06-03-2022, 01:37 | #1 (permalink) |
No Life Poster Join Date: Oct 2009 Location: GRAN ALACANT SPAIN
Member: 1147852 Status: Offline Thanks Meter: 587 | Problem to service oppo a15 cph2185 2. Remove Install battery if needed 3. Connect USB cable to powered off device 4. For New sec. Press and Hold Both Volume keys for Brom Mode 5. For Old sec. Press and Hold Volume UP for Brom Mode 6. Do not press any Key for PreLoader Mode 7. Install drivers if needed ==================================== - Connection : Flash Mode - Method : Custom DA - Process : Format | Reset FRP ==================================== Authenticating ... DONE Initializing ... DONE ==================================== Waiting for device ... Device found MediaTek USB Port_V1632 (COM10) Mode : BootRom Port : COM10 Handshaking ... DONE Initializing : DONE Hw code: MT6765 - Helio P35/G35 Hw sub code: 8A00 Hw version: CA00 Sw version: 0000 Watchdog disable ... DONE Protection disable ... DONE Preparing Download Agent ... DA Version : MTK_AllInOne_DA_v3.3001.2020/07/07.10:10_513994 Drivers : MediaTek Inc. Driver Date : 01/22/2015 Driver Version : 3.0.1504.0 Handshaking : DONE Loading Preloader : DONE Booting device : DONE Chip name : [MT6765] Syncing with DA : DONE AT THIS STAGE IT TAKE A WHILE TO SYNCHRONIZE. Identifying Hardware ID ... ==================================== ChipID : MT0000 Software Ver : 0000 Hardware Ver : 0000 Secure Ver : 00 BootLdr Ver : 00 Ext RAM : 0xC0000000 SRAM : 0x00070000 Storage : 0x0749400000 ==================================== RAM Size : 3.000 GB SRAM Size : 448.000 KB Storage Size : 29.145 GB Storage Type : EMMC ==================================== Getting partition details : FAILED (STATUS_DEVICE_CTRL_EXCEPTION) Partition count : 0 Searching for required data... FAILED IT STUCK HERE IALREADY SERVICED A SIMILAR DEVICE BEFORE. I REINSTALLED DRIVERS , MTK LIBUSB , FILTER BUT NO SUCCESS UNABLE TO READ PREALOADER , GET ERROR FAILED 03 ANY HELP WILL BE APPRECIATED Last edited by Punto-Móvil; 06-03-2022 at 01:43. |
