Thank You to sajid01913 For This Useful Post: |
01-22-2018, 14:19 | #821 (permalink) |
No Life Poster Join Date: May 2013 Location: Far From Home..:(
Member: 1948608 Status: Offline Thanks Meter: 1,743 | mobicell onyx flash done UAT Flash Process started... Tips: 1. Remove Battery, Insert usb cable, Insert battery 2. power off Phone, Remove & Reinsert Battery , insert USB Cable (In Case Some Phone Requires to hold bootkey) Waiting for Phone Usb.... Phone found on : COM14 COM port is open. Trying to sync with the target... Flashing Device Please Wait .... Flashing Successfuly Done. Rebooting Device into Normal Mode ... Please Wait few Seconds to get Device in Normal Mode ... Elapsed Time : 2 minutes - 50 seconds |
The Following User Says Thank You to -Mosin- For This Useful Post: |
01-22-2018, 14:50 | #822 (permalink) |
No Life Poster Join Date: Nov 2006 Location: Türkiye
Member: 395431 Status: Offline Thanks Meter: 458 | lenovo P1a41 world first lenovo P1a41 imei repair nor root no data loss press power off and wolume down insert usb cable direct imei repair Last edited by Mehmood Riaz 1; 01-22-2018 at 17:01. |
The Following User Says Thank You to turkcellgsm For This Useful Post: |
01-22-2018, 15:21 | #823 (permalink) |
Member: 1948608 Status: Offline Thanks Meter: 1,743 | ::LG D320 pinlock done by UAT:: Checking User Login User Login OK. 1 - Turn the phone OFF 2 - Press Vol+ And Put Micro USB Cable 3 - Wait for Device Go into Download mode then install driver if needed! Searching Device...... Device Found!! Reading Info.... Model : LG-D320 Software Version : D32010d IMEI : 3529xxxxxxxxxxx Android Version : 4.4.2 Removing All Locks Please Wait... Writting Locks Data Please Wait.... Step1...OK Step2...OK Step3...OK Step4...OK Step5...OK Reset All Locks Done!! Rebooting Device... |
01-22-2018, 16:55 | #825 (permalink) |
No Life Poster Join Date: Jan 2009 Location: cameroon
Member: 953931 Status: Offline Sonork: 1652252 Thanks Meter: 897 | ZTE L110 FRP REMOVE DONE BY U.A.T Code: -- Checking Current Version -- Current Version OK -- Checking User Login -- User Login OK. -- Searching Device - -- Fastboot Device Found -- Reading Device Info. -- Version : 1.0 -- Product : -- Serial No : -- Operation : ITEL FRP RESET -- Resetting Frp Please wait... -- Frp Reset Successfuly Done.. -- Rebooting Device -- Elapsed Time : 0 minutes - 4 seconds |
The Following 2 Users Say Thank You to fokal2008 For This Useful Post: |
