Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Uni-Android Tool - UAT PRO
Old 03-28-2024, 16:46   #1 (permalink)
Crazy Poster
Member: 750049
Thanks Meter: 17
Redmi 9 FAILED : PARTITIONS_NOT_FOUND
hi, i received this phone dead, i was able to see the partition and start the flash, but it froze on super.img, after that i cant see the partitions anymore and got an error, can it be bad EMMC ?
Thanks.
1. Power off device
2. Remove Install battery if needed
3. Connect USB cable to powered off device
4. For New sec. Press and Hold Both Volume keys for Brom Mode
5. For Old sec. Press and Hold Volume UP for Brom Mode
6. Do not press any Key for PreLoader Mode
7. Install drivers if needed
- Connection : Flash Mode
- Method : By Model
- Brand : Xiaomi
- Model : Redmi 9 Prime (Lancelot)
- Process : Backup Nv data
Waiting for device... [COM13]
Port : COM13 : MediaTek USB Port
USB : USB\ROOT_HUB30\4&338DE6A&0&0
Drivers : MediaTek Inc. [usb2ser.sys]
Driver Date : 01/22/2015
Driver Version : 3.0.1504.0
Initializing usb... OK
Handshaking... OK
Reading hardware info...
BOOT MODE : BROM
HW ID : MT6768 [707] Helio P65/G85 k68v1
Details : CA00 , 8A00 , 0000
Sec Config : [SBA:True] [SLA:False] [DAA:True]
MEID : 90A0FF71E2B039180D5E5229DA6283B8
Bypassing authentication... OK
Handshaking... OK
Analyzing Preloader... preloader_lancelot.bin [Internal] OK
Sending Download-Agent (Stage-1)... OK
Jump DA Address... OK
Syncing... OK
Getting Synchronized Signal... OK
Setting Environment... OK
Getting Hardware signal... OK
Setting up device... OK
USB_SPEED : HIGH-SPEED
Connection type... [BROM]
Sending EMI config... OK
Sending Download-Agent (Stage-2)... OK
Syncing with 2nd DA... OK
Booting DA... OK
Fetching Storage... OK
CHIP TYPE : eMMC
BOOT 1 : 0x0000000000400000 [4,00 MB ]
BOOT 2 : 0x0000000000400000 [4,00 MB ]
RPMB : 0x0000000000400000 [4,00 MB ]
STORAGE : 0x0000000747C00000 [29,12 GB ]
CID : 150100444436384D420233B4D489C62F
INIT_SRAM : 0x0000000000070000 [448,00 KB ]
EXT_DRAM : 0x0000000100000000 [4,00 GB ]
HW_CODE : 0x7070000000000000
HWSUB_CODE : 0x8A00000000000000
HW_VERSION : 0xCA00000000000000
SW_VERSION : 0x0000000000000000
Reading partition info... FAILED : PARTITIONS_NOT_FOUND
HINT : FAILED : PLEASE CHECK IF PROPER MTK DRIVERS ARE INSTALLED !
Page generated in 0.09931 seconds with 8 queries
