01-15-2023, 19:05 | #3946 (permalink) |
No Life Poster Join Date: Mar 2015 Location: Islam Age: 35
Member: 2371500 Status: Offline Thanks Meter: 5,801 | Samsung Galaxy J4 Core SM-J410 FRP REMOVED WITH ADB ENABLING TRICK Device found Port : [ COM22 : SAMSUNG Mobile USB Modem ] Reading device info. ... Brand : Samsung Electronics Co., Ltd. Model : SM-J410F Country : AFGHANISTAN SW Version : J410FXXS2AUD1/J410FOJM2ASL2/J410FXXS2ATF1/J410FXXS2AUD1 HW Version : J410FXXS2AUD1 MNC : 05 MCC : 418 Serial : R28M12ZWJTT IMEI : 353793109584923 Unqiue Code : CFE0032C6C659C5 Connection : AT,MTP Read Info done Enabling ADB .... ADB Enabled done Please check confirmation dialog on your device screen and allow it Waiting for adb device ... Device found Model : SM-J410F Manufucture : samsung Android Version : 8.1.0 CPU : armeabi-v7a Platform : msm8937 Chipset : MSM8917 Hardware : qcom Board : msm8937 Bootloader : J410FXXS2AUD1 USB Config : sec_charging,adb User : dpi Baseband : J410FXXS2ATF1 Display ID : M1AJB.J410FXXS2AUD1 Build ID : M1AJB PDA : J410FXXS2AUD1 SIM State : ABSENT,ABSENT Serial No. : R28M12ZWJTT Soft Version : J410FXXS2ATF1 Build Date : Fri Apr 23 15:45:43 KST 2021 Build Tags : release-keys Country Code : Afghanistan Network Type : Unknown,Unknown SIM Operator : , LCD Density : 320 Data Encryption : encrypted Device IMEI : 353793109584923 Checking Root : Not Rooted Resetting frp please wait ... Reset frp done UAT PRO : 150.01 | 14 - كانون*الثاني - 2023 [ 09:41:55 م ] Elapsed Time : 4 seconds |
01-16-2023, 18:31 | #3947 (permalink) | |
No Life Poster Join Date: Sep 2008 Location: FMI OF Age: 52
Member: 866455 Status: Offline Sonork: SAMSUNG CPID ONLINE Thanks Meter: 577 | MI 9T SUCESED FLASH from eng room to normal [IMG][/IMG] Quote:
01-16-2023, 18:32 | #3948 (permalink) | |
01-16-2023, 19:25 | #3949 (permalink) |
Member: 2371500 Status: Offline Thanks Meter: 5,801 | SM-A115F Samsung Galaxy A11 BROSER TRICK TO REMOVE FRP DONE A115FXXU2AUA3 Waiting for MTP device ... Dvice found Reading device info. ... Brand : Samsung Electronics Co., Ltd. Installing drivers... DONE Launching browser event ... DONE Press 'view' on device screen to open the browser then continue to bypass FRP UAT PRO : 150.01 | 16 - كانون*الثاني - 2023 [ 09:18:06 م ] Elapsed Time : 10 seconds |
01-20-2023, 08:30 | #3951 (permalink) |
Product Supporter Join Date: Aug 2017 Location: Islam Age: 34
Member: 2750997 Status: Offline Sonork: 100.1678720 Thanks Meter: 1,266 | Oppo A83 Screen Lock Without Data Loss One Click By UAT PRO Oppo A83 Screen Lock Without Data Loss One Click By UAT PRO |
01-20-2023, 17:42 | #3952 (permalink) | |
No Life Poster Join Date: Jun 2006 Location: Poland Pruszków-Warszawa-Warka
Member: 290272 Status: Offline Thanks Meter: 431 | Huawei y6 2018 atu-l31 Quote:
The Following User Says Thank You to marcin7904 For This Useful Post: |
01-29-2023, 17:46 | #3953 (permalink) |
Freak Poster Join Date: May 2004 Location: Slovakia Age: 45
Member: 66497 Status: Offline Thanks Meter: 80 | Huawei JAD-LX9 Repair chip damage OK 1. Power off device 2. Press and hold volume up + volume down insert usb cable 3. In some case requires special edl cable or test points 4. Install Qualcomm drivers if needed ==================================== - Connection : EDL - Method : By Model - Brand : Huawei - Model : JAD-LX9 (Huawei P50 Pro) - Process : Honor Fix Damaged Chip ==================================== Waiting for QDLoader port ... Port found Device on Port : [ COM14 : Qualcomm HS-USB QDLoader 9008 ] Analyzing Sahara please wait ... HW_ID : 0001E0E9100 BLOCK_ID_S : 36911FAB BLOCK_ID_H : 72NO12P8Q8N3ON19R019SPQ68544S98N BLOCK_ID_H : NR92602448299522355184N0PON47048 Executing boot : DONE Version : 6 Code Size : 816 Signature Size : 512 Header Type : NEW FhVendor : QUALCOMM HW ID : 000000000015006F SW ID : 00000003 OEM ID : 0015 Vendor : HUAWEI Model ID : 006F APP ID : 00000000 Pk Hash : B25DECD85D217F5D9B53DC3C42EF7846DCEF59DD3E0AF4D126 06199F5099FF23 Configuring : DONE Reading Parts : DONE Capacity : 29.64 GB Userdata : 28.11 GB Reading GPT : DONE Partition Count : 101 Drivers : Qualcomm Technologies, Inc. Driver Version : 08/02/2017,2.1.2.7 MEM_TYPE : UFS Max_Payload_Size_InBytes : 1048576 Max_Payload_Size_Supp. : 1048576 Max_XML_Size : 4096 Version : 1 Date_Time : Sep 16 2021 - 03:08:21 Userdata : UnEncrypted Processing data ... Process done Prepairing data please wait.... Data prepairation done Checking damaged data in device ... Data check done Fixing chip damage error Chip damaged error fix done Setting up device please wait... Device setup done 1. If same chip damaged error appears on the device screen 2. Please press and hold volume up + power to goto recovery 3. Wipe cache / userdata or wipe all data from recovery and reboot. All process done rebooting device UAT PRO : 151.01 | 29 - January - 2023 [ 17:15:45 ] Elapsed Time : 15 seconds |
01-29-2023, 17:46 | #3954 (permalink) |
01-29-2023, 17:58 | #3955 (permalink) |
Member: 2750997 Status: Offline Sonork: 100.1678720 Thanks Meter: 1,266 | JAD-LX9 (Huawei P50 Pro) Chip Damaged fixed done One Click by UAT PRO JAD-LX9 (Huawei P50 Pro) Chip Damaged fixed done One Click by UAT PRO Code: 1. Power off device 2. Press and hold volume up + volume down insert usb cable 3. In some case requires special edl cable or test points 4. Install Qualcomm drivers if needed ==================================== - Connection : EDL - Method : By Model - Brand : Huawei - Model : JAD-LX9 (Huawei P50 Pro) - Process : Honor Fix Damaged Chip ==================================== Waiting for QDLoader port ... Port found Device on Port : [ COM14 : Qualcomm HS-USB QDLoader 9008 ] Analyzing Sahara please wait ... HW_ID : 0001E0E9100 BLOCK_ID_S : 36911FAB BLOCK_ID_H : 72NO12P8Q8N3ON19R019SPQ68544S98N BLOCK_ID_H : NR92602448299522355184N0PON47048 Executing boot : DONE Version : 6 Code Size : 816 Signature Size : 512 Header Type : NEW FhVendor : QUALCOMM HW ID : 000000000015006F SW ID : 00000003 OEM ID : 0015 Vendor : HUAWEI Model ID : 006F APP ID : 00000000 Pk Hash : B25DECD85D217F5D9B53DC3C42EF7846DCEF59DD3E0AF4D12606199F5099FF23 Configuring : DONE Reading Parts : DONE Capacity : 29.64 GB Userdata : 28.11 GB Reading GPT : DONE Partition Count : 101 Drivers : Qualcomm Technologies, Inc. Driver Version : 08/02/2017,2.1.2.7 MEM_TYPE : UFS Max_Payload_Size_InBytes : 1048576 Max_Payload_Size_Supp. : 1048576 Max_XML_Size : 4096 Version : 1 Date_Time : Sep 16 2021 - 03:08:21 Userdata : UnEncrypted Processing data ... Process done Prepairing data please wait.... Data prepairation done Checking damaged data in device ... Data check done Fixing chip damage error Chip damaged error fix done Setting up device please wait... Device setup done 1. If same chip damaged error appears on the device screen 2. Please press and hold volume up + power to goto recovery 3. Wipe cache / userdata or wipe all data from recovery and reboot. All process done rebooting device UAT PRO : 151.01 | 29 - January - 2023 [ 17:15:45 ] Elapsed Time : 15 seconds Reported by UAT PRO User [Milan Svitek] |
02-01-2023, 15:09 | #3956 (permalink) |
Product Supporter Join Date: Mar 2016 Location: Bangladesh
Member: 2548908 Status: Offline Sonork: 100.1672479 Thanks Meter: 761 | Samsung A520F FRP Remove Done By UAT Pro Samsung A520F FRP Remove Done By UAT Pro Code: Waiting for MTP port ... Device found Port : [ COM3 : SAMSUNG Mobile USB Modem ] Reading device info. ... Brand : Samsung Electronics Co., Ltd. Model : SM-A520F Country : SAUDI ARABIA SW Version : A520FXXSGCTK1/A520FOJVGCTK1/A520FXXSGCTK1/A520FXXSGCTK1 HW Version : A520FXXSGCTK1 MNC : 03 MCC : 470 Serial : R58J91HRH5B IMEI : 359601088064177 Unqiue Code : CBJ0025BDFE7C84 Connection : AT,MTP Read Info done Enabling ADB .... ADB Enabled done Please check confirmation dialog on your device screen and allow it Waiting for adb device ... Device found Model : SM-A520F Manufucture : samsung Android Version : 8.0.0 CPU : arm64-v8a Platform : universal7880 Chipset : exynos7880 Hardware : samsungexynos7880 Board : universal7880 Bootloader : A520FXXSGCTK1 USB Config : mtp,adb User : dpi Baseband : A520FXXSGCTK1 Display ID : R16NW.A520FXXSGCTK1 Build ID : R16NW PDA : A520FXXSGCTK1 SIM State : ABSENT,ABSENT Product Code : SM-A520FZKDKSA Serial No. : R58J91HRH5B Soft Version : A520FXXSGCTK1 Build Date : Sat Nov 7 19:59:15 KST 2020 Build Tags : release-keys Country Code : KSA Network Type : Unknown,Unknown SIM Operator : , LCD Density : 480 Data Encryption : encrypted Device IMEI : 359601088064177 Checking Root : Not Rooted Resetting frp please wait ... Reset frp done UAT PRO : 151.01 | 01 - February - 2023 [ 1:06:30 PM ] Elapsed Time : 3 seconds |
02-04-2023, 09:26 | #3957 (permalink) |
Member: 2750997 Status: Offline Sonork: 100.1678720 Thanks Meter: 1,266 | Xiaomi Redmi Note 11 Screen Lock + Frp Reset Without Open Mi Assistant Mode By UAT PR Xiaomi Redmi Note 11 Screen Lock + Frp Reset Without Open Mi Assistant Mode By UAT PRO |
02-12-2023, 04:40 | #3960 (permalink) |
Insane Poster Join Date: Jan 2023 Location: phillippines
Member: 3029970 Status: Offline Sonork: NULL Thanks Meter: 32 | 1. Power off device 2. Press and Hold Volume up + Power 3. Wait device screen to appear recovery Options 4. Select MiAssistant option 5. Insert Cable, Select Model and do the selected process ==================================== - Connection : MiAssistant Mode - Selected Model : Mi 11 (venus) - Process : Reset FRP ==================================== Searching device by MiAssistant Mode ... Device found Reeading Info. please wait ... Selected Model : Mi 11 (venus) Product Name : venus Device Name : venus Android Version : 12 Android OS : Snow Cone MIUI Version : V13.0.4.0.SKBMIXM Branch Info. : F Recovery Version : 2 DeviceSerial : 0x3bf5a17a Rom Zone : 2 Language Info. : en Region Info. : GB Country : UNITED KINGDOM Resetting frp, please wait ... Reset frp done UAT PRO : 151.02 | 12 - February - 2023 [ 11:34:28 AM ] Elapsed Time : 4 seconds |
The Following User Says Thank You to FullFlash2023 For This Useful Post: |
