07-31-2021, 07:08 | #1 (permalink) |
Freak Poster Join Date: Aug 2007 Location: Guatemala
Member: 576278 Status: Offline Thanks Meter: 32 | Redmi Note 7 remove Account fail 2 pieces [SOLVED] Waiting for QDLoader port ... Port found Device on Port : [ Qualcomm HS-USB QDLoader 9008 (COM337) ] Analyzing Sahara please wait ... HW_ID : 0001E0C8000 | Snapdragon 660 BLOCK_ID_S : F9BE6F55 BLOCK_ID_H : N2O3O37090N43RPN78Q1R4650SO91901 BLOCK_ID_H : 3Q6O0373719458996OQRS5PQ02R8P825 Executing boot : Done Configuring : Failed Device requires authorization Connecting to UAT server Checking UAT server online status UAT server is online Reading authorization blob... OK Blob : [ s0gw1raD21EA3gWweqgqA3uC+uSwT2hcZqTz0dWBiYRvAG8AdA AuAGI ] Sending request to Server Waiting for signature @256bytes authentication Signature authentication rejected HINT : Turn off phone, remove battery, keep power button pressed for 10-15 seconds without battery. Short Test Points, and connect USB cable. Once you see EDL port in device manager, connect battery and try repeating process. |
07-31-2021, 07:11 | #2 (permalink) |
Member: 576278 Status: Offline Thanks Meter: 32 | note 7 fail second piece Waiting for QDLoader port ... Port found Device on Port : [ Qualcomm HS-USB QDLoader 9008 (COM337) ] Analyzing Sahara please wait ... HW_ID : 0001E0C8000 | Snapdragon 660 BLOCK_ID_S : F9BE6F55 BLOCK_ID_H : N2O3O37090N43RPN78Q1R4650SO91901 BLOCK_ID_H : 3Q6O0373719458996OQRS5PQ02R8P825 Executing boot : Done Configuring : Failed Device requires authorization Connecting to UAT server Checking UAT server online status UAT server is online Reading authorization blob... OK Blob : [ s0gw1raD21EA3gWweqgqA3uC+uSwT2hcZqTz0dWBiYRvAG8AdA AuAGI ] Sending request to Server Waiting for signature @256bytes authentication Signature authentication rejected HINT : Turn off phone, remove battery, keep power button pressed for 10-15 seconds without battery. Short Test Points, and connect USB cable. Once you see EDL port in device manager, connect battery and try repeating process. |
07-31-2021, 07:49 | #3 (permalink) |
Product Manager Join Date: Mar 2012 Location: Some Where
Member: 1737175 Status: Offline Sonork: 100.1667675 Thanks Meter: 10,509 | Try without Selecting Model .. Try by auto detect Model Or Try both Models Redmi Note 7 (Lavender) or Redmi Note 7 (Lavender)Micron Or Contact me on Telegram @MehmoodRiaz |
