Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Uni-Android Tool - UAT PRO
Old 05-31-2024, 17:13   #1 (permalink)
profkefah's Avatar
Member: 2371500
Thanks Meter: 5,870
Realme 8 (RMX3085) FRP REMOVE DONE
POWER OFF PHONE
PRESS AND HOLD VOLUME KEYS
CONNECT TO COMPUTER
1. Power off device
2. Remove Install battery if needed
3. Connect USB cable to powered off device
4. For New sec. Press and Hold Both Volume keys for Brom Mode
5. For Old sec. Press and Hold Volume UP for Brom Mode
6. Do not press any Key for PreLoader Mode
7. Install drivers if needed
- Connection : Flash Mode
- Method : By Model
- Brand : OPPO
- Model : Realme 8 (RMX3085)
- Process : Reset FRP | Erase Method
Waiting for device... [COM16]
Port : COM16 : MediaTek USB Port
USB : USB\ROOT_HUB30\4&BF7F3A7&0&0
Drivers : MediaTek Inc. [usb2ser.sys]
Driver Date : 01/22/2015
Driver Version : 3.0.1504.0
Initializing usb... OK
Handshaking... OK
Reading hardware info...
BOOT MODE : BROM
HW ID : MT6785 [813] Helio G90
Details : CA00 , 8A00 , 0000
Sec Config : [SBA:True] [SLA:False] [DAA:True]
MEID : 81CD3679D66AB796ACBF04B1A02D95B5
Bypassing authentication... OK
Handshaking... OK
Analyzing Preloader... preloader_k85v1_64.bin [Internal] OK
Sending Download-Agent (Stage-1)... OK
Jump DA Address... OK
Syncing... OK
Getting Synchronized Signal... OK
Setting Environment... OK
Getting Hardware signal... OK
Setting up device... OK
USB_SPEED : HIGH-SPEED
Connection type... [BROM]
Sending EMI config... OK
Sending Download-Agent (Stage-2)... OK
Syncing with 2nd DA... OK
Booting DA... OK
Fetching Storage... OK
CHIP TYPE : UFS
UFS_LUN0 : 0x0000000000400000 [4.00 MB ]
UFS_LUN1 : 0x0000000000400000 [4.00 MB ]
RPMB : 0x0000000001000000 [16.00 MB ]
STORAGE : 0x0000001DCB000000 [119.17 GB ]
CID : CE014B4D3856393030314A4D2D423831
INIT_SRAM : 0x0000000000080000 [512.00 KB ]
EXT_DRAM : 0x0000000200000000 [8.00 GB ]
HW_CODE : 0x8130000000000000
HWSUB_CODE : 0x8A00000000000000
HW_VERSION : 0xCA00000000000000
SW_VERSION : 0x0000000000000000
Reading partition info... OK [53]
Reading device info... SKIPPED !
Bootloader : LOCKED
Resetting frp [Erase Method] : OK
Rebooting device... OK
UAT PRO : 170.02 | 31 - May - 2024 [ 6:57:55 PM ] IRAQ
Elapsed Time : 27 seconds
The Following User Says Thank You to profkefah For This Useful Post:
Page generated in 0.10486 seconds with 8 queries
